Old 01-26-2016, 08:21 AM   #1
Dalwyn's Avatar
2015 Interstate Grand Tour
Southaven , Mississippi
Cigarette power adapter splitter
Quick question. I have two items that need power from the cigarette lighter, a dash cam and tpms monitor. Has anyone used a cigarette power adapter splitter? If so, which brand? I am trying to keep from having to hard wire the tpms monitor.
Dalwyn is offline   Reply With Quote
Old 01-26-2016, 09:16 AM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I have a bunch of older vehicles with only one lighter socket. I use a splitter all the time. I just get whatever brand has the style and price I like.
CRH is offline   Reply With Quote
Old 01-26-2016, 09:24 AM   #3
Francisco , Indiana
Amazon is your friend.
Robot Check
Hickory
hickory is offline   Reply With Quote
Old 01-26-2016, 09:26 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
You should already have no less than four 12v power sockets.
1 - in the pull-out cup holder in the center dashboard, power controlled by ignition key.
2 - closer to the floor, low center dashboard, always-on.
3 - base of the driver's seat near the parking brake lever, always-on.
4 - front overhead compartment above and behind driver, far left. Though this one might have gone away in newer models when they started mounting a blu-ray player up there. I think this one is powered by the house batteries, but haven't really checked because I've never used it while the vehicle was in motion.
I have a splitter just in case, but I've never needed it.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-26-2016, 09:41 AM   #5
Dalwyn's Avatar
Thanks for all the replies. I really need to get better acquainted with my vehicle. :-) Just as a side note I purchased the TST TPMS and Mike Benson was great to work with.
Old 01-26-2016, 11:03 AM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
You can get a "cigarette lighter" type splitter/adapter at a good auto parts store. Most are fused at 5 amps. I changed the fuse to 10 amps so I could run my TV, no problems.
Old 01-26-2016, 11:59 PM   #7
albuquerque , New Mexico
Swap20 amp fuse for 5 smp
The only problem with that is wiring overheating with higher amp fuse. Watch closely.
splintair is offline   Reply With Quote
Old 01-27-2016, 06:40 AM   #8
The T1N only has two of those outlets up front - one always-on in the dash next to the map holder, and the other in the traditional place in the ash tray. However, the ash tray outlet cannot be used whenever cups are present, as the cups block it from opening. As cups are present 100% of the time, it can never be used. One day I will find a workaround for this.
Meanwhile, this specific product was recommended... somewhere. Perhaps on WDYGFYTT. It's the one I use. Number one best seller, they say, for what that's worth.
http://www.amazon.com/Powerful-Omake.../dp/B00OZ5OIFE
Old 01-27-2016, 07:11 AM   #9
Lily&Me's Avatar
Normal , Illinois
We bought one of these a number of years ago, when heading into the Rocky Mountains to boondock for several weeks, and it has worked well.
We charged the phone, IPsd, and sometimes the hand vac, all at the same time.
We did find out the hard way, tho, that leaving this plugged in will drain your battery pretty severely, so unplug when not in use.
Maggie
Old 01-27-2016, 07:45 AM   #10
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Whatever they have at Walmart or auto parts stores or Radio Shack- 6 of one, half dozen of the other-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-27-2016, 10:40 AM   #11
2014 25' Flying Cloud
Cohasset , Massachusetts
Thumbs up splitter for the cigarette lighter
I bought mine at West Marine. It is very useful on the boat, TV and Airstream! It was NOT inexpensive!
Tan Son Nhut is offline   Reply With Quote
Old 01-27-2016, 10:59 AM   #12
Lumatic's Avatar
1993 34' Excella
Images: 16
The circuit is already fused to 20 amp at the distribution box so the wiring to the 12v outlet overheating is not an issue. I believe the wiring to the outlet is 12 gauge which can more than handle a 10 amp load. The wiring on my splitter is also #12 and I really only use half the splitter to run a inverter for my small flatscreen which draws less than 10 amps , but more than 5.
By the way calling those 12v outlets inside the coach "cigarette lighters" is a bad idea. People have put cigarette lighters into them and overloaded their wiring. It is only a 12 v outlet
Old 01-27-2016, 12:32 PM   #13
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
By the way calling those 12v outlets in the coach "cigarette lighters" is a bad idea. People have put cigarette lighters into them and overloaded their wiring. It is only a 12 v outlet
Old habits die slowly.
While a cigarette lighter element may draw more current than the circuit can support (the circuit fuse should protect the wiring), the real danger of putting a lighter element in the 12V power receptacle comes from the heat it generates within the receptacle. Modern receptacles are usually made of plastic and are not designed to withstand the heat a lighter element generates that older metal based receptacles could. Note, this is not always the case. Hopefully your vehicle owners manual will clarify what can be used in the receptacle.
Greg
greghoro is offline   Reply With Quote
Old 01-28-2016, 07:11 AM   #14
Dalwyn's Avatar
Appreciate all info provided. I ordered one from Amazon and as soon as the temperature warms up intend to find all the outlets in my coach.
Lights quit working after plugging cell phone charger into cigarette lighter hagnik Lights - Interior & Exterior 6 06-20-2011 10:57 AM
Different DC Cigarette Plug Receptacles? rseagle Electrical - Systems, Generators, Batteries & Solar 5 08-14-2010 08:03 AM
TV Cable/Splitter Ugly1 All Squarestream Trailers 2 10-12-2009 01:23 PM
digital tv: splitter or amplifier? Chuck Audio, Video & TV 2 07-08-2007 05:46 PM
Cable Splitter jhobbs Electrical - Systems, Generators, Batteries & Solar 6 10-14-2005 12:02 PM
