Old 04-18-2016, 04:39 AM   #1
2013 Interstate Coach
Raymond , Iowa
EMS delay with generator
I have a 2012 AI. When I plug into shore power I get 120 V after a very brief delay - which I assume is due to the Progressive Industries surge protector doing its checking. But when I use the generator there is an immediate brief beep of the microwave then it powers off for a minute or two. During this minute of two the EMS appears to be doing some sort of diagnostics andthen I get power back to the microwave (and everything else). Wondering if others experience this delay when using the generator. If not, any ideas as to what is causing it and how to remedy it?
Or maybe this is something in the generator circuit that forces the generator to warm up a bit before it can absorb load?
Facts or opinions welcomed.
Titus is offline   Reply With Quote
Old 04-18-2016, 04:56 AM   #2
toskeysam's Avatar
Townsend , Tennessee
It is part of the generator warmup routine. Not a problem.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 04-18-2016, 07:08 AM   #3
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Totally normal.
Ron_CA is offline   Reply With Quote
Old 04-18-2016, 09:06 AM   #4
Boxster1971's Avatar
Fulton , Maryland
+1 Yes it is normal.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 04-18-2016, 11:51 AM   #5
2004 25' Safari
1968 17' Caravel
Fountain Valley , California
Automatic Bus Transfer Switch (ABT)
It could be that your rig has an Automatic Bus Transfer (ABT) switch, or equivalent circuitry built in. These often provide two functions. They are normally generator-seeking, meaning if a generator is hooked up the electric loads will switch to it even if shore power is still available. Now they often include two circuitrys, 1) a time delay of approximately 45 seconds from the time a generator is hooked up and powered, until it then switches over to the generator. This gives the generator a slight warm up before being "hit" with the electric loads. 2) Some also include generator stabilization sensing, such that they don't switch until they sense the generator is stable then they switch to the generator.
WindyJim is offline   Reply With Quote
Old 04-19-2016, 04:51 AM   #6
FWIW, there's an analogous delay in our T1N Interstate when initiating either shore power or generator power. We installed our own internal surge protector and this shore-power-related delay is not related to that... there's some other component in there. You know the expression "it ain't over 'till the fat lady sings"? Well, in our Interstate, it ain't over 'till the microwave light comes on and stays on.
Intellitec EMS 73shark Sprinter and B-van Forum 11 07-08-2015 09:04 PM
Ems-hw50c cwf Electronics & Connectivity 1 03-26-2015 03:58 PM
Interstate EMS System Questions FlaBucki Sprinter and B-van Forum 2 03-22-2015 06:49 PM
To 'Time Delay' or not 'Time Delay' FordTruck Jacks, Stabilizers, Lifting and Leveling 11 05-20-2008 02:58 PM
EMS from Progressive Industries markjoandall Electrical - Systems, Generators, Batteries & Solar 0 08-02-2005 07:14 AM
