07-16-2017, 09:07 AM
2016 28' Flying Cloud
The Plains
, Ohio
DEF at Pilot
Has anyone added DEF at a Pilot station? I added Diesel at a truck pump and was totally confused as to how to add DEF when the time comes. What sequence of choices will be correct if I want to add both diesel and DEF?
Also, will the DEF hose reach to the opposite side of the van where the DEF tank is located under the hood?
I'm not ready for DEF (brand new AI and I would think they would have filled the DEF tank). Although I guess one never knows until the low DEF warning shows up.
I worry too much but I'd appreciate it if someone could lead me through the process.
Thanks.
Richard
07-16-2017, 09:11 AM
Dazed and Confused
Hillsburgh
, Ontario
Your vehicle should come with the original Mercedes owners manual for the chassis and engine; should you not look there first as opposed to someone's word?
Or Google Mercedes Sprinter DEF
Cheers
Tony
07-16-2017, 09:53 AM
Muskogee
, Oklahoma
Thanks.
Richard
First of all, DEF is not that complicated. All it is is a fluid that sprays into the exhaust to reduce the emissions. There is no connection between DEF and Diesel other than that. It makes no difference which you fill first or last.
You can buy it at Pilot or any other station and use the pump, or in containers at Walmart or any automotive outlet, and yes, the hose is usually long enough.
The problem using the pumps though is that, at least in my experience, that the flow rate from those pumps is too fast and the filler neck will overflow almost immediately, leading you to think it's full when it is not.
During my last 5000 mile trip, my engine light came on. This happened before and I suspected it was the prelude to the low DEF message. So I bought 2 gallons of DEF, and poured it in. The light, a few miles later, went out.
When I returned home, I put in another 2.5 gallons, but it took two days. After about 1.5 gallons, the fluid would come to the neck of the filler but slowly drain (and I mean SLOWLY) in the tank. I would wait about 30 minutes, and put in some more. It took about six iterations of this procedure to use the entire 2.5 gallon container. From other posts, and from other owners I have talked to, this is a common occurrence. So just because the fluid comes up to the neck of the filler, wait awhile and check it again, if you want to top the tank off.
I would recommend that when you get home, just do the same before your next big trip. Don't worry about it on the road.
Be sure to wash off the excess if you spill any.
And you don't need to read the manual.
2011 Interstate WD/Lounge (since sold).
2020 Leisure Van WonderRTB
07-16-2017, 10:12 AM
2017 Interstate Lounge Ext
Northern
A full tank of DEF should last you about 5,000 miles. You can be proactive and put a couple gallons in every 2000-3000 miles, or just wait for the Low DEF message and fill it up then. The only possible issue with waiting until the message shows up is it is accompanied by a "X starts remaining" warning, which can freak some people out. If you treat the Low DEF message like a Low Coolant message, i.e. drive straight to the nearest auto supply store and get more, you'll never have an issue. If you procrastinate and run your DEF dry, you can have problems.
Which reminds me, I need a couple gallons of DEF after my last trip.
Oh, and with all the Bluetec cars on the road, DEF is now available dang near everywhere. You can even find it at places like Walmart, and as a bonus the Walmart jug (2.5 gallons) comes with a nice little hose that you attach to the top of the bottle to reduce spilling. $7.88 for 2.5 gallons and you're all set.
07-16-2017, 10:28 AM
Muskogee
, Oklahoma
I may add to the OP that I NEVER buy diesel at Pilot or Love Truck Stops.
They only sell Bio-Diesel. The Sprinter engine will tolerate B5, but even Mercedes won't warrant engine damage if you use B20. Most bio-diesel say "May contain up to B20 Diesel" so you have no idea what you are getting.
I found this out the hard way when I first got my Interstate after I had to replace my O2 sensor after using bio-crap after only a few thousand miles.
Sixty-thousand miles later, and no bio used, never had another problem. Even the Sprinter tech guy told me to "Never use bio if you can help it."
I only use straight, no bio diesel, would advise you to stay away from Pilot and do the same.
And I never travel in Minnesota, because it mandates B10 in the summer, and B5 the rest of the year. Next year, this goes to B20. You don't even have a choice. You won't catch me ever vacationing or even traveling though that state.
07-16-2017, 10:43 AM
2015 Interstate Ext. Coach
Columbus
, Ohio
Thanks.
Richard
I also agree with those commenting already, that filling your DEF at home is a pretty easy procedure.
However, I wonder where you're stopping to get fuel at a Pilot station?
I've just about given up trying to fuel up there. During our last long trip, every time we stopped at a Pilot/flying J, they only had 20% Biodiesel for sale. That won't work in our 5% bio max Mercedes!
I thought I read somewhere that possibly Gas Buddy was going to add bio % to their app, but so far haven't seen it!
Adventure before Dementia!
07-16-2017, 10:52 AM
Vintage Kin
Fort Worth
Truckstop procedure is Diesel first and DEF second for my corporate account. I finish with fuel, hang it up and click on the DEF button. Then pull that Spring wound rascal out farther than I need it to top off my 18-gal tank.
The nozzles are sensitive. Some are terrible. I've held them in all sorts of positions. So, keep at it.
So far as DEF is concerned, keep the tank top topped off (is what we do in big truck world). Fewer related problems that way.
Just finished delivering 5,200-gals of DEF at the T/A just up IH35 from NTAC. Would rather be there admiring others rigs.
All DEF comes from the same plants.
If it matters, use 9.09 lbs/gl to figure.
07-16-2017, 12:32 PM
The Plains
, Ohio
Cheers
Tony
Gee Tony, I searched and searched the owner's manual for instructions as to how to use the DEF pumps at the Pilot gas stations and you know what, there wasn't a single page that outlined the procedure. Perhaps you could direct me to the proper page.
Richard
07-16-2017, 12:58 PM
Dazed and Confused
Hillsburgh
, Ontario
Richard
It's the page that states you shouldn't be filling with 20% bio diesel as this will void your warranty and result in engine damage that could cost you $20,000+ to fix.
Cheers
Tony
07-16-2017, 02:33 PM
Northern
Richard
I think you're being cheeky, but the answer, at least when I was last at a combo Pilot/Chevron station where they had DEF pumps (about 2 weeks ago), was exactly the same procedure as pumping fuel. Swipe your credit card, lift the handle and pump as much DEF as you need (as others state, it comes out WAY too fast for our rigs, but you're welcome to try it, just remember, DEF is corrosive vs. certain metals so be sure to clean up any spills!), then return the handle to the pump.
As an aside, I will echo others in regards to only fueling Sprinters with "pure" diesel and staying away from ALL bio, including B5. I know the manual says B5 is OK, but in actuality, bio is very poorly manufactured and regulated, so what may be marked as B5 may very well be something else. For me, it's not worth the risk......
07-16-2017, 03:28 PM
2024 Interstate 19
Fulton
, Maryland
DEF at Pilot
I have used the DEF pumps at truck stops with no issues - easy job. But all those who think they are getting non-bio diesel you might be kidding yourselves. The enforcement of pump markings are pretty weak and if you live in any are where corn is grown you are likely getting at least 5% bio-diesel. Thank your local politicians for this mess.
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
07-16-2017, 03:34 PM
2011 Interstate Coach
Overland Park
, Kansas
My dealer said don't use biodiesel period. And I would get about 10,000 miles from the five gallon DEF tank.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
07-16-2017, 04:12 PM
Northern
Totally agree, but there isn't much we can do about it. Enforcement on the pumps is pretty much zero where I am, but that's all we have to go by. I even went onto Arco, Chevron, Shell, and BP web sites to try to find any info on what they are putting in their diesel fuels and I can't find anything useful. If it really is a federal law that says every pump with bio has to be marked, these guys are all breaking it or they are all pumping pure diesel. I'll let others decide which is fact, but I know which one I believe and will claim I've only ever put pure diesel in my rig if I ever have to make a claim with MB because I've never filled up with anything that's marked as having any bio content.......
07-16-2017, 05:04 PM
2024 Interstate 19
Fulton
, Maryland
Considering how much diesel fuel that Pilot and Love's stations pump you can bet local distributors are selling bio-diesel. Also thank Willie Nelson as he was an early supporter of bio-fuels. I should have added areas that grow soybeans too.
- - Mike
07-17-2017, 06:46 AM
2012 Interstate Coach
Westerville
, Ohio
Intersting info. from Mercedes regarding approved fuel labels on pumps (toward the end of document)
https://www.mbusa.com/vcm/MB/Digital..._Brochure5.pdf
07-17-2017, 07:06 AM
Columbus
, Ohio
I contacted Flying J/Pilot customer service about Bio Diesel %'s.
Here's their reply;
Thank you for contacting Pilot Flying J Guest Services! Not all of our stores sell bio diesel. Our diesel ranges from 5% to 20% nationwide. If you go to the following website, it can tell you what locations have bio diesel and what percentage is carried there. https://www.pilotflyingj.com/fuel-prices.
If you need any further assistance from Guest Services, please call 1-877-866-7378 and any representative that answers will be happy to assist you.
07-17-2017, 07:12 AM
Columbus
, Ohio
Originally Posted by Aircruiser
Thanks for the link Bob...It is very informative!
Looks like we should look for only the "Green Label" when fueling our AI's!
Mark
07-17-2017, 08:50 AM
2024 Interstate 19
Fulton
, Maryland
DEF at Pilot
Here's their reply;
Thanks for posting the response from Pilot Flying J. I looked around the list and most stations sell bio-diesel. After going to one specific stations web page I noticed a fine print disclaimer.
https://www.pilotflyingj.com/disclaimer
Regarding bio-blends it says:
"Biodiesel and/or Renewable Diesel Blend Percentages - Pilot Flying J will use commercially reasonable efforts to meet these posted percentages. However, Pilot Flying J cannot guarantee blend percentages for all locations 100% of the time due to pre-blended diesel in the supply chain, store blending systems, supply availability, measurement calculations, temperature, etc."
I contend that since pre-blended diesel is already in supply gain you can't avoid it. It's time for Mercedes to change their design to handle bio-diesel as others have done.
Perhaps this issue also contributed to Mercedes dropping all diesel engines from there car/SUV line this year. They told the media that diesels were only 2% of their US car/SUV market.
http://autoweek.com/article/diesel/m...mpliance-fears
But all Sprinters in USA/Canada are diesel. Time to bring back the gasoline powered Sprinter that was once sold under Dodge logo. Or better yet a Sprinter with a nice Mercedes V-8 gas engine. I'm dreaming of an AMG V-8 in a Sprinter. [emoji41]
- - Mike
07-17-2017, 09:48 AM
Bellevue
Pretty useful. Thanks.
07-17-2017, 09:56 AM
Northern
Mark
These "green labels" are often missing from pumps, along with any other labels, so it can be a challenge to figure out what's in the pump.
Also, some pumps have a blue "S15" label instead of the "green label" to indicate ULSD. I came across this in my recent trip to Oregon.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Diesel/DEF mileage.
ROBERTSUNRUS |
Tow Vehicles |
28 |
03-19-2014 11:47 AM |
DEF Fluid
eliasurbina |
Sprinter and B-van Forum |
8 |
11-23-2013 11:29 AM |
Def
aa9zz |
4 |
10-03-2013 11:34 PM |
Diesel Exhaust Fluid (DEF)
Brentsouth |
17 |
04-13-2013 02:18 PM |
Hi-Def on the road?????
FlaAirstream |
Full-Timing |
2 |
11-26-2007 06:30 PM |
