Old 09-16-2017, 05:17 PM   #1
Austin , Arkansas
Electrical system ?? for an AI newbie
Just purchased a 2018 AI - when your van is not in use and it can be plugged into electrical outlet , is it safe to leave it plugged in? Thank you
jodie1425 is offline   Reply With Quote
Old 09-16-2017, 05:25 PM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Yes. Plug it in and leave the battery disconnect in the "on" position. All recent AI, with the Magnum charger/inverter, can be stored plugged in.
I keep my 2014.5 in covered storage with 30a service. Plugged in and refrigerator on. It is my "man cave," just like my former Airstream trailers. I often stop in after lunch to take a quick nap or watch a DVD without being disturbed. It is also my refuge when my wife's book club meets at my house.
John W. Irwin
WBCCI #9632
Old 09-16-2017, 05:40 PM   #3
FlyFishinRVr's Avatar
2017 Interstate Lounge Ext
Northern , California
I'm not sure how this translates to the '18 because I don't know if they have the same Main Disconnect switch that we have in previous model years, but the bottom line is to leave the "house" power on when you're plugged into shore power. In previous model years you know it's on because there is a red LED next to the switch. If the LED is on, house power is on. Hopefully the new '18's have something similar.
Oh, and congrats on the new Interstate!
FlyFishinRVr is offline   Reply With Quote
Old 09-17-2017, 08:59 AM   #4
Austin , Arkansas
Thank you so much for responses!! I know this won't be the last question , as we are so green to this vehicle, but so excited for the adventures to come!! Thanks again
Old 09-17-2017, 09:55 AM   #5
fairfax station , va
More internet opinions
An alternate life view. My 2014 charges just fine when plugged in and has battery disconnect activated.
The inverter/charger is one of the uses that receives power with the disconnect activated, along with the propane detector, the lounge motor, the BIM, the solar controller and maybe the tank heater. (but not the propane switch)
The Magnum senses shore power and it monitors charge status unless the battery is disconnected at the source.
Theoretically you can always leave it plugged in and the Magnum doesn't hate you enough to ruin your battery. Apparently other chargers are not so magnanimous.
One thing about activating the battery disconnect is that if your shore power is accidentally unplugged, the battery drain is slower....ask me how I know.
VAtom is offline   Reply With Quote
Old 09-17-2017, 10:51 AM   #6
Just to avoid confusing someone new to the Interstate, this is only true on models built before 2016. Starting with the '16's, the house power MUST be left on or the Magnum won't charge the batteries. This little tidbit caught a lot of dealers out as they didn't know this, and as a result they killed a lot of coach batteries (much to the annoyance of new owners with house batteries that wouldn't hold a charge ).
Old 09-17-2017, 11:57 AM   #7
Sautee , Georgia
More AI electrical diversity
This came up on another thread and I noted tha my 2017 AI Tommy Bahama charges with house batteries on or off. I tested it after reading that it would not charge with house batteries off, so I suggest the OP test his to see how his works.
busb2 is offline   Reply With Quote
Old 09-17-2017, 12:45 PM   #8
Jeepers
Jackson Center Roulette
Old 09-17-2017, 04:15 PM   #9
Even the schematic shows it's not possible to charge the batteries with the Main Disconnect off (i.e. red light is OFF). On the '16's and beyond, AS put in a second electro-mechanical switch just like the primary switch to fully disconnect the Magnum from the batteries. This replaces the old SB-164 solenoid.
I just checked the '17 Tommy B owner's manual and the schematic on pg 9-17 is identical to the other '17's. You'll see two switches, one labeled House Main Disc, the other is Inverter Main Disc. Both have the same trigger (Master Disc Sw), so when that switch is off (i.e. red LED OFF), both switches open and completely isolate the inverter/charger from the batteries. The only way yours could be charging with the Main Disc switch off is if your Inverter Main Disc switch isn't working (manually disabled or something electrically is wrong).
Old 09-17-2017, 04:31 PM   #10
Sautee , Georgia
I have owned three AI's and one thing is consistent for all three. The owners manuals seem to contain inconsistencies and variances with how the units were actually built. My current AI was obviously not wired as referenced. Also, there seems to be differences in how the fusion unit was wired in various same year units as noted in the long chassis battery discussion in another thread. My unit was on the dealers lot for at least three months and I tested the house and chassis batteries before delivery and they were perfect. ????
Old 09-17-2017, 06:43 PM   #11
Good to know your dealer maintained your batteries properly. Mine did as well. Sadly, many did not and there were lots of frustrated new owners posting on the forums.
I know that some Fusions were incorrectly wired. Mine is one of them. The schematic shows the power for it should come from the house supply, not the chassis, yet mine pulls from the chassis. I'll fix it this winter.
As far as the Inverter Main Disc switch is concerned, if you can charge your 2016 or newer coach with the Main Disc wall switch off (red LED OFF), you've got a problem with your Inverter Main Disc switch, which means your Magnum is pulling from your house batteries any time the coach is sitting unplugged.
Old 09-20-2017, 08:21 AM   #12
2015 Interstate Ext. Coach
Newburgh , Indiana
Sometime in late 2015/Early 2016 Airstream made a change to fully disconnect the Magnum as part of the Master Disconnect Switch. In 2015 AI and earlier years, disconnecting the Battery Switch (at the sliding door) still left a load of about 800 milliamps on the house batteries as the Magnum inverter shunt remained connected. That load also included the CO and propane detectors. The problem with that approach was that you HAD to leave the AI connected to shore power, or your batteries would deplete entirely in about two weeks, even with the disconnect switch off. Sometime in late 2015, Airstream modified the circuitry to disconnect the inverter entirely when the battery switch was off, and retrofits were provided for earlier models that amounted to a solenoid that disconnected the inverter shunt as the BD switch was toggled. I found the retrofit not altogether satisfactory, as the solenoid got quite hot and also used 200-300 milliamps to stay closed when the house was "on". I replaced the solenoid with a heavy duty "battery disconnect" style SPST switch that allows me to disconnect the inverter load for long term storage as I didn't have access to shore power in my storage facility. If you own a 2015 or earlier and have shore power at your storage facility and keep your rig plugged in (with or without the battery switch on), you don't need to worry about it. With mods done 2016 and beyond, the switch must be on for shore power to charge the house batteries.
stast01 is offline   Reply With Quote
Old 09-20-2017, 09:26 AM   #13
Another battery question
Thanks for the explanation of the evolution.
I added a high amp disconnect to the battery bank as well and am very pleased with the result. I lose about .01 volt per day or less, so that means it might take 60 days to go from 12.9v (my full charge) to 12.3V (my 50% charge) That's a lot of cushion for me.
All of the battery disconnects (like BlueSea) are for the positive battery cable but all of the experts say to disconnect the ground for storage.
Is this important, or is the + disconnect satisfactory.
Old 09-21-2017, 09:39 AM   #14
Newburgh , Indiana
It shouldn't matter--as long as one side of the battery bank is disconnected, the batteries are isolated from any load. My SPST switch only disconnects the inverter shunt. There is still a slight load on the batteries for the propane detector, but I have left my AI stored for 4-6 weeks with no appreciable drain on the batteries.
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
Newbie needs help with electrical system jacqueg Batteries, Univolts, Converters & Inverters 7 11-29-2007 04:00 PM
electrical system 67 tradewind boardsander Electrical - Systems, Generators, Batteries & Solar 3 10-14-2002 04:32 PM
Problem with electrical system (1965 safari) rslaymaker Electrical - Systems, Generators, Batteries & Solar 4 06-13-2002 05:49 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 07:39 PM
