Old 04-13-2013, 02:19 PM   #15
jquayle's Avatar
2013 Interstate Coach
Napa , California
Here's what they gave me. Doesn't fit the shower however. You might need to get a whole assembly which includes the outlet and knobs if you want the newer style.
jquayle is offline   Reply With Quote
Old 04-13-2013, 08:48 PM   #16
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by jquayle View Post
Does you shower outlet have a normal hose connection?
Mine is completely different.
Name:	DSCN0182 small.jpg
ID:	183261   Click image for larger version
Name:	DSCN0183 small.jpg
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-14-2013, 08:54 PM   #17
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
That's what my 2011 looks like.
Protaganist: How did you get Hot water to the external shower outlet?
Old 04-15-2013, 12:08 AM   #18
Muskogee , Oklahoma
It has a both a hot and cold water valve. I remember seeing some units with the type on yours. I bet they simply ran out of the type used on mine for a few models and then went back to it.
In fact, it was one of the selling points by the dealer-to be able to clean out the black tank without hooking up to an external source.
Gerald
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 04-15-2013, 03:27 AM   #19
That's the way Jackson Center plumbed it. I didn't have to do anything.
WBCCI #1105
TAC LA-4
Old 04-15-2013, 06:31 AM   #20
73shark's Avatar
Yeah, I forgot that it has the Hot to it. It was late last nite.
Old 04-15-2013, 07:48 PM   #21
Teamaron's Avatar
2014 Interstate Ext. Coach
Boca Raton , Florida
Does it matter if hot is run through it? I mean you only heat water just before a shower or when you need it.
All other times doesn't the water just flow through the tank when it's off?
I know if I use faucet water and turn it to either side it stays cold when hot water is off and pressure remains the same.
Teamaron is offline   Reply With Quote
Old 04-16-2013, 06:50 AM   #22
73shark's Avatar
AFAIK, you are correct.
Old 04-16-2013, 04:21 PM   #23
When the camping trip is over and it's time to dump the black and gray tanks, I've still got hot water left after washing my breakfast dishes. So, I use that hot water to flush the black tank, courtesy of my modified external shower hose. Helps keep the tank cleaner and less odorous in between trips.
But if you routinely shut off the water heater until right before you take a shower or wash dishes to save on propane, then you probably don't have leftover hot water when you flush your black tank, and it won't matter to you.
WBCCI #1105
TAC LA-4
