Old 03-22-2016, 06:20 PM   #15
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Originally Posted by CruizinDux View Post
UKDUDE, any chance of a photo of your install?
I recommended this magnetic catch after seeing it at an RV show in Phoenix but haven't installed it myself. In my Interstate Lounge/Wardrobe I have just one lower drawer and the original catch is still very firm.
Old 03-23-2016, 06:23 PM   #16
2016 25' Flying Cloud
2010 20' Flying Cloud
Los Gatos , California
We just had a large pots/pans drawer built in for our 2016 FC25FB. I was concerned that the drawer would be flying open when going around corners.
The guys at Ultimate Airstreams added an additional drawer lock/latch to prevent that from happening. So far it has worked well. There are no latches or exterior modifications, it's all inside on the back of the drawer take a look at the photos.
These are the standard drawer stays the Airstream uses.
IMG_2082.JPG IMG_2090.JPG IMG_2089.JPG IMG_2091.JPG.
Notice there are 2 drawer stays on the top drawer and 3 drawer stays on the pots and pans drawer. Our remodel guy Spencer said that each latch has about ten pounds of stay power. So three stays provide 30 pounds plus of holding power which has worked for us to keep the heavy drawer closed. There is room on the back of the drawer for several of these if you need more holding power.
ID:	259264   Click image for larger version
ID:	259266   Click image for larger version
TerryC is offline   Reply With Quote
Old 03-23-2016, 08:18 PM   #17
Long Island , New York
Thanks for the photos Terry and for updating your thread:
http://www.airforums.com/forums/f516...fb-144271.html
Much appreciated.
Peter
OTRA15 is online now   Reply With Quote
Old 03-23-2016, 10:23 PM   #18
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Peter I was going to day, don't drill. I have an idea. However I do like TerryC's and had been thinking about a similar approach at the front vs the rear.
CruizinDux is offline   Reply With Quote
Old 03-23-2016, 11:19 PM   #19
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
I added brass surface bolts to my "heavy" pots and pans drawer, needed especially with the big copper pan. Less hassle than the magnetic release and the polished brass looks nice. The drawer slides had broken when I bought it and my replacements did not have the detents to hold it close. I can post photos if someone wants to see them.
Cliff & Andrea,
2 cats, but they stay home
TerraYacht is offline   Reply With Quote
Old 03-24-2016, 04:12 AM   #20
OK, Bob, I will hold off, but Terry's installation is a very exacting process which works only (IMO) because everything was fabricated square in a shop, with the back "drawer keep receivers" located precisely on that back carcass. I have not used these keeper units, but have had plenty of cabinet shop experience, so I would not want to have to install them at the back of the FC20 oven's lower drawer space, not with these knees and shoulders at any rate . . . !
See the next post from TerraYacht about surface-mounted brass bolts. As I said in the 20-footer thread, a bit funky perhaps, but I kind of like the off-handed F. U. comment to the Airstream factory:
"If you can't build it right, we are going to make the "fix" visible and funky!"
What is your idea, Bob?
PS -- LIS [ Life is short ] -- and the surface bolt fix is KISS and enables OTRA ASAP!
[ How's that for acronym city? ]
Old 03-24-2016, 11:44 AM   #21
CruizinDux's Avatar
TerryC, how challenging is when opening the drawer in consideration of the three latch/locks. Sounds like your OEM was two and you added another??
TerraYacht I'd love to see your pics.
Old 03-24-2016, 12:23 PM   #22
CruizinDux's Avatar
Originally Posted by OTRA15 View Post
OK, Bob, I will hold off, but Terry's installation is a very exacting process which works only (IMO) because everything was fabricated square in a shop, with the back "drawer keep receivers" located precisely on that back carcass. I have not used these keeper units, but have had plenty of cabinet shop experience, so I would not want to have to install them at the back of the FC20 oven's lower drawer space, not with these knees and shoulders at any rate . . . !]
My thoughts exactly re the rear installation and I ruled that out thinking back of the recent pump insulation work (need to get some pics).
Earlier, I was thinking of adding the latche(s) at the front, but wasn't aware of the math side of it. I believe ours are in front and maybe adding 1 or two would be (groan) somewhat easy. I need to look again at the drawer.
p.s. I remember the earlier TerryC thread as I remember thinking as I read the San Miguel reference in Saratoga...Peter appears to like his SM....surf and the beer ; )
[What is your idea, Bob?
PS -- LIS [ Life is short ] -- and the surface bolt fix is KISS and enables OTRA ASAP! How's that for acronym city? ]
{ impressive }
Just a thought...http://jaynovabrass.com/brass-buildi...ss-latches.htm
scroll down to the second picture (also attached...latch on the far left) Seems these types of latches have a flat female portion that accepts the latch, that could be screwed to the top of the drawer fascia. The down side is that it would be screwing with the ply's...so lateral strength may be less than desired although probably stronger than the slide bolt intrusion.
The other thought was to drill just below the drawer fascia and thread in a threaded tap...rework a small L bracket with another return so that you could finger tighten a small bolt to keep the drawer in place. You could also put a T-nut on the back of the panel for additional strength.
When in place you would only see the bracket which wraps vertical (1/2" maybe) and maybe the end of the bolt...depending on the selection of the head type. When not in use you wouldn't really see the tap. In fact, with a T-nut on the back, maybe that would not be needed and you'd see the 1/8" hole. You could also sacrifice the draw fascia and drill thru it and forget the bracket and slip in a dummy bolt when the drawer is in use.
To paraphrase a TSR neighbor who was the proverbial rocket scientist at Ames/Moffet Field..."no idea is a dumb idea. Dumb ideas are often part of the evolution of good ideas"
Name:	brass_baby_latch (Small).jpg
ID:	259295   Click image for larger version
Name:	dual-threaded-insert-for-wooden-taphandles (Small).jpg
Old 03-24-2016, 07:10 PM   #23
KISS
LISS
OTRA ASAP
Old 03-24-2016, 07:40 PM   #24
2007 22' International CCD
Bottom drawers coming out in sharp turns
Reminds me of my NASA days. Them folks speak eat, and dream acronyms, I swear.
I keep in mind that there are only 17,576 possible TLAs so it gets confusing in a hurry.
(Three Letter Acronyms) 😄😄😄😄
KE4GNK/AE
Old 03-24-2016, 08:52 PM   #25
[Sorry Bob I got as far as the acronyms, and ran out of edit time window, as something else came up.]
Thanks for your suggestions, those rectangular slide bolts sure look a lot better!
I am going to carry the new barrel bolt in the trailer, and install it if the drawer ever comes out again. Will pack that bottom drawer carefully so contents can't slide around and generate internal momentum which might force the drawer open.
Time to "summerize" and get on the road again, if only to a local campground . . .
Old 03-24-2016, 09:59 PM   #26
CruizinDux's Avatar
rmkrum: apologies TSR = The Sea Ranch. I'm sure there is one for Ames : )
Peter/OTRA15, I'll continue to refine the tap/bracket concept and maybe go by the (good contractor good product) Hardware supplier. I still haven't forgotten the magnet concept. I want to understand it better.
Default: KISShttp://www.bedbathandbeyond.com/1/1/...rod-white.html
I hear it is available in brushed nickle ; )
Go Dux...58/72 Duke vs. Oregon: 4:04 remaining 2nd half )))))))
Old 03-24-2016, 10:05 PM   #27
CruizinDux's Avatar
ooops, forgot the visual
Name:	IMG_7908 (Small).JPG
Old 03-24-2016, 10:21 PM   #28
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Wouldn't an old-fashioned rubber doorstop have worked just as well? Especially for someone who doesn't have a convenient corner to wedge a brace intoÖ
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Sharp Turns: Blowout Cause? John&Vicki Tires 39 07-09-2015 08:41 PM
Drawers coming out kswelsh Our Community 27 11-07-2013 01:19 PM
'05 25' intl ccd-bottom metal coming off Tim_S Belly Pans & Banana Wraps 8 11-09-2010 05:29 AM
Key Turns and Turns..is this normal? help shiny1973 Doors & Locks 10 11-25-2008 04:57 AM
