Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 06-23-2006, 08:47 AM   #1
zigzagguzzi
Profile:  2005 19' Safari
Gainesville , Florida
diesel left running
Is it okay to leave the Interstate running for up to an hour? I trust the ac in the sprinter more than I do the generater in the conversion. I am talkingabout leaving it running while going into a store, etc. jim
zigzagguzzi is offline   Reply With Quote
Old 06-23-2006, 08:58 AM   #2
Melody Ranch
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1947 22' Liner
Valley View , Texas
Images: 42
Leave it running?
Try that here in Texas and it will go to Mexico without you.
Old 06-23-2006, 09:03 AM   #3
steelbird312
steelbird312's Avatar
Profile:  1989 29' Excella
Griffin , Georgia
Images: 11
My motorhome is not like yours, however, I would never trade running my CAT when I can run a 3 cylinder Kabota on the generator I really don't understand why you would 'mistrust' your conversion. If that's the case, I think I would hunt another.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 06-23-2006, 09:06 AM   #4
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Thumbs up No Problem!
Hi Jim,
I've left my Sprinter idling with the air on for several hours at a time.......no problems with overheating or anything else. Just DO IT!!!
Lew Farber -Certified Master RV Tech (currently on Forums sabbatical)
WBCCI #1032/VAC (assoc) #1032 AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 06-23-2006, 09:52 AM   #5
JBK
JBK's Avatar
Profile:  Grand Rapids , Up in the Nort' Woods of Minn.
I give: What's a sprinter?
JB
JBK is offline   Reply With Quote
Old 06-23-2006, 10:24 AM   #6
62 Overlander
62 Overlander's Avatar
Profile:  2005 25' International CCD
1954 25' Cruiser
Paradise , Texas
Not to mention it's illegal to leave your car with the keys in or running and unattended. I don't know about the Sprinters, but on the Ford diesels it'll cause some damage due to the egr system sooting up (from what I hear from other owners).
Paul & Annie
Paul Mayeux,
President Heart of Texas Camping Unit, Region 9
WBCCI #7162
Charter Member - Heart of Texas Camping Unit
AIR #1565
62 Overlander is offline   Reply With Quote
Old 06-23-2006, 12:52 PM   #7
Porky Pig
Cartoon Character
Porky Pig's Avatar
Profile:  2004 34' Classic
On The Road , U.S.A.
JB
Here ya go ...
http://www.airstream.com/product_lin...alia_home.html
Porky
TrailerGypsies.com
WBCCI #3405 — Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
Porky Pig is offline   Reply With Quote
Old 06-23-2006, 03:20 PM   #8
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
That is true of the newer diesels but not the old first generation PSD's. One of the reasons I have one Dunno about the legality or illegality, I have two keys, one in the ignition when the engine is running the other in my pocket. BTW they are different.
Aaron
WBCCI #2449 AIR #2495
Old 06-23-2006, 04:25 PM   #9
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
You can even lock your keys in a running gasser and the load on the cooling system is so much lower than driving that it will run out of gas with not one bit of trouble. Unlike problems caused by frequent starts to earlier generation diesels, I have heard from several good sources that you will cause more problems leaving newer generation diesels running. So I would echo 62 overlander's opinion that the 'olde wisdom' no longer applies. Sounds like you need to make other plans if you leave your spouse or pet inside. Hmm... I never heard of a Sprinter pulling a toad ...
CanoeStream is online now   Reply With Quote
Old 06-23-2006, 07:54 PM   #10
lewster
Commercial Vendor
lewster's Avatar
Tow capacity for the van or class B Sprinter conversion is 5000lb. with 500 lb. tongue weight with or without WD. I see no reason why it can't tow a toad within the weight limits. Don't know WHY one would want to as the Sprinter is very manuverable in tight spots, but I guess it's a matter of preference.
Old 06-24-2006, 05:05 AM   #11
wahoonc
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Images: 35
Want to see an interesting comparison? Find the EU Sprinter specs They are rated quite a bit higher for use over the pond. I suspect it may have a bit to do with the way the trailering/towing laws are written over there as well as the tort system limiting litigation. However, I have seen the Sprinters and sprinter type vehicles hauling some amazing loads in Europe.
If I had one of the Winnebago MoHo's on the Sprinter chassis, I could see the possiblity of a toad. We have considered that route, with the toad being a Ford Focus wagon. BTW with the Sprinter in the MoHo configuration the towing is reduced to 3500#, IIRC it is in some cases with the conversions too.
Aaron
Old 06-24-2006, 06:40 AM   #12
ticki2
Profile:  1976 25' Caravanner
Campton , New Hampshire
It's not a good idea to let a diesel run at low idle , new or old, for extended periods . If you notice the truckers at rest stops that leave them running step them up to high idle , 1200-1500 RPM .
ticki2 is offline   Reply With Quote
Old 06-24-2006, 11:49 AM   #13
Minnie's Mate
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville , Georgia
I have the model below. I let mine run while I unhitch and until I pull away from the trailer. It usually takes about 10-15 minutes. I do this to let the turbo booster have a chance to cool down after pulling a load before I shut it off. After my daily commute with no load on the turbo booster for 5-10 minutes or the last 7-8 miles from the interstate to my house I don't allow that cool down. I figure it has had that cool down in the last few minutes of the commute at lower speeds. I think unnecessary idling would put undue ware on the engine. If there is family or pets in my truck, I will let it idle for the A/C the same as I would my wife's gas Expedition. But for just a few minutes, not for an hour.
Family of Disney Fanatics
WBCCI# 4821
streamin across america
Old 07-09-2006, 10:56 AM   #14
tx-lawman
tx-lawman's Avatar
Profile:  Houston , Texas
I would not worry about leaving it running. If you plan to do it on a regular basis, I would add a Hobbs hour meter and check your maintainance requrirements.
The vehicle fleet I work with includes F250 Fords and GMC 2500HD trucks. They idle for 8-10 hours a day. They are maintained by the hour meter instead of the milage, and there are never any problems. The trucks are 1998-2005 models, and to my knowledge there have not been any problems with the engines. They are still as powerful and smooth as when they were new.
tx-lawman is offline   Reply With Quote
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Diesel tow vehicle-tips? maxandgeorgia Tow Vehicles 27 08-27-2006 10:28 PM
Running the roof A/C when traveling ... Hayseed Airstream Motorhome Forums 3 07-21-2002 08:16 PM
Ford Diesel RV Puller 3 axle FrankR Tow Vehicles 0 05-03-2002 06:47 PM
isuzu diesel islandvu3@cox.net Airstream Motorhome Forums 0 03-19-2002 09:48 PM
Forums Directory
