Old 07-14-2015, 04:25 PM   #1
gambita's Avatar
2015 Interstate Ext. Coach
Framingham , Massachusetts
Check engine light, 10 starts remaining
I guess this problem is common
Name:	ImageUploadedByAirstream Forums1436912634.309777.jpg
ID:	242973Click image for larger version
Name:	ImageUploadedByAirstream Forums1436912667.675051.jpg
gambita is offline   Reply With Quote
Old 07-14-2015, 06:39 PM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Have you filled your DEF tank?
Old 07-14-2015, 07:36 PM   #3
2013 Interstate Coach
Raymond , Iowa
Maybe more than you wanted to know:
This message is courtesy of your friends at the US EPA. DEF is required to make the Selective Catalytic Reduction (SCR) system work. SCR reduces NOx (a precursor to ground level ozone or 'smog') to N2 and O2. DEF is consumed at about 2% of the rate that diesel fuel is consumed. So the 6-ish gallon DEF tank will last about 300 gallons of fuel. About 6000 miles +/-. The engine runs just fine without DEF. The DEF costs about $3 per gallon and those driving the Sprinter many many miles per year and using it to make money might be tempted to not fill the DEF tank, and save less than a penny of DEF per mile driven. So EPA reguires the engine manufacturer to somehow force the driver to refill the DEF. MErcedes does so by preventing restarts when the DEF is empty - hence your 10 restart warning. Others may choose to limit vehicle speed to 5 mph when DEF is low/empty. Unfortunately (IMHO) Mercedes chose not to have a DEF level gauge, so you have no idea when DEF is getting low until you get the 10 restart message.
Titus is offline   Reply With Quote
Old 07-14-2015, 07:56 PM   #4
Ron_CA's Avatar
San Diego , California
Usually when it is DEF the display will say so. I think it may be something different. I can't tell what the symbol is that it is displaying.
Ron_CA is offline   Reply With Quote
Old 07-14-2015, 07:59 PM   #5
73shark's Avatar
IIRC, the first DEF message is for 25 starts. FWIW, I get about 10K miles on the five gallon tank. YMMV.
Best to get scanned for any DTCs
Old 07-14-2015, 10:43 PM   #6
gambita's Avatar
I just had my 15k service A 2 weeks ago
Old 07-15-2015, 12:45 AM   #7
lewster's Avatar
Naples, FL , Hood River, OR
I had that happen to me a few months ago, when the DEF countdown indicator showed 9 starts remaining. I had filled the DEF tank about a month prior, but found more and added a couple of pints. The clock remained at 9 after 3 more starts, so I knew there was an electronic problem.
Took it to Mercedes the next day and they re-flashed the ECU and all was good. HOWEVER, I have had more repair bills for DEF related issues, things like bad pre-heater, bad injection pump and bad level sensor than with any other part of the van. Now at 120,000 miles.
PS: the symbol in your second shot is the indicator for a DEF issue. All of the warning symbols are listed in your Sprinter owners' manual.
Old 07-15-2015, 05:05 AM   #8
Raymond , Iowa
That symbol (and ice cream cone on its side, hovering over a body of water) is the universally recognized (or not) symbol for DEF. A somewhat similar looking symbol with a bunch of dots over the ice cream cone (which is supposed to represent the exhaust pipe) is supposed to alert you to issues with the particulate filter.
In addition to the Mercedes commercial warranty there is also an EPA-mandated (and CARB mandated if you are so unfortunate as to live in California) emissions warranty. That (longer?) emissions warranty may keep you from having to pay for SCR-related repairs.
Old 07-15-2015, 04:08 PM   #9
gambita's Avatar
The problem was the nox sensor.
The DEF was full .
See details below
Name:	ImageUploadedByAirstream Forums1436997918.851340.jpg
ID:	243067Click image for larger version
Name:	ImageUploadedByAirstream Forums1436997945.213493.jpg
Old 07-15-2015, 04:12 PM   #10
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
All these reports of diesel emission problems remind me the early days of gas emission controls back in the 70s.
Old 07-15-2015, 04:56 PM   #11
Muskogee , Oklahoma
Curious. Did you happen to use biofuel and if so, was that when the NOX sensor's failed?
The DEF was full .
See details below
Attachment 243067Attachment 243068
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 07-15-2015, 05:17 PM   #12
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
The Sprinter seems rather prone to issues like this. I wonder if diesel Mercedes cars have the same problems. Our diesel Touareg is 18 months old and so far has never experienced any of these things.
Old 07-15-2015, 05:35 PM   #13
73shark's Avatar
My AI is almost five years old and that is one problem I haven't had. Not that I've had many problems with the MB part. My issues are on the Airstream side.
Old 07-15-2015, 09:26 PM   #14
Kwils25's Avatar
Taylor Ridge , Illinois
The DEF was full .
See details below
Interesting, I just had the same issue with my 2014 AI. DEF error and my DEF tank was close to being full. Had it serviced yesterday. It was warranty work also, but the dealer included costs on the invoice. Parts and labor came to $835. Glad I didn't have to pay for it. I hope this isn't a reoccurring issue.
Kwils25 is offline   Reply With Quote
Check Engine Light - 2000 Yukon funkill Tow Vehicles 18 07-23-2012 03:27 PM
check engine light lefounta Classic Motorhomes 2 11-26-2009 08:57 AM
Engine starts, but won't restart, starter sheared off dalefox Classic Motorhomes 31 08-24-2008 09:45 AM
Remaining Naked after Stripping? Becky B. Cleaning, Stripping & Polishing 8 03-25-2008 08:35 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
