Old 06-07-2015, 08:15 PM   #1
2011 Interstate Coach
san francisco , California
Dragging wire
We are on our shakedown trip and the folks we are staying with pointed out a wire dragging under the coach. The wire comes from a vinyl sheath underneath the vehicle right behind the driver area. It's a single gray wire inside a small plastic sheath I have secured it for now but I really want to find out where goes
rwcmick is offline   Reply With Quote
Old 06-07-2015, 08:21 PM   #2
Here is a photo of the wire before i taped it down.
Old 06-07-2015, 08:27 PM   #3
another picture of the wire
Old 06-07-2015, 11:01 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
The sheath or boot, is where the DC wires enter the fuse block area that's under the driver's seat after being run under the van.
As to exactly what that wire is for.....I haven't a clue??
The only way to find out is to remove the driver's seat and locate that wire coming up thru the boot and see where it is connected.
Old 06-08-2015, 08:31 AM   #5
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Since it's wire inside split loom tubing it is probably something added by Airstream.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 06-08-2015, 09:18 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Obvious question, is there something on your van that doesn't work? Since that wire has to go somewhere, that "somewhere" shouldn't be able to work with the wire disconnected.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-08-2015, 09:38 AM   #7
when I get home I'll start the "what doesn't work" game. What seemed interesting to me was that that there wasn't a matching dangling wire somewhere else. I guess the connector and all could have fallen off. Part of me hopes that it is some unused wire for an option I don't have but I imagine that is wishful thinking. The hose retractor works as do the black and gray valves and the waste pump. The exterior lights all work on the chassis.
Old 06-08-2015, 09:41 AM   #8
I guess I should add that if anyone with a similar vintage model can look underneath their coach and see where the wire is routed it would be greatly appreciated.
Old 06-08-2015, 11:25 AM   #9
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Maybe look closely at the insulation, can you read anything on it? Might identify the Gage and lead to ???
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 06-08-2015, 04:17 PM   #10
I checked the wire. No obvious markings to suggest what it is. Just a gray wire in a split plastic sheath.
Old 06-08-2015, 05:39 PM   #11
GCinSC2's Avatar
1 conductor or? Maybe a crisp pic of the end of the conductor?
S/OS #001
Old 06-08-2015, 05:57 PM   #12
It's a braided copper wire
Old 06-08-2015, 06:47 PM   #13
lewster's Avatar
Braided or stranded? Braided in normally used for grounding cables and stranded for DC loads.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 06-08-2015, 08:04 PM   #14
73shark's Avatar
Overland Park , Kansas
I looked at mine and the split loom w/ a single wire goes forward and appears to be connected to something on the left (driver's) side of the engine block next to another connector. Since it's cable tied to another cable, I'm guessing that it's something Airstream adds and forgot to connect. Hard to imagine, I know.
brakes dragging? can't figure it out katzklaw Brakes & Brake Controllers 7 09-16-2010 06:52 PM
No more dragging the bumper '77 Minuet. Royce Axles 0 04-18-2010 09:19 AM
Tail dragging Farmer Dan Towing, Tow Vehicles & Hitches 6 06-05-2009 08:40 AM
dragging the rear end of my 30' excella in the skid wheels gtmellon Repairing/Replacing Floor &/or Frame 7 12-03-2006 08:08 AM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
