08-30-2016, 03:38 PM
2015 Interstate Ext. Coach
Chicago
dripping hose at bib
I've searched, but can't find any threads or posts about this. At risk of this being one of the stupidest discussions ever: I seem to have this chronic problem of excessive dripping where my water hose connects to the bib. This is true across: 1) campgrounds; 2) with or without water filter; 3) different hoses; 4) 2 or 3 different pressure regulators; 5) regardless of how tight I try to screw my hose connector onto the faucet
About the ONLY thing that reduces the drip is to NOT use a pressure regulator, which I don't think is a good solution.
Is this just a chronic problem experienced by RVers? am I doing something wrong? Do others experience this?
08-30-2016, 04:28 PM
2007 22' International CCD
Corona
Try changing out the hose washer for a softer one. Some tend to be hard and won't seal quite right. Check the condition of the hose bib. If the end is nicked or damaged it may leak no matter what you do.
08-30-2016, 04:54 PM
Auburn
, Georgia
The manual says it has a built in regulator and not to use an additional external one.
08-30-2016, 05:54 PM
Corona
In some situations, like extreme high campground water pressure, an external regulator at the campground his bib is a good way to keep your hose from blowing out.
08-30-2016, 06:03 PM
Loretto
, Ontario
Take out the flat washer and replace with a O ring. You can get them at Ace
08-30-2016, 06:41 PM
2019 27' Globetrotter
Missouri Valley
, Iowa
Do you have the regulator connected right on the trailer? If so, that may cause strain on the fitting. Put the regulator on the c/g faucet or hydrant. I do it this way to keep excessive pressure off of the water hose, as rmkrum says. They do make metal ell connectors to go on the city water hook-up which will give you less strain on the city water connection as well.
Dan
08-30-2016, 07:14 PM
1979 23' Safari
Wayland
, New York
As mentioned replace the washer in the hose connection. Might try stacking 2 of them in there. I just stayed at a CG where the shape of the bib prevented the hose from screwing all the way up tight. The lip of the hose fitting would hit the spigot body before seating. I had to stack 2 washers in there, worked like a charm.
08-30-2016, 08:01 PM
Chicago
Thx. I'll try the washer suggestions
08-31-2016, 11:54 AM
1977 31' Sovereign
Lynnwood
Having a good assortment of garden hose washers in your tool kit is essential.
Tom
08-31-2016, 12:31 PM
Pearland
Marks71 - I had the same issue and got a new pressure regulator, one that allows a little more flow. I have a small pressure gauge on a "Y" that I test the water pressure with before I hook up. If the pressure is between 45 and 55 I don't use the regulator, it slows down the flow too much I also don't leave the "Y" in line, it restricts flow also. Over time the crimped on hose connectors will begin to leak. I've replaced mine with appropriate brass water hose fittings with hose clamps and have eliminated all the leaks and drips. "O" rings are a good idea too if it still drips.
08-31-2016, 01:04 PM
2014 25' FB Flying Cloud
Mattituck
, New York
There are some good suggestion here. I tried them in attempt to stop a drip. Further investigation fueled by frustration I found hat there was a tiny pin hole in the threaded portion (male) of my almost new supply hose. So the leak was in the hose fitting itself not in the connection.
08-31-2016, 01:17 PM
TinCan
2016 30' Classic
Apache Junction
I seem to have the same issues. I usually need to use a pair of pliers or chanellocks to lightly snub up the connection. Changing washers also seems to help.
TinCan
08-31-2016, 02:13 PM
2015 25' Flying Cloud
GILBERT
I had the same problem and found out that the built in regulator was bad, when I took to the AS shop they told me that this is one thing that goes bad a lot. When you hook your hose to your AS, make sure that you use a 90' elbow on your hose.
This is a $40 part.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
08-31-2016, 03:16 PM
2011 Interstate Coach
Overland Park
, Kansas
This is a $40 part.
This one is $3.77 at Amazon. But then it's not ninety feet.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
08-31-2016, 07:24 PM
Chicago
funny
09-01-2016, 05:50 AM
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
My manual says nothing about NOT using an additional regulator, and I use a Valtera rated at 50-55 PSI at the bib to protect the hose.
09-01-2016, 03:45 PM
Auburn
, Georgia
That is in the 2015 "Interstate" owners manual. It said it could reduce pressure and flow to the faucets. I guess it couldn't hurt to protect the hose with the extra regulator at the park faucet as long as it didn't cause low water flow inside.
09-02-2016, 01:59 AM
Corona
If you use a quality adjustable regulator with a gauge on it, few issues.
I had a simple in-line one. It dropped pressure badly at high flow rates and kept my tankless water heater from working properly when wife took a shower one time.
It's gone..and the new one works to protect my hose. Wife is now happy. Priceless.
09-02-2016, 10:50 PM
GILBERT
In Lake Tahoe at the RV camp there pressure was 85 lb and blew out our fresh water hose in the matter of a few minutes, I now check the water pressure before I hook up anything at all parks, a simple water pressure gauge will save you a lot of problems.
09-02-2016, 11:42 PM
Corona
I've seen it both ways. Once in Texas the park had a sign warning against cheap regulators because their pressure was chronically low.
They had pictures of the typical inline cheap regulator I got rid of. 😀
