Old 12-15-2014, 05:46 AM   #1
2014 Interstate Ext. Coach
Bound Brook , New Jersey
Driving with Propane furnace or Generator
Hi folks,
I'm coming up on 1 month of ownership (2014.5 Lounge EXT)and have a question for those more experienced than I am. One week from today I'm driving some family members to the airport and due to the number (5) I'm going to use the Interstate. My question is this, is it ok to drive with the propane on and the furnace running? or for that matter, the generator in the summer to run the A/C? It's going to be in the low thirties when I drive them, so I wanted know whether I should get up 2 hours earlier, to heat the coach and then shut off the propane while driving to the airport and just use the chassis heat to try and maintain.
long winded question I know, but thanks in advance for your response.
SCARLET BISON
Silver 2014.5 Interstate EXT
scarletbison is offline   Reply With Quote
Old 12-15-2014, 05:52 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
It most certainly IS okay to drive with the furnace on. I did my Interstate's test drive in December 2011, and it was cold in Gulfport that day. The furnace was already on when I climbed in, and we left it on throughout the test drive. No problems at all.
I've never driven with the generator on, which you need in order to run the rooftop AC while driving. I'll leave that part of the answer to other Interstate owners.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-15-2014, 06:15 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I have done both with small motor homes in the past, and I run the furnace on my TT when traveling in very cold weather.
Current MoHo that I have access to has a water exchanger as part of the furnace system... them big Cat diesels put out some serious heat.
Aaron
WBCCI #XXXX AIR #2495
Old 12-15-2014, 06:38 AM   #4
BikerBill
Poconos of Pa , Pennsylvania
Asking the question of using propane while driving is like asking which is better: Ford or Chevy. And the unequivocal answer is YES.
I and many others have driven with propane on and using appliances i.e.: generator. You have to be concerned with the possibility for some appliances that the pilot may blow out. No pilot on penny though.
Bikerbill is offline   Reply With Quote
Old 12-15-2014, 07:49 AM   #5
Mjgman's Avatar
2013 Interstate Coach
Bradenton , Florida
Driven many times with the generator on with the AC cranked up to max.. Also used the furnace while driving many times.. Crank up all your systems and roll on down the road my friend..
Mjgman is offline   Reply With Quote
Old 12-15-2014, 09:31 AM   #6
Newbie
joemikeb's Avatar
Fort Worth , Texas
I have driven several hundred miles in my 2013 AI on the Interstate highways in temperatures hovering between the upper 20s and lower 30s and had to dial down the temp on the Sprinter heater because it was getting uncomfortably warm inside and that was without the benefit of the furnace. After all Germany can be a very cold country and the AI is pretty well insulated. I have also driven several hundred miles across the Southwest in 100+ temperatures with the generator running so I could run the A/C to keep the interior temperatures tolerable with no problems. Firing up the furnace to pre-warm the interior before heading for the airport is a good idea, but it may be overkill once the engine heats up to operating temperatures.
CAUTION: Be aware in your planned airport journey the ride in the back of the AI is notoriously not good and can easily launch rear seat passengers into low earth orbit. (One commentator claimed his passengers reached geo-synchronous orbit.) The ride in the driver, co-driver, and passenger seats is great, but the ride in the back is a reasonable facsimile of a thrill ride at the carnival. I found that out the hard way taking a VIP to the airport. She was nice about it, but the next time took a taxi.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Old 12-15-2014, 10:42 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Our friends with a 1995 Tiffin Allegro Bus drive around with the generator on running the roof air all the time. The only consideration is to make sure the window above the generator is closed to keep the generator's exhaust from entering the vehicle.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 12-15-2014, 02:00 PM   #8
1974 27' Overlander
Fairbanks , Alaska
Furance while driving
My experience is that the furnace on my 1974 Airstream does not function properly while driving or with the exhaust facing the wind while parked. My slide-in camper furnace works just fine -- so I imagine any modern camper whould have no problem.
Alaskahistor is offline   Reply With Quote
Old 12-15-2014, 03:13 PM   #9
Rockwell , North Carolina
Over Thanksgiving we drove from NC to Indiana with my wife, our son, his wife, our grandson and two dogs. It was cold (high 20's and low 30's) but the rear passengers opened the side windows to cool it down as the heat buildup from the truck heater was more than sufficient to heat it up. Part of that heat probably came through the windows as it was sunny. I dialed back the truck heat considerably. We did not use the furnace at all. We did run the generator as my grandson brought along his Playstation 4 which is a power hog. On the plus side, it kept him entertained.
Ditto on the ride thing as well. While my son's family did not complain, my wife sat back there for one stint and did not like it. It is much more comfortable up front.
jerhofer is offline   Reply With Quote
Old 12-15-2014, 03:15 PM   #10
CAUTION:The ride in the driver, co-driver, and passenger seats is great, but the ride in the back is a reasonable facsimile of a thrill ride at the carnival.
How about the side-facing seat directly over the wheelwell? It should be better than the sofa all the way to the rear in that regard.
And an impertinent question… were the people launched into orbit not wearing seat belts?
WBCCI #1105
TAC LA-4
Old 12-15-2014, 05:59 PM   #11
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
The alternator couldn't keep up w/ the PS 4? If it's consuming that kind of power, hope it's sitting on something that won't melt cuz it'll definitely be hot.
Old 12-15-2014, 07:19 PM   #12
That trip was when I discovered the alternator was not charging the house batteries.
http://www.airforums.com/forums/f240...es-128968.html
Old 12-15-2014, 09:19 PM   #13
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
Same with my previous AS, a '71 18ft Caravel. Those older appliances with pilot lights aren't reliable when the trailer is moving. We couldn't use the furnace or the fridge when moving. We'd freeze blue ice in the freezer and put it in the fridge when we hit the road.
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 12-16-2014, 12:49 PM   #14
Boxster1971's Avatar
Fulton , Maryland
There is no pilot light on these newer units. They have electronic spark ignition of furnace.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 08:56 AM
Newbie Advice on Propane and Propane Accessories Socal1 LP Gas, Piping, Tanks & Regulators 1 07-15-2013 12:36 PM
Furnace is driving me crazy tinlizzie2 Furnaces, Heaters, Fireplaces & Air Conditioning 6 12-10-2009 03:54 PM
Propane Generator Help Please Snadi LP Gas, Piping, Tanks & Regulators 11 09-25-2005 05:03 PM
Furnace while driving Chaplain Kent General Motorhome Topics 17 12-27-2004 02:58 PM
