Old 07-26-2014, 01:51 PM   #29
2004 22' Interstate
Davis , California
Well there IS a plug or two above the accelerator! Not easy to unplug but we will five it a go. It would be swell to have a disconnect. Thanks again.
DavisBurns is offline   Reply With Quote
Old 07-26-2014, 05:19 PM   #30
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
IF one of the plugs is a battery disconnect, it will be a plug with only ONE wire going to it in each direction. Probably attached to the transmission hump. If you are standing on the ground outside the driver's door, it should be easy to reach the plug and pull it loose with just one hand. If the plugs you're seeing aren't like that, they're not the disconnect.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-26-2014, 05:34 PM   #31
2005 22' Interstate
Pittsburgh , Pennsylvania
The battery disconnect plug looks like this:
You have to push the red tab to release it. (The guy's hand is hiding the accelerator pedal.)
avanti is offline   Reply With Quote
Old 07-26-2014, 06:09 PM   #32
2004 22' Interstate
Davis , California
Great picture! The 2004's don't have this, at least mine doesn't. But, after a day of messing with wires, tightening and putting in a ground to the frame that included drilling a hole in the floor under a bed, the Trimetric tells us we have zero vampires-- which is the way we believe it should read. We don't know what was wrong but sometimes cleaning up makes a difference. Thanks to all who helped.
Electrical short dgmelp Lights - Interior & Exterior 5 12-04-2011 07:55 AM
Coverter & DC Electrical Load Qs rwnash Batteries, Univolts, Converters & Inverters 8 09-28-2011 06:17 PM
Electrical blowout...HELP Chris N. Electrical - Systems, Generators, Batteries & Solar 8 09-15-2011 08:39 AM
