Old 08-27-2010, 11:22 PM   #1
2009 22' Interstate
Poulsbo , Washington
Draining Tanks
We purchased our new 2009 interstate at the beginning of 2010 and are still learning about the various systems. First, my drain hose has several pinhole leaks already. This is hard to understand, unless there is something sharp on the reel that is puncturing the hose. Has anyone else experienced this problem? Also, I encountered a problem when I tried to drain the black tank today. The rocker switch to open the drain valve doesn't activate the valve, so I can't drain my tank (yikes!); also, the "open" light on switch does not illuminate.
windblade is offline   Reply With Quote
Old 08-29-2010, 07:04 AM   #2
ben322's Avatar
2009 Interstate
Bethesda , Maryland
On some of the Interstate models, there were screws that were abrading the reel hose. I would check the fuse for the drain valve but you'll need to see a Airstream dealer to have the reel hose replaced under warranty and they'll check for any interference.
2009 Airstream Interstate
ben322 is offline   Reply With Quote
Old 08-29-2010, 07:25 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
"Slinky" hoses are notorious for developing pin hole leaks. We had several go that way. I think that small abrasive material on the ground (rocks, sticks, etc.) can cause these holes. We switched to the Sewer Solution about three years ago and have never gone back to the 'stinky slinky'.
As far as your black tank drain valve being stuck. I didn't even know that they had such a thing as an electrically-actuated drain valve. As when any electrical function is not responding, check the appropriate fuse. This function is most likely 12 volt DC. Check the automotive type fuses in your converter box.
Brian
SuEllyn & Brian McCabe
Old 08-29-2010, 07:58 PM   #4
ben322's Avatar
2009 Interstate
Bethesda , Maryland
The AS Interstate built on the NCV3 Sprinter chassis has a built-in macerator with a power retractable reel so it winds up like a garden hose and is of similar size. They are also equipped with electricly operated tank valves with "open" indicator light. Ben
Old 05-09-2011, 11:26 AM   #5
solar-guy's Avatar
2009 22' Interstate
Covington , Louisiana
Unhappy I'm guessing I know why your black water drain valve isn't working.....
I had the same problem with my black water drain valve on my 2008 Interstate yesterday and found that the valve was installed touching the engine exhaust pipe, so the valve is now melted to the exhaust pipe and does not work (see post on this subject). My wife is going to call Airstream today and see if we can get any help via the warranty.
solar-guy is offline   Reply With Quote
Old 05-09-2011, 11:28 AM   #6
solar-guy's Avatar
2009 22' Interstate
As a further note I forgot to mention that my waste hose also has pinhole leaks I discovered while dumping the tanks yesterday....yuck!
Old 07-02-2012, 05:21 PM   #7
rv40's Avatar
Dallas , Texas
We have exact same problems. Black tank won't open, hose has small leaks and lights don't work on grey and black tank switches. My question... Is there a way to manually open the black tank valve?
rv40 is offline   Reply With Quote
Old 07-02-2012, 06:37 PM   #8
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Another way pin holes can delvelop in 3" drain hoses is birds. Yup...in some places—noteably, the Grand Canyon campgrounds — crows have been known to peck at drain hoses...so if you are somewhere that these pesky critters are making havoc, you might want to put your hose away between dump sessions.
TB & Greg and Abbey Schnauzer
#3954
Old 07-02-2012, 08:38 PM   #9
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
From my owners manual:
"In case of electric system failure, there is a manual override on the electric dump valves located on each side of the valve. Use a flat head srew driver or an allen wrench to turn the override screw clockwise or counter clockwise according to side you access to open and close the valve. The direction is labeled on the valve."
Keep in mind that mine is a MY2010 Interstate.
Hope this helps,
Wayne
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 07-03-2012, 05:16 AM   #10
ben322's Avatar
2009 Interstate
Bethesda , Maryland
The valves are manufactured by Drain Master and the use of a 1/8" allen wrench will open and close the valve. The black tank valve is easier to access and according to Drain Master, if installed vertically does not require lubrication.
I actually had my black tank valve stick closed and of course, I didn't read the manual so I made an appointment with AS for service. Upon reading the manual I opened the valve manually and now it seems to work properly using the switch. I'm going to start exercising these valves periodically so I won't have to crawl under the van at the dump station :-)
Old 07-28-2014, 04:41 PM   #11
2011 Airstream Interstate
2011 Interstate Coach
Energy , Illinois
I have crawled under mine and I can't see the manual override bolt.
raddocc is offline   Reply With Quote
Old 07-29-2014, 05:27 AM   #12
2012 Interstate Coach
norman , Oklahoma
My 2012 AI had the same problem with the pinhole leaks almost from new (2nd or third dump). Don't know what caused it but the hose was replaced under warranty.
russ240 is offline   Reply With Quote
Old 07-29-2014, 05:39 AM   #13
Figment of My Imagination
Protagonist's Avatar
Most likely cause is that you turned on the macerator pump while the red valve at the end of the discharge hose was closed. When the macerator pumps against a closed valve, the water has to go somewhere. The least little defect in the hose opens up quickly under that much pressure.
I did that exactly once, and water squirted out of several pinholes then. But as long as I remember to open the valve on the end of the hose before I turn on the pump, the pinholes don't leak at all, so I haven't bothered replacing the hose.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-29-2014, 07:27 AM   #14
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Another reason is allowing the hose to wind onto the reel when there are kinks in the hose. Wear a thick gardening glove while the motor draws the reel in, and guide it neatly onto the reel. A little tricky since the motor spins the reel too fast.
Draining and Flushing Tanks stefario Our Community 8 09-02-2009 07:30 PM
something is draining the battery gbroughman Batteries, Univolts, Converters & Inverters 7 05-31-2008 08:19 AM
Draining issue Siamese66 1970-79 Tradewind 11 11-08-2006 06:51 PM
Draining the tanks, funny! HubbyBear Our Community 3 07-15-2006 10:56 AM
Draining eddo Fresh Water Systems 4 09-21-2005 08:28 PM
