Old 04-21-2015, 07:35 AM   #1
2013 Interstate Coach
Lafayette , Louisiana
D/C wiring for towing
2013 Sprinter appears to have separate brake light/turn light wiring. Amber for turning and red for braking. Does not appear to be combined.
Does Sprinter have a 3 to 2 converter built in to system? My toad has a separate system. Any electrical experts out there who know what I am talking about?
drgene is offline   Reply With Quote
Old 04-21-2015, 08:47 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
How the van's taillights are set up is unimportant. What's important is the way the van's seven-pin connector is set up. The seven-pin connector is standardized, with turn/brake/taillights all going to a pair of two-filament bulbs, one on each side of the toad or trailer.
On my Honda Fit toad, when I'm driving it the turn signals are amber. When I'm towing it and the signal comes from the van, the turn signals are on the red lenses along with the taillights and brake lights. Trailers aren't required to have a center brake light— and when towed, your toad is legally a trailer and so doesn't need a center brake light, either.
Standard practice these days, if the toad's taillight housings are big enough, is to wire separate bulbs into the red lenses, thereby avoiding the need to tap into the toad's wiring harness and install relays for the toad's OEM lights. It's a much cleaner install, with less potential for problems.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-21-2015, 09:26 AM   #3
Protagonist, my KIA has amber turning and red braking and running lights. Are U saying that one two-filament bulb added to each red lens right and left will be all that I need thus converting my KIA to a "trailer" like my boat trailer?
Old 04-21-2015, 10:31 AM   #4
Yes, assuming you run the wires from the umbilical cable to the lights correctly.
WBCCI #1105
TAC LA-4
Old 04-21-2015, 01:07 PM   #5
D/C wiring
Thanks so much for the info!
Old 04-21-2015, 04:29 PM   #6
Rockwell , North Carolina
I installed the bulbs in the tail light lens on my Fiat Abarth. You can see how in this thread:
http://www.airforums.com/forums/f240...re-133686.html
jerhofer is offline   Reply With Quote
Old 04-22-2015, 12:26 PM   #7
2000 36' Land Yacht XC Diesel
Fresno , California
I'm so blown away y'all can do this sort of work yourselves! So impressive. I rely on the lovely folks at Toscano RV to do all my work. I know on my H2 toad they added two new bulbs into the housing for towing. Do you think they added some to my reverse lamps? Those also work when hooked up.
LucasS is offline   Reply With Quote
Old 04-22-2015, 01:19 PM   #8
They might have. But since you can't back most toads while they're hitched up, it's generally a non-issue for the rest of us.
WBCCI #1105
TAC LA-4
Old 04-22-2015, 10:09 PM   #9
Fresno , California
What do you mean y'all can't back up your toads??? I can. I have. Am I not supposed to???
Old 04-23-2015, 02:04 AM   #10
Most toads won't back very far while they're being towed because the steering "trips" to one side and stays there. Backing most toads is a great way to ruin front tires.
If your toad has an automatic transmission like mine, then backing the toad also causes the transmission fluid to pump itself out through the dipstick tube because the transmission's internal workings are being cranked backwards.
Also, self-adjusting towbars aren't really designed to push, only to pull.
If you can back up your motorhome more than a couple of feet with the toad attached, and not risk any damage to the toad or the towbar, you're very lucky.
WBCCI #1105
TAC LA-4
Old 04-23-2015, 10:42 PM   #11
Fresno , California
Wow I'm glad I responded to this post. I've never had to reverse more than a few feet to correct a turn or maneuver through super tight RV parks. But now I know not to push it.
Towing 19ft Bambi with 2009 Tacoma v6sr5 w towing package Shany53 Tow Vehicles 6 07-03-2017 10:44 PM
Water pump wiring and proper wiring Supertwin1 Water Heaters, Filters & Pumps 8 05-23-2014 07:05 AM
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
Is House Wiring the same as Automotive Wiring? swebster Mechanics Corner - Engines, Transmission & More... 7 06-15-2004 06:11 AM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
