Old 08-13-2013, 10:27 PM   #1
bennu36's Avatar
2012 Interstate Coach
Portland , Oregon
cooling the 'fridge
on average how long does it take to get you fridge donw to temp if the setting is at 3 as recomended. I want to take it out this weekend but will mostlikey not have the chance to plug it in, so I am wondering do I try and cool it from the battery and then fill it or fillit saturday moring and hop it reaches temp as we drive along we have about a 2.5 to hour drive.
bennu36 is offline   Reply With Quote
Old 08-13-2013, 10:34 PM   #2
kmaggard's Avatar
1994 21' Sovereign
Paradise Valley , Arizona
I freeze 15 to 20 water bottles at home and put them in the fridge and freezer section to help it cool. Remember a full fridge is a happy fridge and you have nice cool water all weekend. You also can start it on propane a day early. They actually do not use a lot.
WBCCI# 2520
AIR# 77458
Ken and Ben the Saint
Paradise Valley, Arizona
kmaggard is offline   Reply With Quote
Old 08-13-2013, 10:36 PM   #3
Sebastopol , California
We freeze bottled water and put it on the door, fill fridge with cold food, turn on and take off. This method has worked so far. The frozen waters serves like an old fashioned ice box until the power of the fridge catches up.
Sebtown is offline   Reply With Quote
Old 08-13-2013, 10:43 PM   #4
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Don't cool it using your battery. Start it on propane a day early. Ice helps also.
I monitor my fridge temp using a remote thermometer from Walmart, less than $10.
See my thread in the fridge section.
Dan
Old 08-13-2013, 10:43 PM   #5
bennu36's Avatar
Portland , Oregon
thanks sounds like a great idea I think we will try that
Old 08-13-2013, 10:45 PM   #6
bennu36's Avatar
Portland , Oregon
for many good advice
Dan
The problem is the fridge in the Interstate is all electric no propane
Old 08-13-2013, 10:53 PM   #7
kmaggard's Avatar
1994 21' Sovereign
WOW I didn't even know they made a non-propane fridge, 'learn something new everyday'.
WBCCI# 2520
AIR# 77458
Old 08-13-2013, 11:12 PM   #8
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I usually cool the fridge down the night before by having my Interstate plugged into a 120V source. I also add some frozen water bottles. I don't think it would take more than 2 hours for the fridge to get down to temp when you drive. But you may have difficulty keeping it running all weekend on only the coach battery if you are not driving or plugging into 120V. In my experience the coach batteries will be flat in two days just from running the fridge. Of course you can run the propane generator occasionally over the weekend if needed to keep the batteries up.
- - Mike
- - Mike
Old 08-14-2013, 06:03 AM   #9
Figment of My Imagination
Protagonist's Avatar
The trick is, make sure the inverter is set to "charge only". That forces the fridge into 12vDC mode, which is more efficient in its use of power. By doing that, I've started the fridge to let it cool down as much as 36 hours in advance of the trip, without depleting the house batteries below 65%. Side noteó I don't usually cool down the fridge that long; my departure was delayed on that trip. Usually, I'll start the fridge the evening before, and pack the fridge the morning I leave, so it's only on 12~15 hours in advance.
Anyway, the way the Nova Kool fridge is set up, as long as there is a source of 120vAC power, the fridge automatically switches to 120vAC even though it's less efficient in that mode. Any source of 120vAC power, including the inverter. So the only way to keep the fridge in 12v mode is shut the inverter off.
I've debated unplugging the 120vAC cord altogether and using the fridge as 12vDC only, but I haven't been motivated enough to tear open the galley cabinets to reach the electric outlet. Even though someone kindly told me (here on the Forums) how to remove the microwave so I could reach the plug for the fridge.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-14-2013, 08:22 AM   #10
David M's Avatar
Orange County , California
On the non-wardrobe Interstates, you can unplug the fridg by opening the tilt-out tray in front of the sink so it only runs off of 12v. As you can see in the attached photo, there are 2 single-plug outlets; one for the fridg and the other for the microwave. The outlet for the microwave only works when the Interstate is plugged in to shore power, and the outlet for the fridg works when the inverter is turned on. What I'd like to know is why AS went to the trouble of running 2 circuits there. Maybe AS didn't want to run 2 appliances off of one circuit, but it would have been nice if the circuit for the fridg also worked only when plugged in to shore power (as Protagonist mentioned above).
David M is offline   Reply With Quote
