Old 06-26-2014, 09:46 AM   #1
2010 22' Interstate
Vincennes , Indiana
Carrier Air Conditioner Thermostat
Having trouble with Carrier air conditioner thermostat in my 2010 Interstate.
Any idea where I can get a replacement?
aa9zz is offline   Reply With Quote
Old 06-26-2014, 11:11 AM   #2
BikerBill
2014 Interstate Ext. Coach
Poconos of Pa , Pennsylvania
Google online but more than likely from AMAZON.
Bikerbill is offline   Reply With Quote
Old 06-26-2014, 03:29 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
My 2012 Interstate manual says that the thermostat is wired to a 5amp breaker on the front of the furnace. May want to check that first before you go looking for a new thermostat.
WHY it's wired to a breaker on the furnace, and not to a fuse on the house fuse panel, I don't know. But that's what the manual says. And since the same thermostat controls both A/C and furnace…
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-26-2014, 07:24 PM   #4
2010 22' Interstate
Vincennes , Indiana
Thanks Protag, I appreciate and trust your advice.
I took the unit to an area RV repair and they told me the thermostat was ten degrees off. If I set it to 60 it will cool to 70. I haven't used the air since April but it worked fine then. I'll give it a little testing over th weekend. I plan to do a little traveling to northern Indiana.
Air Conditioner / Furnace Thermostat aa9zz Sprinter and B-van Forum 15 10-08-2013 11:03 AM
Picture of Air Conditioner Thermostat Splitrock Furnaces, Heaters, Fireplaces & Air Conditioning 1 11-13-2010 02:25 PM
installing the thermostat upgrade on Carrier shermantic Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-03-2009 09:57 AM
Air conditioner thermostat working? nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 7 03-18-2004 07:37 PM
