Old 11-29-2014, 08:16 AM   #1
2014 Interstate Ext. Coach
Bound Brook , New Jersey
Cold weather tailgating
Hi all. As you may know I'm a new owner of a 2014.5 lounge ext. I'm going to practice tailgate today at our neighborhood Turkeybowl gathering. Temperature is a balmy 28 rising to 40. I'll be running the furnace a bit to provide a "warming hut". Do I need to run the generator or just keep an eye on battery level. And at what point should I crank up the generator?
Thanks in advance for this community of users
SB
SCARLET BISON
Silver 2014.5 Interstate EXT
scarletbison is offline   Reply With Quote
Old 11-29-2014, 08:37 AM   #2
mandolindave's Avatar
Hey SB
With a full battery charge, you should be good for 8 hours. The furnace blower depletes the battery more than any other stock equipment. Know that a battery reading 12 volts is considered dead. A resting voltage( about 8 hours after charging ) of at least 12.6 is considered full. While charging…your batts could be around 13.4 volts.
In answer to your question, crank up the jenny when you get close to 12 volts. I have a little cheap meter that plugs into the cigarette lighter style socket.
I recommend having two batteries, and unplug the trailer from the tow vehicle so you won't run down it's battery
mandolindave is offline   Reply With Quote
Old 11-29-2014, 02:34 PM   #3
UKDUDE's Avatar
Sedona , Arizona
Just keep an eye on the solar controller display panel..... press the black button repeatedly until it displays the battery charge in percentage. It's a matter of opinion, but my opinion is not to let it go below 50%.
UKDUDE is online now   Reply With Quote
Old 11-29-2014, 03:27 PM   #4
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
Hmmm ..... tailgate gathering ..... warming hut - I'm guessing door open and shut a lot - tours of the trailer - door left open a lot - pretty much all lights on - water pump running more than usual ..... I think I'd be running the generator from the get-go - then forget about any monitoring of the voltage and join the party .....
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 11-29-2014, 04:51 PM   #5
Thanks everyone for your hints and suggestions, There were a lot of tours and showing, there were other warming sources (patio heaters, fire pit). At one point the batteries appeared to be down at 65% so I cranked up the generator to give it some exercise. All in all a great afternoon.
SCARLET BISON
RVing in Cold Weather harryp Winter Living 30 04-06-2007 11:14 AM
Cold Weather Airstreaming gryphon Winter Living 38 04-16-2006 07:16 AM
LCD and Cold weather? balrgn Audio, Video & TV 4 12-18-2004 06:21 AM
Cold Weather Camping Bill & Barbara 2002 Safari 9 08-26-2003 10:29 PM
cold weather how do air streams do? overlander Our Community 2 10-02-2002 05:10 AM
