Old 12-24-2014, 05:43 PM   #1
2009 22' Interstate
Laguna Beach , California
Angry Class B ignition problem
Just puchased a 2009 (2008 Sprinter) Class B, and after storing for 4 weeks, cannot use key in ignition. Keys check out ok from MB shop, but will not turn in ignition. New batteries. Any suggestions? LaVaughn
LaVaughn is offline   Reply With Quote
Old 12-24-2014, 06:00 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forum.
Wiggle the steering wheel back and forth while trying to turn the key.
Old 12-24-2014, 06:47 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Also make sure the gearshift is fully in "Park".
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-24-2014, 07:03 PM   #4
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
The keys have a chip in the fat end which sends a signal to the ignition switch. If it doesn't match, the van won't start. You should still be able to turn the key, though. If you can't turn the key, it isn't cut correctly. If it turns but won't start, the key needs to be reprogrammed. You probably have to go to a Mercedes dealer, with your VIN number off of the dash plate, and have one made. I say one because they will be $125 or more each.
robert claus is offline   Reply With Quote
Old 12-24-2014, 07:42 PM   #5
Oh, nearly forgot… Since you say it's been in storage, look down by the accelerator pedal and make sure the chassis battery is connected. If the chassis battery is disconnected, the switch won't read the key's RFID chip and won't let you turn the key.
Same thing happens if the battery is connected but dead.
WBCCI #1105
TAC LA-4
Old 12-24-2014, 08:22 PM   #6
2000 19' Bambi
I know Sprinters, but not the intricacies of the Interstates, and so yield to Protag on this
Old 12-26-2014, 06:43 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
It also will not start if the side sliding door is not fully closed. The side door can appear closed, but not be fully closed. Open it and shut it firmly, then try the key again.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 12-26-2014, 07:15 AM   #8
I'm not sure about that one. Mine starts with the door not quite closed, but then gives me a red "Door Open" message on the dashboard display. Might be true for newer models, though.
WBCCI #1105
TAC LA-4
Old 12-26-2014, 07:55 AM   #9
2005 22' Interstate
Pittsburgh , Pennsylvania
Our 2014 will start with the side door open as well. It just complains about it.
Formerly: 2005 Airstream Interstate (2500 T1N)
Now: 2014 Great West Vans Legend SE (3500 NCV3)
avanti is offline   Reply With Quote
Old 12-26-2014, 12:39 PM   #10
m.hony's Avatar
2013 30' Classic
Jannie and Billie's is a 2004.
TAC #MS-10
Airforums #70955
Atwood water heater electronic ignition problem Deairstream Plumbing - Systems & Fixtures 0 07-09-2014 04:32 AM
Furnace Ignition Problem billberk Furnaces, Heaters, Fireplaces & Air Conditioning 25 01-12-2008 08:13 PM
Suburban Elec Ignition Question Problem. Deano69LY Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-10-2007 12:23 PM
Headlights 'ON' ignition switch buzzer Astrodokk Airstream Motorhome Forums 1 11-16-2003 05:11 PM
Ignition timing adjustment PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 9 04-20-2003 08:22 PM
