Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 07-09-2006, 12:00 PM   #15
tx-lawman's Avatar
Profile:  Houston , Texas
Ohh, and by the way - Overland is correct, it is illegal in Texas to leave your vehicle unattended without killing the engine and removing the key from the ignition. I would check the laws in your state before you do it.
The fleet I referenced above is a company I work with, and the crews are with the trucks the entire time.
Troy Marrs
95 Airstream LY 33
tx-lawman is offline   Reply With Quote
Old 07-09-2006, 12:25 PM   #16
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Welcome to the Forums Troy! That is a very reassuring answer. In the words of the Texas Troubador, "Thanks! Thanks a lot!"
Old 07-09-2006, 12:59 PM   #17
Davydd's Avatar
Profile:  Tonka Bay
Images: 13
I haven't run the roof top air conditioner other than when hooked to 30 amp electrical or off the propane generator. I don't see much of a reason to run the diesel while shopping or lunch, etc. The engine air conditioner works just fine once underway again even in 100 degree weather. I have run the propane generator for up to 3 hours so far with no problem if that is a desire. The more you run it the better off you are because you should run it at least once per month for at least 2 hours says the manual. As far as I know all Sprinter conversion vans except the Westfalia use the same Onan.
My fridge is the biggest concern. Underway we run DC, stopped with no electrical hookup we run propane and with electrical hookup we run AC. For short stops we leave it on DC. While traveling the house battery pretty much keeps it's charge. Gotta keep that beer cold.
Europe and England must have looser towing regs. I was amazed to see what we consider compact cars pulling trailers in England. The most popular tower seemed to the the VW Passat but I suspect they were diesels. I don't see why a Sprinter couldn't pull a Bambi. It certainly has the torque. There would be no reason to pull a toad (car) in my opinion since you can park anywhere a car can park except in a parking garage. Now that many codes and ordinances require the main level of a parking garage capable of access by ambulances and mobility vans you could even luck out in the newer parking garages.
I think I just broke my 666 evil devil hex message count.
Davydd
Pleasure-Way Plateau Sprinter B Camper Van
2004 Nissan Titan LE Crew Cab
(Former vintage Airstream Owner)
http://www.tonkawoods.com
http://www.porktenderloinsandwich.com
Davydd is offline   Reply With Quote
Old 07-09-2006, 11:53 PM   #18
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Originally Posted by Davydd
Onan.
I don't see why a Sprinter couldn't pull a Bambi. It certainly has the torque. .
This Sprinter does very well pulling it's 19CCD around the country, and with a van weight of around 8000lb loaded. (see pic at left)
Lew Farber -Certified Master RV Tech (currently on Forums sabbatical)
WBCCI #1456/VAC (assoc) #1456 AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 07-10-2006, 03:27 AM   #19
volvophile's Avatar
Profile:  colorado springs , Colorado
Illegal in Colorado to
Its illegal in Colorado to leave a running vehicle unattened. Something about "undesirables" hanging out in apartment complex parking lots in the winter and waiting for someone to warm up thier car....
I installed a Cool Start remote starter in my Ford PSD. It has a setting to let the engine run for a set time, or indefinatly without the key in the ignition.
If the brake pedal is pressed (neccisary to take it out of park) it kills the engine.
BTW, the remotes are not recomended for diesels with manual transmissions.
The starter motors have enough torqe to start the engine if left in first gear.
There are issues with leaving a PSD running at low idle for long periods of time. One if which is the top of the cylinders getting hotter than the bottom of the cylinders. There are mods to increase your idle speed to around 1100 or so to aleviate that problem.
Cheers,
volvophile is offline   Reply With Quote
Old 07-10-2006, 08:36 AM   #20
Profile:  Plantersville , Texas
personal choice
Here is another example of state laws that limit your freedom of choice.
I'm not saying that you should leave your motor running un attended.
You should have the choice do to so at your oun risk (motor damage or theft) If our state lawmakers worked as hard on important issues as on these nit-picking things the Texas legistature would not have had 3 sessions to adopt a school finance plan. New Jersey would not have to shut down the govt, waiting on a budget.
my $.02
Kay
carnegie1935 is offline   Reply With Quote
Old 07-10-2006, 03:38 PM   #21
tx-lawman's Avatar
Many laws are much like the caution and warning stickers on the products we use. They exist to keep stupid people safe from harm. In my line of work, I get to meet most of the stupid people in my area... sometimes I get to meet the very stupid people over and over again.
I don't know what the intent of the law makers was when they wrote the law about not leaving your engine running, however I do have a couple of GOOD things about the law.
1) Saves alot of vehicles from being stolen, which in turn keeps insurance rates down.
2) Gives cops a reason to write a ticket or arrest drug dealers or other scum when we can't figure out what they are really up to - but we know it is something illegal.
OK, so one of the above is just a joke, but since there are too many people out there that can't judge for themselves when it is safe or not to do this, I guess we have to protect them from themselves.
____________
Troy Marrs
95 Land Yacht 33
Old 07-30-2006, 06:25 PM   #22
Profile:  Norfolk , Virginia
Sprinter has a high idle option from the factory. Many of these vehicles are used as ambulances in Europe, and they are on idle all of the time.
Steve
Geophilist is offline   Reply With Quote
Old 01-19-2008, 03:38 PM   #23
Profile:  Flemington , New Jersey
It's not good to let diesels run @ low idle. The noise is detonation, flame fronts colliding. I'm to install the constant RPM option, High idle.
Sprinter-Forum
Bo
BW999 is offline   Reply With Quote
Old 06-28-2008, 09:32 PM   #24
Profile:  newport news , Virginia
I tow my wife's ford Contour sometimes. It is nice to be able to just leave the Interstate at the campsite and go sightseeing. We visit state parks and in many of them moving your van off the site opens it up for someone else to use, even if you leave your other stuff there.
2007 Airstream Interstate
alann is offline   Reply With Quote
Old 06-29-2008, 01:43 PM   #25
The guy with the B-van
Skater's Avatar
Profile:  Bowie , Maryland
Send a message via ICQ to Skater Send a message via AIM to Skater Send a message via Yahoo to Skater
Woohoo! I tow a '99 Cougar (which is built on the same platform). But I have an older B-van, not the Mercedes-based one.
(Sorry for the off-topicness.)
1991 Airstream B190 - 7.5L/460 cu in V8.
Jasper remanufactured E4OD.
Stehl Tow Dolly. Tekonsha Prodigy brake controller.
Pioneer head unit, Sirius tuner.
WBCCI #13270 - Washington, DC unit
B190 Owners: The new site B190 Enthusiasts is dedicated to the 1989-1999 Airstream B190.
Skater is offline   Reply With Quote
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 08:50 PM
Diesel tow vehicle-tips? maxandgeorgia Tow Vehicles 27 08-27-2006 11:28 PM
Running the roof A/C when traveling ... Hayseed Airstream Motorhome Forums 3 07-21-2002 09:16 PM
Ford Diesel RV Puller 3 axle FrankR Tow Vehicles 0 05-03-2002 07:47 PM
isuzu diesel islandvu3@cox.net Airstream Motorhome Forums 0 03-19-2002 10:48 PM
