Old 12-11-2018, 08:38 AM   #1
Liberty Township , Ohio
Cover for a 2018 Interstate Grand Tour EXT
Reaching out for any wisdom on which cover to purchase for my 2018 Grand Tour EXT. Also will be purchasing wheel/tire covers.
My rig will be exposed to southwest Ohio climates during outside storage.
Thanks Friends!
Luckysnuck is offline   Reply With Quote
Old 12-11-2018, 09:06 AM   #2
2016 Interstate Lounge Ext
Lake Oswego , Oregon
I have an unused full cover that I purchased for my 2016 interstate. I've since changed plans , and built a carport for it. It's made for the 24 foot version and is a soft, water proof fabric with correct entry zipper access. if you are interested please let me know.
joe rv guy is offline   Reply With Quote
Old 12-11-2018, 09:58 AM   #3
Lily&Me's Avatar
Normal , Illinois
I have black vinyl wheel covers, elasticized and stay on nicely.
Conventional wisdom, mine included, is against a full cover, particularly when you live in areas of snow and ice.
They are hard to keep secure in wind, and the shifting causes abrasions to the finish.
Also, snow and ice will pool on the cover on the roof, difficult to remove when you want to get the cover off for travel.
Ours was a waste of $300.
Maggie
Lily&Me is online now   Reply With Quote
Old 12-11-2018, 01:36 PM   #4
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
LUCKYSNUCK - I agree with MAGGIE. When used outdoors, a full cover protects from sun UV and bigger things like leaves and some good measure of dirt protection. But the better it is at doing those functions, it also increases the issues MAGGIE mentions. It is virtually impossible to keep the finish of your rig 100% clean before putting on a cover. It is also impossible to keep the inside of cover 100% clean. It only gets worse with every passing day. The trapped dirt quickly acts like sandpaper and causes abrasions. While the best covers can also be so effective at keeping weather out, but that also means the moisture will get trapped under it. It also makes the area more attractive to pests nesting in there. So you just end up trading multiple issues with multiple new problems.
Many decades ago, I used a full cover on 1 of my cars & stored it outside (Chicago). Will never do it again. Damaged the paint with scratches and rusted areas where moisture got trapped. I will only use a cover immediately after car is washed and then rolled into garage. If I need to keep a car outside for long period of time, I may cover windows to keep UV from interior. But leave body uncovered and just wash/wax it often. If it is out of commission the entire winter, put up on blocks, cover tires, cover all glass at least from inside (outside covers are better if you can buy them or make your own), treat all rubber & vinyl moldings with 303 Protectant.
BTW California Car Cover makes many different types of Outdoor Car Capsule - The Original Car Storage Bubble. It is an innovative product in that the entire car is protected all around, including bottom. You roll the car onto the bottom shield and then zip it up all around. Unfortunately, there is nothing that a huge AI will fit into.
Alex AVI is offline   Reply With Quote
Old 12-11-2018, 03:01 PM   #5
2013 Interstate Coach
Raymond , Iowa
We leave ours outside Apr-Oct and store it inside for Nov-Mar, the five months when we don't use it. I don't cover it (or the wheels) the seven months it sits out. We put on enough miles (15,000 /yr) that we don't need to worry about the tires rotting from age before they wear out from usage. I suppose 7 months of sum might be a bit hard on the plastic parts (AC cover, etc.) but ought not have any impact on the MB silver paint. And if it does, oh well...
Titus is offline   Reply With Quote
Old 12-11-2018, 03:35 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
As noted above...no cover here.
Tried it with our first AS...bad choice.👎
But then again...it doesn't Sno-in-Bflo 😂🥴
I do unload the axles & store the tires though.
ID:	329500   Click image for larger version
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 12-11-2018, 04:20 PM   #7
Boxster1971's Avatar
Fulton , Maryland
I leave my 2013 Interstate parked outside in Maryland where we get the full four seasons. I never cover it as I use it for my second vehicle, driving it about 20,000 miles/year. Finish on van still looks great. I wash it fully 2-3 times a year. Had it detailed at the FMCA rally last March and looked like new. The only obvious exterior wear is slight fading of the painted plastic trim added by Airstream. Also some of the painted plastic trim has road damage from gravel roads. I don't think a cover is worth it and more trouble with possible damage.
- - Mike
Old 12-13-2018, 12:16 AM   #8
brookhaven , Georgia
Keep it indoors and plugged in.
coasttocoast is offline   Reply With Quote
Cover For A 2018 Interstate Grand Tour EXT Luckysnuck Winterizing, Storage, Carports & Covers 2 10-27-2018 09:28 AM
2018 Airstream Interstate Grand Tour Ext 24 - Florida FlStrmr Airstream Classifieds 0 08-31-2018 10:43 AM
2018 Airstream Interstate Grand Tour Ext 0 - California teresak Airstream Classifieds 0 01-14-2018 02:38 PM
