01-27-2019, 02:08 PM
2015 Interstate Grand Tour
Rancho Mirage
Caution Do Not Launch Boat with Sprinter Interstate
Launched our boat at boat at Lake Powell in September. Went to use the Sprinter and tried to run the generator. It would not crank over so I put it on the lift in my shop and started to troubleshoot what could be wrong. Wound up dropping the generator down and found that the engine appeared to be froze up. Ultimately was able to turn the engine over with a socket on the end of the crank and it began burping water out of the carburetor, then I looked at the air cleaner and found that it was moldy. I was trying to figure out how the heck the generator could have gotten flooded with water and then I remembered our trip to Lake Powell. Bottom line, do not use your Sprinter to launch a boat. Boy do I feel dumb.
01-27-2019, 02:28 PM
2018 Interstate Lounge Ext
LV
, Nevada
MAIL4SBLAIR - Sorry to hear. And thanks for the tip. Glad you got it to turn over. Hopefully, I assume no long term damage? BTW - if I listed every dumb thing I did since owning my AI, I would be run out of this forum Seriously though, I think everyone has had their 'not so proud moments' . Good thing for me is I can no longer afford a boat after buying the AI. We have 1st world problems, for sure.
BTW - along these lines, ONAN also does not recommend using the gen when driving in rain (and I assume even if parked, if heavy rain and water is under the gen). They are bottom breathers and will suck water in. Did not know that until I read their manual.
01-27-2019, 03:21 PM
2012 25' FB Eddie Bauer
Southwestern Ontario
, Ontario Canada
I put a huge mud flap in front of mine. I drove it 12 months of the year including Canadian winters and could always use the genny rain snow etc. No problem.
01-27-2019, 04:01 PM
Rancho Mirage
I was able to turn it over by hand, but I'm sure the engine is ruined and rusted, given that it's had water in it for 5 months. The starter would not turn over with direct power to it, and i'm sure the circuitboard is bad. I'm pricing a new replacement now.
01-27-2019, 05:47 PM
LV
, Nevada
MAIL4SBLAIR - I am on the road now, so I have limited time to search. But if you do some searching in this forum, you will find many owners of brand new rigs thinking of eliminating their gens altogether. In fact, I am one who is currently thinking of the Volta system if only they can give me a provider in/near my region. Unfortunately, those conversions take forever and definitely too long for your needs. Sorry to hear all is lost
01-27-2019, 07:11 PM
2013 31' Classic
billings
, Montana
Remove..take it apart...maybe new rings and bearings....
01-28-2019, 10:22 AM
2017 30' Flying Cloud
Spotsylvania
, Virginia
You must of had the a$$ end of your coach in the water to get water in the generator or there is no protection from rain or snow to keep the generator dry.
We looked at a small Class C and when I found out the generator was under the coach I kept on walking, much to hard to service.
01-28-2019, 11:23 AM
Box Elder (formerly Long Island, NY)
, South Dakota
At least you didn't launch the AI along with the boat.......
01-28-2019, 02:49 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
I had an air-cooled airplane engine to get flooded. All that was done to get it airworthy was to flush the crankcase with fresh oil, cleanup the electronics start and run the engine for a few minutes, change oil and repeat for 30 minutes, and change oil again. Years latter the engine was still good. I would not try to turn over the engine by hand, you might bend a rod or two. Pull the plugs, oil the cylinders, then rotate the crank to be safe.
guskmg
01-28-2019, 05:39 PM
Rancho Mirage
Engine had water in on top of the piston, in the exhaust and down in the case. Rather than rebuild it and not knowing about the electronics, I've decided to replace it with a new unit. Proof that S**t Happens. If I had discovered it right away I probably could have saved it, but there was quite a bit of corrosion from water sitting in it for 5 months. Just means there won't be as much left for the kids when we're gone.....lol.
01-28-2019, 07:53 PM
2012 Avenue Coach
Corpus Christi
Ha ha. I've told my kids it's a good thing we never know our time of death. Otherwise, their mom and I would spend everything and leave just enough in our accounts on our final day to bury us.
01-29-2019, 03:12 AM
Sag Harbor
, New York
. . . but there was quite a bit of corrosion from water sitting in it for 5 months.
Good move to get a new unit!
Thanks for the update.
Peter
01-29-2019, 03:17 AM
Sag Harbor
, New York
OT
Some older folks do the following, after first warning their kids:
-- pre-pay funeral etc. expenses [or set up a small fund]
-- cash out most assets incl. house etc.
-- buy annuities from ultra-safe insurance etc. company
. . . and live off the annuities until the magic moment.
01-29-2019, 05:21 PM
LV
, Nevada
MAIL4SBLAIR - contact user CHRISCOW. Looks like he has an unused one he wants to part with.
01-30-2019, 10:42 AM
Ninety Six
, South Carolina
Omg...thanks for the information....i can see how that could happen without thinking about the generator! Thanks again!
