Old 06-08-2015, 08:13 PM   #15
2011 Interstate Coach
Muskogee , Oklahoma
Looking at my 2011, it looks like it goes to the positive solenoid connection next to the starter, and back into the fuse block. As to what it does, I have no clue. It probably relates to the battery isolator.
I don't have my schematic handy, but whatever it is, it needs to be connected to something.
And it's not at all hard to imagine them leaving it that way. There is little if any quality control at Airstream. It goes down the line, the installers do what the do in the allocated time to do it, right or wrong, and it keeps right on going regardless if they are done or not. They let the customer deal with it later if it's wrong, as is obvious here.
Originally Posted by 73shark View Post
I looked at mine and the split loom w/ a single wire goes forward and appears to be connected to something on the left (driver's) side of the engine block next to another connector. Since it's cable tied to another cable, I'm guessing that it's something Airstream adds and forgot to connect. Hard to imagine, I know.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 06-09-2015, 11:34 AM   #16
Muskogee , Oklahoma
Just curious-does your rear view camera work correctly when you turn on the ignition?
Old 06-09-2015, 11:47 AM   #17
san francisco , California
I really appreciate folks looking into this. I have attached a photo of the starter and what looks like a spade terminal ready for a wire?
rwcmick is offline   Reply With Quote
Old 06-09-2015, 12:32 PM   #18
Muskogee , Oklahoma
That's where it appear to go on mine, or at least, a similar wire inside the plastic cable wrap is connected. Is the wire hanging down a white/brown with a lug to connect to the terminal? From the schematic, it seems that terminal three should be connected with a white/brown wire?
Old 06-09-2015, 12:46 PM   #19
Gainesville , Florida
It may be a Sprinter part, not AS. Check with MB? Jim
Old 06-09-2015, 01:51 PM   #20
I'll triple check, but I am pretty sure the wire I found dragging was gray/sliver in color, not white/brown
Old 06-09-2015, 03:05 PM   #21
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
rwcmick- I got under mine and took some photos. Mine has those wires tied up in that rubber bag like thing I see in your photos. My first suggestion that they are from Airstream is probably wrong. I didn't think MB used the typical split tubing for their wiring looms. But I see that the infamous Y-cable from the battery to starter is covered with the stuff on my van. Here is a photo from the drivers side.
Name:	ImageUploadedByAirstream Forums1433883481.854061.jpg
... and here is one from the passenger side
Name:	ImageUploadedByAirstream Forums1433883619.307308.jpg
As you can see those wires on my van are tucked into that rubber bag and tied off with a zip tie. I suspect it is for a Sprinter option we don't have. Could be for something like the optional diesel fired auxiliary heater that I think get mounted near this location. Probably best to check with a MB dealer.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Old 06-09-2015, 03:13 PM   #22
73shark's Avatar
Overland Park , Kansas
The wire on the 2011s is definitely going to something on the left side of the engine block as gmillerok1 said.
Old 06-09-2015, 03:57 PM   #23
Fulton , Maryland
Dragging wire
That is the heavy wire from the coach battery. The wire rwcmick posted in his photo is farther back coming from the top of the fuel tank.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 06-09-2015, 04:25 PM   #24
Muskogee , Oklahoma
It is a grey wire-at least in mine. See attached (sorry about the poor image quality). The image is taken from the front slightly street side to orient you.
Old 06-09-2015, 04:56 PM   #25
73shark's Avatar
Just crawled under mine and the gray wire is connected to the 1/4" spade terminal on the starter solenoid. No idea as to the circuit's function.
Old 06-10-2015, 09:47 AM   #26
Thank you very much for this info. Very helpful stuff. Is there a tech dept at Airstream I can contact to ask about this wire?
Old 06-10-2015, 09:52 AM   #27
This would be a Sprinter or Mercedes Benz problem, not AS. Go to the Sprinter forum for more info. I guess you could ask AS, but it is unlikely they could help unless this is a recurring Problem. Jim
Old 06-10-2015, 11:00 AM   #28
Muskogee , Oklahoma
I believe you are are incorrect and it is clearly an Airstream issue, not a MB issue. For one thing, I believe only Airstream uses cheap plastic cable wrap like that on the vehicle.
But a quick call the Airstream would answer the question.
brakes dragging? can't figure it out katzklaw Brakes & Brake Controllers 7 09-16-2010 06:52 PM
No more dragging the bumper '77 Minuet. Royce Axles 0 04-18-2010 09:19 AM
Tail dragging Farmer Dan Towing, Tow Vehicles & Hitches 6 06-05-2009 08:40 AM
dragging the rear end of my 30' excella in the skid wheels gtmellon Repairing/Replacing Floor &/or Frame 7 12-03-2006 08:08 AM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
