Old 07-14-2018, 11:08 AM   #1
St auguatine , Florida
Dead 2018 AI AGAIN!
After being in the shop at RVOne in Winter Park FL for at least the 7th time in 10 months for dead batteries ) selinoid (sp?) two weeks ago, the van is dead again and I am t leave for key west camping trip tomorrow! Spoke with AI Customer service yesterday and did all they said to do: bought charger and hooked it up for 90 minutes then put it on shore power for 13 hours. Still dead. The step still works and worked yesterday and now Magnum is at least lit but says NO COMM and won’t move from that . Anyone have a weekend number for AI help?
carpenc is offline   Reply With Quote
Old 07-14-2018, 11:10 AM   #2
Long Island , New York
Good idea to start your own thread. For everyone's information, the previous conversation is here, starting at Post #16:
http://www.airforums.com/forums/f240...ts-183956.html
Good luck!
Peter
Old 07-14-2018, 12:27 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Basic troubleshooting, start with shore power off / disconnected:
1) Grab a multimeter and check the voltage on the starter battery (should be above 12V)
2) Do the same for the house battery ( also should be above 12V)
3) Check the voltage at the output of the Magnum ( should be same as battery)
4) Plug in to shore power and check the output of the Magnum. It should go up. (like to above 13V)
4a) Check the 120V into the Magnum ( = is the breaker tripped? ) with the multimeter if the
voltage does not rise a bit when it's powered up.
5) Now check the house battery, it should be about the same as the Magnum output.
Best guess is that one or more items on that list will be "nope, that's not what I get". Depending on how many items get a "no", the next steps vary a bit. The following is only a guess:
5) If the Magnum does not raise the voltage, then hook up your charger to the house battery. The voltage should come above 13V after a bit. If it was < 10V to start, it will take longer (like hours). If it does not come above 13V after 12 hours, either your new charger isn't doing the job or the batteries are shot.
Again, that's only a guess, there are *lots* of other directions this could go.
Old 07-14-2018, 03:10 PM   #4
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Check my response in your other similar thread.
Old 07-14-2018, 03:49 PM   #5
Mansderm161's Avatar
NORTH MYRTLE BEACH , South Carolina
If the chassis is dead, take it to mercedes. I was having low battery warning and mercedes replaced the chassis battery under warranty. No problems since
Mansderm161 is offline   Reply With Quote
Old 07-15-2018, 11:13 AM   #6
AFTER TAXES's Avatar
1993 25' Excella
Early Bird , Florida
Images: 11
sad............
thats really sad to hear......A/S
AFTER TAXES is offline   Reply With Quote
Old 07-15-2018, 02:33 PM   #7
gr.austin's Avatar
2009 27' FB Classic
Sioux Falls , South Dakota
Imo A camping RV that is intended to be used off the grid should not have any hi-tech stuff that will leave you stranded in some God forsaken place on a holiday weekend with no one within 50 miles. To buy such a vehicle is just asking for an adventure that you can tell you grandkids about.
Keep smiling remember Buy an Airstream some assembly required. I had 76 quality issues with my 27FB Classic Limited. Would never go through that again.
gr.austin is offline   Reply With Quote
Old 07-15-2018, 04:20 PM   #8
Lily&Me's Avatar
Normal , Illinois
I would suggest that you keep one thread on this going and not start a new one with each question.
It will keep information and replies together for you and anyone else who has similar issues.
Good luck,
Maggie
Old 07-15-2018, 09:09 PM   #9
Wolf Alaska's Avatar
Madison , Alabama
I don't have a weekend # for AS customer support, sorry. I'm answering your 1st Q. Didn't see anyone else do so.
Re: your no start issues. You would be surprised how many RV problems can be fixed with new batteries. They can age out fast or last for multi years with good care.
Many new RV's need new batts @ delivery & should get replacement batts before being seriously used as an RV. Dealers usually refer the owner to the batt. warranty.
A power converter is basically a battery charger, so use your new charger on your chassis or coach batts when you have shore pwr. until this problem is gone away.
The other members' posts are good & should help pin down the cause.
If it was my coach & I needed to leave for Key West, I would get to W-M, buy new batts & see if that got the coach going. It won't hurt to try.
W-M may take the batts back if you don't want to keep them
I would NEVER give up new, installed batts for some old batts. But, that's just me.
Please let us know how this goes. We all hope you get to KW soon.
& would like to be cruising with you!
Let's Roll !
Wolf
Wolf Alaska
M.S./CFI/IR/ME/CP
FMCA SKP GS GPAA NRA USN (Ret)
Wolf Alaska is offline   Reply With Quote
Old 07-15-2018, 09:44 PM   #10
Good luck,
Maggie
Good advice IMO. It is difficult to chase down a problem when it is restated in different places, with different facts.
Cheers,
Peter
Old 07-15-2018, 11:25 PM   #11
Thanks Wolf. Charger on batteries for 90 min followef by 13+ hours of shore power didn’t change anything so taking it in in the am tho I may try one more thing: run engine with battery store on. Saw that idea in another thread. And I started new thread as suggested.
Old 07-16-2018, 07:13 AM   #12
Madison , Alabama
I would have rather you said: battery charger on engine batt. for 13 hours. If engine batt. is flat, it may take many hrs. to recharge depending on strength of your charger. I don't know w hat shore pwr does for engine batt. Also, if your inverter is bad, shore pwr won't do anything for batts.
Wolf
Wolf Alaska
M.S./CFI/IR/ME/CP
Old 07-17-2018, 09:04 AM   #13
Wow I would never expect that many issues in an Airstream trailer! Awful and depressing!
Old 07-17-2018, 09:14 AM   #14
Half a Rivet Short
Hi
Compare that to the 8,927 major issues in the first 2 months on a "typical trailer".
house battery seem dead/ shore power dead joe rv guy Sprinter and B-van Forum 29 12-26-2016 01:36 PM
dead dead bolt Jim from SB Doors & Locks 3 09-09-2012 12:32 PM
Logging In Again and Again and Again Secguru Forum Admin, News and Member Account Info 4 11-01-2010 12:15 PM
Dead ...really dead Melody Ranch Batteries, Univolts, Converters & Inverters 17 06-13-2007 01:23 AM
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-02-2002 12:03 AM
