Old 08-01-2015, 08:17 AM   #15
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
My CO detector started beeping yesterday for no apparent reason. 2 loud beeps every 30-40 seconds. The manual says it means something like "end of life". This is a wired detector.
I turned off the coach batteries and removed the 9v internal battery, but it's continuing to beep!
I haven't found a way to stop it since the labels on it discourage opening it up. Any ideas?
Old 08-01-2015, 08:50 AM   #16
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Carbon Monoxide Detector
You also have to remove the 12V wire to the detector - it should be accessible if you remove it from the ceiling.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
Boxster1971 is online now   Reply With Quote
Old 08-01-2015, 10:59 AM   #17
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
That's interesting because when I turn off the house batteries, my CO detector no longer responds to the test button. Need to dig out the manual on it and see how it's set up.
Old 08-01-2015, 11:49 AM   #18
UKDUDE's Avatar
Sedona , Arizona
- - Mike
Ah yes, I hadn't spotted that if you carefully pull out the wires that go up into the ceiling, there's a plastic connector. Silence at last! Thanks Boxster.
Incidentally, when I completely removed the detector, it continued to beep until I removed the battery.
Mine has 3 wires going to it, which look like chassis 12v, coach 12v and ground. I think I read somewhere they may now be using household-style battery-only versions.
Old 08-01-2015, 02:24 PM   #19
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
One step forward, two steps back. My 2012 Interstate has a battery-only CO/smoke detector. Two AA batteries last about a year.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-01-2015, 02:25 PM   #20
73shark's Avatar
I erroneously said my CO detector when I really meant my propane detector in Post 17 above.
Old 08-01-2015, 04:48 PM   #21
toskeysam's Avatar
Townsend , Tennessee
I also had a CO detector fail. Rather than try again with another one....tech recommended replacing with identical (but battery only) one. The only rub was that warranty would only cover replacing like-for-like so I just bought the battery unit.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 08-02-2015, 11:11 AM   #22
Carlsbad , California
I also replaced mine with a battery powered unit (found on amazon).
02interstate is offline   Reply With Quote
Old 08-02-2015, 11:23 AM   #23
MaineStreamer's Avatar
2007 20' Safari
Saco , Maine
My 2007 First Alert CO detector (3 AAA batteries) started beeping this week and wouldn't stop unless I took it outside and waved it around. Battery replacement didn't help. It had some corrosion on two connections apparently from the prior owner having one or two leaked batteries sometime before I bought the Safari last year. First Alert customer service didn't even have specs for this unit anymore, but told me that their units now have 5- or 10-year warranties, and they consider the warranty period to be the usage life, so my old unit should be replaced no matter what caused the beeping. When fooling around could result in my death, I will follow their advice and replace the unit.
Marty Womer
Saco, Maine
MaineStreamer is offline   Reply With Quote
Old 08-02-2015, 01:07 PM   #24
Raymond , Iowa
they replaced our hard-wired one with a battery-only under warranty.
Titus is offline   Reply With Quote
Old 08-02-2015, 02:53 PM   #25
73shark's Avatar
FWIW, most, if not all, smoke detectors are only considered good for ten years from date of manufacture due to the half-life of the radioactive element used in the sensor.
Combination Carbon Monoxide and Smoke Detector Recall PaulnGina Off Topic Forum 4 02-14-2015 08:32 PM
Carbon monoxide detector/alarm replacement Alphonse General Repair Forum 6 02-04-2013 06:43 AM
Carbon Monoxide Detector and strange smell frscott Furnaces, Heaters, Fireplaces & Air Conditioning 11 10-19-2009 09:22 AM
Carbon Monoxide Detector Silver Threads LP Gas, Piping, Tanks & Regulators 29 06-20-2007 12:24 AM
Carbon monoxide detector...mystery story drcharles2 General Interior Topics 9 11-21-2005 02:50 PM
