Old 06-15-2015, 05:31 PM   #1
2015 Interstate Ext. Coach
league city , Texas
cant find control unit for Awning
Still searching for awning control unit for 2015 Interstate Touring Coach. Read a thread that said it was in the cabinet with generator start switch and tank controls and its not there. they have moved that cabinet in the 2015.5 model . Anyone have an idea where they could have hide the control unit? I need to adjust the sensitivity on the auto retract for awning.
kwhatley is offline   Reply With Quote
Old 06-15-2015, 09:21 PM   #2
Kwils25's Avatar
2014 Interstate Ext. Coach
Taylor Ridge , Illinois
On my 2014 Interstate the generator, water heater and electrical controls are in the curb side upper compartment behind the wardrobe. The awning controller is behind the panel with those switches and gauges. Perhaps yours is in that compartment somewhere. I have also heard on some models, the awning controller is under the front passenger seat.
Kwils25 is offline   Reply With Quote
Old 06-16-2015, 11:11 AM   #3
league city , Texas
Thanks, called customer service and they moved the control unit to the upper rear compartment. you have to remove the upper panel in that compartment and reach up under the insulation on the forward curb side of that compartment. I don't think they could have hidden it better if that is what they were shooting for. I set adjustment to 9 so I will see how that works.
Old 06-16-2015, 07:20 PM   #4
Kwils25's Avatar
Keep your eye on the awning in windy conditions. If it is not sensitive enough to retract in stiff wind gusts you could incur some expensive damage. Last year I adjusted mine from the factory setting of 5 to 7. I'm very happy with that setting. Now it doesn't retract when I close the sliding door but does retract when a decent gust hits it.
Location of Control Unit for Fiamma Awning for 2014 Ext? Kwils25 Sprinter and B-van Forum 10 08-16-2014 08:55 AM
cant find vin harrison Title, VIN & Registration 13 04-26-2011 05:04 PM
I cant get the awning to open....... vwrhoden Awnings 7 02-23-2011 03:02 PM
Ok cant find info on Propane tank tie down? Mrcrowley Exterior Restoration Forum 2 11-28-2008 09:10 PM
Cant Find Water Pump! Navigator Water Heaters, Filters & Pumps 2 11-16-2003 01:18 PM
