Old 05-25-2015, 10:32 AM   #1
gambita's Avatar
2015 Interstate Ext. Coach
Framingham , Massachusetts
City water connection AI 2015 help
Name:	ImageUploadedByAirstream Forums1432571412.470304.jpg
Where is the valve located to open so I can have city water coming in directly in the AI?
gambita is offline   Reply With Quote
Old 05-25-2015, 10:55 AM   #2
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
It's the one on the left in your picture. Not so much a valve but a screw-in thread for the white and blue potable hose that you received with your Interstate. It's also advisable to use an inline filter.
Old 05-25-2015, 12:15 PM   #3
gambita's Avatar
I attached the white hose Click image for larger version
Name:	ImageUploadedByAirstream Forums1432577601.151009.jpg
but for some reason it seems water is not flowing in. Is there a valve inside the Interstate I need to turn on?
Old 05-25-2015, 12:39 PM   #4
Ron_CA's Avatar
San Diego , California
Did you try turning the faucet on inside and then checking to see if water is flowing. It does not flow into a tank so if you aren't using, it's not flowing.
Ron_CA is offline   Reply With Quote
Old 05-26-2015, 08:14 PM   #5
gambita's Avatar
City Water Connection R&SZinser Fresh Water Systems 14 08-20-2012 05:30 PM
water dripping from city water hose attachment location when NOT hooked up to city wa Wilmington Plumbing - Systems & Fixtures 1 03-19-2012 09:25 PM
City Water Connection to Potable Tank? Motoman Fresh Water Systems 2 12-19-2006 06:22 AM
Leak Under City Water Connection JDL Fresh Water Systems 8 08-14-2006 01:16 PM
New City Water Connection j54mark Fresh Water Systems 5 07-01-2002 07:03 AM
