06-24-2013, 04:09 PM
2010 22' Interstate
Anchorage
, Alaska
DRLs on 2008 Sprinter
Has anyone tried the procedure to disable the DRLs on a '08 Sprinter? MB calls this "Constant Headlamp Mode" and there is a procedure in the Owners Manual that will let you disable this feature. I would like to gain control of my lights so that I can make sure they are off when pulling into a camping spot late at night. There is also the backup alarm to deal with for the same scenario. Anyone have any bright ideas on that one. An OFF switch that timed out after say 2 minutes and reverted to ON would be ideal. Don't know if such a thing exists.
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
06-24-2013, 04:18 PM
Naples
I had both on my '11 Sprinter 2500. I was able to disable the DRLs from the dash by toggling thru the settings and following the instructions in the manual (it's been 2-1/2 years and I don't recall the exact sequence).
As for the back-up alarm, I simply located the beeper device under the van and disconnected it. It can easily be re-connected at any time, as can the DRLs.
lewster
06-24-2013, 04:39 PM
2010 22' Interstate
Anchorage
, Alaska
Re. DRLs; The procedure is in my manual also but I can't try it as my Interstate and I are not in the same place.
Re. backup alarm; if the alarm was provided by MB (on mine, it apparently was as it shows up as it shows up as SA Code JW0-Backup Warning System on my Data Card), the Owner's Manual shows a way to turn down the volume. From the manual:
"Reducing the volume of the warning signal Select reverse gear twice in quick succession.
The warning signal sounds more quietly."
Anyone tried this?
- wayne
AIR #44779
TAC AK-1 !!
06-24-2013, 05:43 PM
Mantua
, Ohio
On my 06 sprinter, I only had to pull a fuse under the driver's seat. Cannot remember which one. Yours may be dif. Try the sprinter forum search, there was quite a discussion about this issue years ago. Sprinter.com. Jim
06-24-2013, 05:49 PM
2010 22' Interstate
Anchorage
, Alaska
Jim, are you talking about the DRLs or the backup alarm?
Wayne
- wayne
AIR #44779
TAC AK-1 !!
06-24-2013, 05:51 PM
Mantua
, Ohio
Running lights, sorry, Jim.
06-24-2013, 07:03 PM
Naples
Everything changed with the '07 model year...........
lewster
06-24-2013, 08:11 PM
Sebastopol
Zigzag, would you take a look and post which fuse? Much appreciated.
06-25-2013, 06:36 AM
Mantua
, Ohio
My Interstate is long gone. Lewis says all changed in a later year. He is the expert and I would trust him. Like I said, go to Sprinter forum.com for info. Jim
07-06-2013, 05:19 AM
2009 Interstate
Bethesda
, Maryland
I tried the procedure for the backup alarm but no joy. The DRL's were modified using Starscan at a ex-Dodge dealer now independent repair shop. They had a flat rate of $50 for any electronic diagnosis.
2009 Airstream Interstate
07-06-2013, 08:11 AM
2010 22' Interstate
Anchorage
, Alaska
Hi Ben,
By "modified" I assume you mean disabled? i.e. you have no headlights on unless you turn them on manually?
Wayne
- wayne
AIR #44779
TAC AK-1 !!
07-07-2013, 04:17 AM
2009 Interstate
Bethesda
, Maryland
Sorry; correct I had the DRL's disabled. It was buried in the menu in Starscan but it was there. Since mine is a 2008 Freightliner it should be the same.
07-08-2013, 05:59 PM
2014 Interstate Ext. Coach
Boca Raton
Mine is also on a 2008 chassis and to turn off DRL daytime running lights you can just scroll through menu on dash computer to turn off or back on.
07-08-2013, 06:09 PM
2010 22' Interstate
Anchorage
, Alaska
Do you have buttons on the stealing wheel?
- wayne
AIR #44779
TAC AK-1 !!
07-08-2013, 06:11 PM
2010 22' Interstate
Anchorage
, Alaska
Steering wheel!
- wayne
AIR #44779
TAC AK-1 !!
07-08-2013, 06:21 PM
Boca Raton
No
Somebody 'stole' my steering wheel
Yes we have buttons....
