Old 06-13-2018, 09:09 AM   #1
Mansderm161's Avatar
NORTH MYRTLE BEACH , South Carolina
Dump and flush question
On the interstate, after you dump black tank, then grey tank, do you close both of those valves to hook up hose and do flush? Does the dumping hose valve at the end of the hose on the reel stay open? The sticker where you hook up hose says a valve should be open, but it is not specific. Thanks
Mansderm161 is offline   Reply With Quote
Old 06-13-2018, 10:48 AM   #2
2012 Avenue Coach
Corpus Christi , Texas
If you want to use the San-T-Flush feature, you will be adding water to the black tank with a garden hose. You must have the black valve open and gray valve closed (and yes, your hose valve open). Be prepared to stand by the macerator switch to start the pump periodically during the flush. You'll need to empty a volume of water equivalent to what you are adding with the garden hose (as it fills). You don't want to create an overflow.
I would suggest using the San-T-Flush feature sparingly if you are not having any other problem. It's a nice feature, just not necessary every time.
Your manual should explain the process. Good luck.
rowiebowie is offline   Reply With Quote
Once and for all--need to blow out City Inlet and Black Flush? pcskier Winterizing, Storage, Carports & Covers 27 12-01-2016 12:38 AM
Dump valve solution and rib question layback 1965 - 1969 Globetrotter 0 08-30-2016 11:21 AM
No-Fuss Flush failure - and a question sallye Plumbing - Systems & Fixtures 13 08-28-2016 10:53 PM
Black water flush question???? mwilliamsmd Plumbing - Systems & Fixtures 27 06-27-2015 01:53 PM
Tank flush question cosmotini Waste Systems, Tanks & Totes 1 04-08-2004 07:32 PM
