Old 12-09-2018, 08:28 PM   #1
TX-Newbie's Avatar
2018 Interstate Lounge Ext
AUSTIN , TX
Dumping in and around Austin
Where do y'all go?
TX-Newbie is offline   Reply With Quote
Old 12-09-2018, 08:40 PM   #2
Contributing Member
Pahaska's Avatar
2014 Interstate Ext. Coach
Austin (Hays County) , Texas
Depends on where you start from and what you want to dump.
I live in Hays county and I can take a load of non-garbage to the county yard, a few miles from my house. They charge me depending on the size of the load. It has always been pretty reasonable.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 12-09-2018, 08:59 PM   #3
1988 29' Excella
Austin , TX
I’m remodeling an ‘88 Excella which means ripping out most of the interior. I hauled most of the trash to the Williamson county landfill. I think it was $40 a
load.
JohnnyAustin is offline   Reply With Quote
Old 12-09-2018, 09:15 PM   #4
TX-Newbie's Avatar
AUSTIN , TX
Sorry all. I should have been more clear. I meant dumping my tanks.
Old 12-09-2018, 09:36 PM   #5
Contributing Member
Pahaska's Avatar
I pull up in my driveway and dump into a wheeled portable tank. I empty it into my house sewer cleanout. I can handle about 10 gallons per trip and I can park the AI about 40' from the cleanout. Usually takes about 2 trips.
John W. Irwin
WBCCI #9632
Old 12-09-2018, 11:02 PM   #6
Austin , Arkansas
Emma Long Park off city park road
jodie1425 is offline   Reply With Quote
Old 12-09-2018, 11:54 PM   #7
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
If you have a state park card, you could use the dump station at McKinney Falls SP for free (I generally keep a current state parks card because we camp several times a year in state parks and it pays for itself and then a bit, for us.)
If you're in a house, since your Interstate has a macerator pump-out you might be able to get close enough to your house's sewer cleanout to dump into it directly.
The Walnut Creek wastewater treatment plant has a dump station (might be kinda nasty, honeywagons dump there)
The front side of the Flying J on I35 in Jarrell has a dump at the RV fuel pumps... it's not actually a Flying J, it's a Chevron, only the big diesel station in the back is Flying J... at least in the past it was free to use, didn't require a code like lots of Pilot/Flying Js.
Most of the RV parks around will let you dump for a fee even if you're not staying there. Some are reasonable, some are ridiculous ($20 just to dump tanks)
— David
Old 12-10-2018, 12:11 AM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If you have a “clean out” nearby your home run the dump hose there.
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-10-2018, 07:55 AM   #9
2001 30' Classic S/O
Marshall Ford , Texas
La Hacienda on Hudson Bend charges a small fee. Most RV parks are willing to take your money.
John
TexAirS is offline   Reply With Quote
Old 12-11-2018, 07:58 PM   #10
TX-Newbie's Avatar
AUSTIN , TX
Thanks all. Much appreciated.
Old 12-11-2018, 09:41 PM   #11
2017 Interstate Lounge Ext
Plano , Texas
I use the clean out at the house. Very convenient.
Tobbun is online now   Reply With Quote
First time dumping tanks and only gray works NotStock Sprinter and B-van Forum 7 09-28-2016 05:25 PM
Longer term boondocking and dumping rpmd On The Road... 27 12-08-2014 08:22 PM
Need an inspector around San Antonio/Austin paisleya Member Introductions 0 06-11-2014 12:46 PM
Optimal position for black and gray tank when dumping Woosch Waste Systems, Tanks & Totes 2 10-26-2012 09:23 PM
Help!! Austin-to-LA-to-Austin Astro On The Road... 13 04-05-2006 11:29 PM
