04-19-2015, 06:50 PM
2013 Interstate Coach
arlington heights
CB radio for the Interstate
As we recently put 7000 miles on our "ASI", I spent the entire trip looking at the space above the dash which seems perfect for a CB radio. Has anyone installed one? If so, I have some questions. First, is there anything worth listening to (e.g. traffic, accident info, route advice, etc.)? Years ago, one could actually have a group of friends that were met on the radio but I wonder if that environment still exists. Second, was the installation difficult? And third, where did you place the antenna?
Paul & Doris
04-19-2015, 07:08 PM
Southwestern
, Ohio
We don't use our CB radio very much but it's mighty handy when we need it.
WBCCI uses CB channel 14 for communication on caravans and it's both handy and fun. Everything depends on how heavily the channels are used. In heavily populated areas there is so much traffic it's unusable. Out west you often have a channel to yourself and in the absence of interference I have worked 20 miles mobile-to-mobile.
The other place where CB comes in handy is when there's a traffic jam on the highway. Listening to the truckers on channel 19 will give you some real-time information to help you decide to stick it out or find an alternate route.
The best place for your antenna is right in the middle of the roof, where it has a clear line of sight in all directions and the roof makes a good ground plane. I have a 3-foot K40 fiberglass spiral antenna mounted in the middle of the fiberglass cap of our pickup truck tow vehicle. I created a ground plane out of sticky-back copper tape on the inside of the cap and it works fine.
Not being familiar with the Interstate I don't know how you go about mounting an antenna on the roof, but I'm sure there's a way.
04-19-2015, 07:42 PM
2004 30' Classic Slideout
Fenton
, Missouri
I had a CB for years until the advent of good cellular service. Unless you travel with others, and want to talk to many at one time, I just don't see the need for CB in this day and age. I preface all this with the fact that you have a cellular carrier that has good service on and off the interstates.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
04-19-2015, 07:43 PM
1999 34' Excella
Hillsboro
CBs eere fun.... if you aren't easily offended by bad words, they can provide company on long stretches and road/traffic Intel.
I have installed antennas on fiberglass roofs by building a "ground plane" with aluminum tape... It important for you to have that for decent range. But there are great websites for CBs install and use.
Good luck with decision!
Peace and Blessings..
Channing
WBCCI# 30676
04-19-2015, 07:56 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
The slot over the windshield is a 1DIN size; you can find in-dash CB radios in that size, but CBs that are designed for under-dash mounting are all too big to fit that space.
In my opinion, given all of the clutter on the roof of an Interstate, the best place to mount the antenna would be right where the Sirius XM antenna is located; assuming you don't subscribe to Sirius and don't mind losing the Sirius antenna. That way you already have a roof penetration to use, and an easy run from there to the CB radio. Given that the roof on the Interstate is already 9 feet up, you'd want to use a relatively short antenna.
04-20-2015, 07:03 PM
2014 25' International
2010 22' Interstate
Carol Stream
I use a handheld walkie talkie/CB radio. I don't get the range of a roof mounted antenna unit but it can be useful. Years ago I used the CB radio routinely, not anymore. There are many apps for the cell phone now.
Good luck
04-20-2015, 08:07 PM
2024 Interstate 19
Fulton
, Maryland
A fellow over on the Sprinter-Source forum posted pictures of their installation of a CB in the overhead of a Winnebago ERA. He used a Cobra 19 Ultra III.
Go to this page and start reading a post #157
Tips & Tricks for the Winnie ERA - Page 16 - Sprinter-Forum
Also I'm attaching the page from a Sprinter Option Book that shows the connector terminal details.
04-20-2015, 08:45 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Go to a CB shop where truckers go, buy a Ranger or a Northstar "ham" radio and have the shop "convert" it to CB.
It will transmit 45 or 50 watts instead of the 5 watts CBs transmit.
Get a good antenna and you can reach out ten or fifteen miles instead of a couple hundred yards.....
The "ham" radios these shops sell were built knowing they would be changed to CB. Much better quality and reach than the Cobra units they sell at WalMart and truck stops.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
04-20-2015, 09:42 PM
2016 28' Pendleton
Scottsdale
Hi from AZ. . . no offense to Mr. Morgan, but using 45-50 watt transmitters on The CB channels is against the law. Supposed to be limited to 5 watts output. And with smartphones & a zillion apps, I see no reason to put up with crude language & inane BS that seems pretty constant on CB's. And my GPS unit advises about upcoming traffic problems. just sayin. . . Craig
WBCCI 2851,4CU
04-20-2015, 10:56 PM
2007 22' International CCD
Corona
Those conversions are flat out illegal. And are part of the reason CB is such a zoo.
Want high power-get a ham radio license.....and be legal.
04-21-2015, 06:43 AM
1972 31' Sovereign
Benton
, Arkansas
I know they are illegal....
But still, a 5 watt CB wont reach more than a few hundred yards.....
Now, back before the FCC reduced the wattage from 10 to 5 watts a legal CB was at least practical...
The law has made a legal CB impotent, so, the law created a market for illegal radios.
As far as the trash talk goes, there is some of that no doubt, but at least with a respectable transmitter, a person can step on it.
04-21-2015, 06:45 AM
1972 31' Sovereign
Benton
, Arkansas
I will be 50 next year, in all of my life I never knew anyone who got in trouble for an illegal CB radio... I am betting that no one on this forum has either.
04-21-2015, 08:25 AM
From All Over
That's still not an excuse to broadcast at ten times the legal wattage. There may not be as many CBs out there, but drowning out every other conversation within a mile radius is still rude to people with legal CBs who might have something important to say. Just because they're legal and you can't hear them is no reason to force them to hear you.
04-21-2015, 09:29 AM
2024 Interstate 19
Fulton
, Maryland
All the illegal CB users is one of the reasons I won't use CB again. I've used them a few decades ago and they were useful on several cross-country moves driving two family vehicles.
There is no one enforcing CB users so it's like the Wild Wild West. Ham radio is at least self-policed by other operators.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
04-21-2015, 09:35 AM
1972 31' Sovereign
Benton
, Arkansas
Fifty watts wont drown everyone out for miles, it doesn't work that way, besides, proper edict is to talk one at a time and to take long conversations to different channels.
Now when you get up around 250 watts... That will tend to dominate for a few miles.
04-21-2015, 09:40 AM
1972 31' Sovereign
Benton
, Arkansas
Like I kinda said above, (in so many words) there were few illegal radios out there before the gomm'ent decided that ten watts was too much and all new radios were regulated into worthless 5 watt units that have trouble reaching two hundred yards...
Stupid law incites lawlessness.... (Five watt radios did as much to kill the CB radio craze as the end of the "fad")
And even so, these "converted" radios are capable of having the transmit power turned down with the twist of a knob, although I will admit to transmitting at the full fifty when I would key up. This wasn't often, I wasn't really gabby on a radio.
(Hmmmuh,,, what is the statute of limitations regarding illegal transmission power on a CB radio anyway?
Did I just open myself up to prison time here? I am such an outlaw! )
04-21-2015, 10:26 AM
From All Over
Okay, some hyperbole there— inverse square law still applies— but the point is still sort-of valid. Your range would be a bit over three times as far as with a legal CB, if your antenna has adequate line of sight to that distance.
Which means that for two-thirds of your broadcast range, you'll be broadcasting to people you can't receive from. Which means that you'll step on their signals without realizing it.
04-21-2015, 11:41 AM
1972 31' Sovereign
Benton
, Arkansas
Unless they have a 50 watt transmitter also...
Five watts on the CB band is incredibly anemic.
Three times the distance might be three miles in average conditions. About enough time to mutually say "hello hows it going" with very brief answers to a friend going the other way, but that is about it.
I can not overstate how pitiful 5 watt CB transmitters are....
04-21-2015, 11:50 AM
Durango
Actually with a good antenna system 5 watts is more than adequate.
I have used packet ham transmissions of 5 watts to carry on text exchanges with other operators in New Zealand from Durango, Colorado.
Most people have very poor mobile antenna systems with very poor ground planes.
A little work with proper antenna placement, RF Grounding, bonding, and tuning will yield better results than just throwing more power at a poor antenna.
04-21-2015, 11:58 AM
1972 31' Sovereign
Benton
, Arkansas
A bit of "BIG RADIO" CB trivia;;
For a long time, a period of several years, there was a regular transmission over the CB radio that could BOLDLY be heard anywhere coast to coast.
Some guy who was rumored to be in Oklahoma had a very powerful transmitter that was programmed through a computer to FREQUENTLY deliver an automated message...
The message was always the same. It was delivered in a male voice with a strong southern accent so frequently that I have it memorized verbatim...
"I have my nightgown on and I have my pretty red panties on, and I am ready to go to sleep... "
Yea it got annoying after a while. No telling how big that amp was, but it was big... Rumor has it that the FCC finally shut him down....
