Old 04-29-2015, 07:17 PM   #1
Glamper1's Avatar
Dually Air Valve Extender
Big O orders the part
They worked on and ruined wrong valve and left the other one as is
and shows me the air hose fitting that I can never find at gas stations to reach the one
I came to Big O for.
What a mess.
I told them I'll come back Friday so they can undo this job.
Does this look right to anybody? Especially how the clammed down on finished polished aluminum?Click image for larger version
Name:	ImageUploadedByAirstream Forums1430356587.384757.jpg
Glamper1 is offline   Reply With Quote
Old 04-29-2015, 07:47 PM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Looks like a mess to me.
You should get these:
DL1SPAL Chrome Dually Valve Kit
They look like this installed on my Interstate with TPMS sensors installed.
Good Luck,
- - Mike
Name:	Rear Alcoa with TPMS Sensors.jpg
Old 04-29-2015, 08:17 PM   #3
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
That IS a mess. And look how that bolt is in there trying to support the valve! I hope they didn't drill a hole in the wheel to take in that bolt.
Didn't anyone warn you never to use BigO Tires? They have a very bad reputation around here.
Old 04-29-2015, 08:50 PM   #4
Glamper1's Avatar
Thanks guys
I was nice but inside I freaked out.
Hopefully no damage to rims otherwise I will insist that they replace them.
Such a hack job
and...on wrong valves.
Unbelievable.
Old 04-29-2015, 10:38 PM   #5
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
That is Youuugly.
I haven't gone to Big O since around 1997 when they effed up a brake job on my truck. They ended up refunding me more than the cost of the work.
Ron_CA is offline   Reply With Quote
Old 04-30-2015, 04:57 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I used these on my outer duals:
Amazon.com: Wheel Masters 8029180 180 Degree Valve Extender - Pack of 2: Automotive
I used these on my inner duals:
Amazon.com: Wheel Masters 80293 3" Straight Valve Extender - Pack of 2: Automotive
And I used this on my spare:
http://www.amazon.com/Wheel-Masters-...ords=spare+air
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-30-2015, 09:58 AM   #7
Glamper1's Avatar
Thank you protagonist !
That's exactly what I assumed
I'd get.
Old 04-30-2015, 09:59 AM   #8
Glamper1's Avatar
Easy to put on yourself?
Old 04-30-2015, 01:33 PM   #9
Easy enough if you do it with the wheels off the van. Harder with the wheels on the van unless you have really small hands with very nimble fingers.
The one for the spare requires that you drill one hole to mount the end of the extension on the rear bumper or hitch receiver. But being able to check the pressure in the spare without crawling underneath is worth it.
WBCCI #1105
TAC LA-4
Old 05-01-2015, 09:06 AM   #10
1977 31' Sovereign
Lynnwood , Washington
Next time, go to a truck tire shop. There's a difference. They've got the right equipment. They're experienced with dualies.
Just because they say, "We work on all makes and models," doesn't mean they can do the job right the first time.
Tom
TomKirk is offline   Reply With Quote
Old 05-01-2015, 12:48 PM   #11
Newbie
joemikeb's Avatar
Fort Worth , Texas
Good Luck,
- - Mike
These are the ones I put on my AI. The valve stems were installed at the local Discount Tire with my gentle supervision. They did a nice job at a very reasonable price. The TPMS I installed myself.
Make errors otherwise the Great Spirit realizes
you have finished your purpose on earth.
Navajo saying
joemikeb is offline   Reply With Quote
Old 05-01-2015, 03:12 PM   #12
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Because you have to remove the valve cores before putting on the extensions?
Old 05-01-2015, 09:37 PM   #13
Rockwell , North Carolina
The inside rear wheels use a rubber valve stem with a plastic extension that is difficult to get to. I put a metal extension on that stem without securing it to the wheel. Both of those plastic extensions failed costing me two damaged flat tires. I bought the new extensions from a place that deals mostly with semi's. They always use metal valve stems for their extra rigidity. When I installed the TPMS system, I ended up with metal valve stems on the inner wheels. You can see the extensions I used in this thread:
http://www.airforums.com/forums/f240...te-131097.html
jerhofer is offline   Reply With Quote
Old 05-02-2015, 08:19 AM   #14
Newbie
joemikeb's Avatar
Fort Worth , Texas
Metal vs rubber or plastic extended valve stems have been discussed several times around here. The vast consensus is never use plastic or rubber valve stem extensions especially if you are going to use pass through external TPMS sensors. The slight added weight of the sensor will cause the plastic and rubber extension to vibrate excessively and even worse break. When they break the first corollary to Murphy's Law immediately comes into effect. Remember too the inner rear wheels are steel and the outer ones aluminum, so you have to have metal valve stem extensions that are specific for the different metals. The Dl1spal]DL1SPAL Chrome Dually Valve Kit set has the right materials for both the inner and outer wheels.
From the posts on these forums, it also appears there is a preference for pass through external TPMS sensors. You do not have to dismount the tires to install them or change their batteries and the internally mounted sensors often have their signals blocked by the wheel itself. I even put external TPMS sensors on the wheels of my tow dolly and the rear wheels of the toad itself. I did have to use the long range antenna on the readout to reach the rear wheels on the toad.
Navajo saying
Anyone using a hitch extender? adwriter73 Hitches, Couplers & Balls 25 11-26-2012 01:42 PM
Dually versus non-dually ShikariJones Tow Vehicles 29 08-27-2008 08:55 PM
Best 1-Ton Dually on the market and why? Streamer1 Tow Vehicles 25 10-23-2006 08:16 AM
MPG of F350 Diesel Dually??? joossens Tow Vehicles 13 06-13-2004 12:55 PM
