Old 06-22-2015, 11:08 AM   #1
2015 Interstate Ext. Coach
Tulsa , Oklahoma
checking generator oil
As a new user, I hope someone can tell me the best way/ easiest way to check my generator oil & add oil if necessary.
TulsaBob is offline   Reply With Quote
Old 06-22-2015, 05:40 PM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Welcome to the Airforums.
Some say you need to remove the spare. I didn't. I backed mine to the end of the driveway so the rear was hanging out over the street which gave me ample clearance to crawl under. Remove the rear panel on the Onan which gives access to the dipstick and fill port. The drain plug is on the bottom towards the right front corner of the Onan. I used an oil suction gun that's normally used to suck oil out of a differential that doesn't have a drain plug. I put the quart of Onan oil in it and placed the tube in the fill port and squirted it in. Check the Onan manual that should have come w/ your AI for verification cuz Airstream changed gensets after mine was made.
Old 06-22-2015, 05:58 PM   #3
ben322's Avatar
2009 Interstate
Bethesda , Maryland
Also checking the oil is done without screwing the dipstick in which is typical for many small engines.
2009 Airstream Interstate
ben322 is offline   Reply With Quote
Old 06-22-2015, 06:12 PM   #4
Ron_CA's Avatar
San Diego , California
Yep my spare was in the way and would not allow me to remove the dipstick without first partially lowering it.
I chalked it up to learning how to access the spare tire but was kinda scratching my head as to WHY did it have to be this way????
Ron_CA is offline   Reply With Quote
Old 06-22-2015, 06:54 PM   #5
Tulsa , Oklahoma
Thanks for the response. Gen manual says check oil every 8 hrs! Yea, sure ��
Relorton is offline   Reply With Quote
Old 06-22-2015, 08:00 PM   #6
73shark's Avatar
Also mine says to change after the first 20 hours and every 150 hours after that.
Old 06-23-2015, 11:07 AM   #7
Tulsa , Oklahoma
Welcome Bob,
Theoretically the oil level should be proper as you just purchased the coach.
Once again and welcome to Airstreaming!
Road Jager
Road Jager
Living On Tulsa Time
RoadJager is offline   Reply With Quote
Old 06-23-2015, 05:16 PM   #8
ben322's Avatar
2009 Interstate
Bethesda , Maryland
All's well in theory. Mine was slightly low which would allow the generator to run but stall when the AC was turned on. Checked the oil level and it did show on the bottom of the stick so I changed the oil and brought the level up. No more stalling.
Old 06-27-2015, 01:01 PM   #9
Dalwyn's Avatar
2015 Interstate Grand Tour
Southaven , Mississippi
TulsaBob - Did you manage to check the oil level? I also have a 2015 Interstate Ext and want to check the oil level. The only way I can see to check it is to remove the spare. If there is another way I would appreciate any knowledge anyone would care to share.
Even if I remove the spare and leave it in the garage, I will not be checking the oil level every day.
Dalwyn is offline   Reply With Quote
Old 06-27-2015, 07:26 PM   #10
Ron_CA's Avatar
See post #4 Above. Once you lower the spare down a little it will be hanging on the cable and you can push the spare back an inch or two, to allow you to remove your dipstick and check your oil.
You won't need to check it every day.
Old 06-27-2015, 07:44 PM   #11
Rockwell , North Carolina
I did not have to lower my spare to check the generator oil on my 2014 EXT. The cover can be removed with the spare in place and I could then remove the dipstick. To add oil I used an old fashioned oil can squirter.
jerhofer is offline   Reply With Quote
Old 06-27-2015, 08:30 PM   #12
Dalwyn's Avatar
I did try that, but I couldn't find a way to remove the dip stick. I am going to try and drop the spare a little tomorrow and see how that works.
Thanks everyone for replying.
Old 06-27-2015, 10:33 PM   #13
Tulsa , Oklahoma
Thanks everyone - no easy way. Find a lift and some help ��
To oil or not to Oil woodyarn General Repair Forum 14 08-03-2012 08:05 AM
Does the amount of engine oil increase with the addition of a larger oil cooler? Mr. D Mechanics Corner - Engines, Transmission & More... 5 03-07-2009 08:56 AM
Vege oil in a honda generator??? silver suz LP Gas, Piping, Tanks & Regulators 27 06-09-2004 12:07 PM
Oil in Generator Question flyfisher Generators & Solar Power 4 12-29-2003 03:50 PM
