Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 05-21-2017, 07:39 AM   #1
2017 Interstate Grand Tour Ext
Houston , Texas
How often to use drain valve lubricant?
I have a 2017 Interstate with a macerator pump. Someone recommended I use Thetford RV Drain Valve Lubricant. The directions say use after every dump, which seems a little excessive to me.
Also since I have separate gray and black tanks, would it be sufficient to put the lubricant in only one tank, or maybe alternate them?
Any thoughts?
Leigh & Bettie
Houston TX
2017 Interstate GT
TayaraTravel is offline   Reply With Quote
Old 05-21-2017, 09:06 AM   #2
1981 31' Excella II
New Market , Alabama
If they stay wet all the time then no reason to use the stuff. Water will lube the seals when they are being used a lot. I would think the lube would be useful if you are going to drain the tanks and let it sit for a year or two. Most likely you could accomplish the same thing by using a few squirts of food grade silicone spray down the tank and in the toilet valve. I expect the toilet valve would benefit more by the lube than the tank valves that are rarely used. Most silicone sprays have solvents in them that you don't want in your tanks. You can also use the spray to lube tambor slides etc. It would be good around door and window seals as well. Also good to water proof fabrics like tents and awnings.
https://www.amazon.com/CRC-Grade-Sil...pray+lubricant
Perry
Old 05-24-2017, 08:07 AM   #3
Houston , Texas
Drain valve lubricant for Interstate?
(I posted this in the Airstream plumbing forum but didn't get a response relevant to the Interstate, so reposting here.)
Do you use this or a similar product?
Leigh & Bettie
Houston TX
2017 Interstate GT
Old 05-24-2017, 08:33 AM   #4
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
I have used it in my shower drain which had not been draining properly after periods of non-use. Not enough time has gone by to know whether it was effective. Of course, that will make its way to the gray valve, as well.
I used some I was given in both tanks in my former Classic. I never had any valve problems, but it is impossible to know whether it made any difference.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 05-25-2017, 06:43 AM   #5
2013 Interstate Coach
Waterloo , Iowa
I think this post is mixing two different issues - the shower drain valve (hepvo trap) and the tank drain valve. While I suppose this lubricant might keep the hepvo trap from sticking closed, I think the intended purpose of the lubricant is the grey and black tank drain valves - which are manual or electric knife valves.
Titus is offline   Reply With Quote
Old 05-25-2017, 02:29 PM   #6
Houston , Texas
I think that is the purpose, along with lubricating the macerator itself. So my question is whether real people use this stuff regularly, or is it overkill unless there is a problem.
Leigh & Bettie
Houston TX
2017 Interstate GT
Old 05-26-2017, 01:30 PM   #7
2015 Interstate Ext. Coach
Tega Cay , South Carolina
This is the first time I have read this. Am interested if it is necessary and works
gghayes is offline   Reply With Quote
Old 05-26-2017, 06:00 PM   #8
Argyle , Texas
It was my experience that the lubricant used inside the tanks did not help. Before each trip, I try to remember to use steel wool, polishing the pull rods - or whatever the proper name for them is - themselves, then coat with PB Blaster, W. D. 40 or whatever the auto parts supply folks tell me has come on the market. It is still not the easiest chore - but best thing I have found. Perhaps using both would be beneficial to the interior of the tanks.
Betty Farmer is offline   Reply With Quote
Old 05-29-2017, 08:25 AM   #9
Houston , Texas
Thanks to all for the above feedback. Given the response so far, I'm concluding that drain valve lubricant is not a routine and frequent additive to most people's tanks. And that I can skip this unless I suspect a problem in future. Please correct me if I'm wrong.
Leigh & Bettie
Houston TX
2017 Interstate GT
How often to use drain valve lubricant? TayaraTravel Waste Systems, Tanks & Totes 1 05-21-2017 09:06 AM
Door hinge lubricant paddy79 Doors & Locks 2 07-27-2004 08:45 PM
coconut oil lubricant for drains murphy Waste Systems, Tanks & Totes 9 05-12-2003 08:01 AM
