Old 07-10-2016, 08:00 PM   #15
1979 23' Safari
Wayland , New York
AS needs to figure out a way to work in a way they can incorporate the square 4" bumper tube that you find on SOBs into their bumped. They're great for storing the slinky in.
I just finished brainstorming how to retrofit one in my 79 safari bumper.
Old 07-10-2016, 08:30 PM   #16
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A bit of Airstream Interstate historyÖ
Interstates only came with slinkies in the T1N models. When the switch was made to the NCV3 Sprinter-based Interstates, Airstream also switched to macerator pumps discharging through a hose on a built-in reel. This was one of the first in a series of many modifications over the years that added complexity and price without adding much in the way of utility.
So Airstream doesn't really need to figure out a way to incorporate bumper storage of slinkies in Interstates that haven't even used slinkies in nearly ten years. And for owners of older T1N Interstates, I think the price of an aftermarket storage bumper that doesn'tó and can'tó match the lines of the van would be more than the problem is worth. There are plenty of ways to provide concealed slinky storage underneath, if one is willing to get creative on placement.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-17-2016, 07:09 AM   #17
Project completed! We discovered an easy way to extend the original Valterra carrier beyond Airstream's mounting plate at which the smaller version used to stop. This minimized the work, reduced the need to purchase new hardware, and prevented new holes from having to be drilled in the chassis. Details in the blog post. Sorry about the crummy pic. Sun angle is still very low this morning
VALTERRA DUMP HOSE CARRIER MODIFICATION FOR THE AIRSTREAM INTERSTATE
Old 07-17-2016, 07:17 AM   #18
Mont Vernon , New Hampshire
Thanks for the great write up! We need to do the same and this is very helpful!
What length hose are you able to carry now?
Katy
bugsbunny is offline   Reply With Quote
Old 07-17-2016, 09:37 AM   #19
Katy
Now there's a good question. The hose I show in the photos... I believe that was our previous owner's home-made solution to the tiny on-board hose. As such, I don't know that it's a standard off-the-shelf length (and there's no brand name that I can find). I CAN tell you that it will lie on the ground at 11 feet without contracting under its own power, and I can extend it to 15 feet without feeling like I am over-stretching to the point where it wants to snap back on me. And it compresses down to about 36 inches.
Old 07-17-2016, 01:41 PM   #20
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Since flared end fits inside the existing tube, does the slinky want to hang up on it or did you have to bevel the end to prevent this?
Old 07-17-2016, 03:01 PM   #21
Good catch! Yes, I beveled the ends of both the pipe and the drain plug. I'm not sure how much it helps but I did know that I wouldn't be able to bevel the edge after assembly.
LB_3 is offline   Reply With Quote
Old 07-18-2016, 05:12 AM   #22
Post-beveling, I yanked it in and out several times without snags. But if one were to occur, a bit of jiggle and twist would likely resolve it. Whatever lip or overlap area might be remaining is very small.
Old 07-20-2016, 02:30 PM   #23
RossFam05BH's Avatar
2005 30' Safari
Pfafftown , North Carolina
Hey all,
Here is our solution to the short stock sewer tube holder. We bought a 4.5" diameter by 6 ft. long aluminum tube (http://www.speedymetals.com/), end cap, and hinged door (Http://www.Americanvan.com/). We then attached the completed tube onto the street side running board with hose clamp brackets. The assembly holds 2 10-foot long stinky slinkies.
Paul
2005 30' Bunkhouse "Nedapedalua"
2002 Ford Excursion 7.3L Diesel 2WD
WBCCI #5182
AIR # 6050
RossFam05BH is offline   Reply With Quote
Old 07-23-2016, 08:15 AM   #24
Here's what our hose looks like when fully extended, the hose that is now accommodated by the modified carrier. Some dump stations and clean-outs are not located in convenient places. There's no way I could get by with a hose shorter than this. Even WITH this, I've had to throw the shore line on top of it to weigh it down and prevent it from snapping back once the wastewater load is released.
Old 07-23-2016, 04:28 PM   #25
Oh incidentally, ^^ that pic that I posted above... that's also why I always carry a collapsible bucket. Some operators don't want to put their water hoses next to their dump stations, because they know full well that some fine RV owner is going to bury the water hose inside their stinky slinky to wash it out. And then the next poor fool is going to come through and fill their fresh water tank with the same hose. Eeeewwww!!! So this operator had installed their hose far enough away to prevent this. Which means I had to run with many buckets of water, because I was triple-rinsing both of the tanks as well as the hose.
Question for owners of Interstates with VB-Air Suspension Boxster1971 Sprinter and B-van Forum 13 06-15-2016 07:52 PM
Retrofitting solar in a T1N Interstate InterBlog Sprinter and B-van Forum 45 02-22-2016 12:56 PM
Overhead Shelf for T1N - Airstream Interstate 2005 lizt1011 Sprinter and B-van Forum 14 02-10-2016 04:36 PM
Urgent question about dump hose?!?! Gillpine Airstream Lifestyle 30 10-23-2015 02:36 PM
Interstates VS secondary roads .... AnnieD On The Road... 14 12-08-2009 02:49 PM
