Old 10-19-2016, 02:51 PM   #85
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Originally Posted by M and R View Post
The panels appear to be rail mounted. Were the rails on when you purchased, or did you install? If you installed, what brand, how difficult?
Mike
Yes my Interstate came with Mercedes factory roof rails. I think Airstream dropped them from newer models, probably to save some cost. I used Rhino-Rack cross bars attached to the roof rails. I did it to raise the panels above the bath vent. I also replaced the gray tank vent with a lower profile version to the 360 Siphon vent cap.
But there are other ways to mount the solar panels on the roof. I'd use the AM Solar mounting accessories if I was doing this again. See link below for details:
http://amsolar.com/rv-solar-panel-ki...g-accessories/
Old 10-24-2016, 06:36 AM   #86
Lady Lake , Florida
Boondocking in Grand Tour
http://amsolar.com/rv-solar-panel-ki...ng-accessories
Thanks for the link. I am going to add panels. Looking at different methods to best utilize the limited real estate.
M and R is offline   Reply With Quote
Old 05-14-2017, 03:01 PM   #87
Houston , Texas
Finally got around to installing the Victron Controller and reorienting the Solar Panels to series connected. I immediately noticed improved charging behavior especially late in the day in complete shade. Updated the document capturing the finished product.
Mcrider is offline   Reply With Quote
Old 05-14-2017, 08:09 PM   #88
FlyFishinRVr's Avatar
2017 Interstate Lounge Ext
Northern , California
Good stuff Mc, thanks very much for taking the time to put this together.
May I ask for a little more detail on what you mean by "improved charging behavior"? It seems to me that by switching all to series, you are reducing your max Ah by over 60%. Are you really getting that much more later in the day to make up for the loss? If so, when I make the same mod, I'll follow your lead and go series vs. taking the parallel approach like I had planned.
FlyFishinRVr is online now   Reply With Quote
Old 05-15-2017, 10:09 AM   #89
Eberheld's Avatar
Scotch Plains , New Jersey
Question about solar
How many watts of solar do you have on your roof? How long can you Boondock without recharging?
Eberheld is offline   Reply With Quote
Old 05-15-2017, 09:26 PM   #90
Houston , Texas
The MPPT controller will adjust its input voltage to harvest the maximum power from the solar array and then transform this power to supply the varying voltage requirement, of the battery plus load. Thus, it essentially decouples the array and battery voltages so that there can be, for example, a 12 volt battery on one side of the MPPT charge controller and a large number of cells wired in series to produce 36 volts on the other. The MPPT controller will harvest more power from the solar array. The performance advantage is substantial (10% to 40%). So even in low light, the panel array voltage will be above 12 volts and contributing some charge to batteries.
Old 05-15-2017, 10:53 PM   #91
Thanks!
I think I may go with 4 panels (assuming they fit!), 2 parallel groups of 2 panels in series. This would give me roughly 36v (full sun) and about 11Ah. The 11Ah should continue well past when a single panel's voltage would drop too much to power the controller, so maybe this will be the best of both worlds.
Old 05-21-2017, 12:46 PM   #92
Njg
Njg's Avatar
2016 Interstate Lounge Ext
Columbia , Missouri
On this topic, I was thinking about wiring my two new renogy panels in parallel and then wiring that in series with the existing gopower 100w panel. Trying to get the best of both worlds. Any possible issues with this? Also, I was thinking about putting the victron in the space below the drivers side cup holder between the jump seat and the lounge... any problems with butt splicing wires to make the run from the Atkinson current location to there?
Njg is offline   Reply With Quote
Old 05-21-2017, 05:27 PM   #93
Houston , Texas
Originally Posted by Njg View Post
Any possible issues with this? . . .
Yes there are issues with mismatching panels. Read here https://itechworld.com.au/blogs/lear...e-solar-panels
Old 05-22-2017, 08:15 AM   #94
Njg
Njg's Avatar
Columbia , Missouri
Agreed. My concept involves 2 100w panels in parallel and subsequently wiring those in series with a third 100w panel. This trying to double dip the voltage benefits of series and the shading and amp benefits of parallel.
Old 05-22-2017, 10:43 AM   #95
Maybe Lew will chime in, but I don't see why that wouldn't work. You'll double your OC voltage with the series connection so it should keep your controller "on" longer, and you'll also double your current vs. just having all 3 in series (so maybe 10-11A).
I assume you're looking to go with 3 total because of the roof space for flex panels? I was just up on my roof this weekend mucking around with antennae placement for my new WeBoost Drive 4G-X and it looks like the only way I can fit 4 total panels on mine is if I move the XM Radio antennae. If I do that, then I can put one more panel up towards the front of the rig and 2 behind the AC unit.
One thing to note is AS used Dicor and screws to put my solar panel on the roof. When I get around to adding more, I'll be using SikaFlex and tape. As Lew says, NO HOLES! Oh, and the techs did a sh*t job of putting Dicor around my Fantastic fan, so next time I'm up there I'll do a proper job of getting those bolt heads sealed. It made it through a VERY rainy winter with no issues (wettest on record!), but I'd rather have the job done right vs. hoping there isn't a problem later.
Old 05-22-2017, 10:20 PM   #96
Njg
Njg's Avatar
Columbia , Missouri
Three panels because my 2 new ones fit behind the AC and utilizing the third that was OEM from Airstream. I with they hadn't laid it crosswise on the roof because 2 panels could have fit in that space.
Old 05-23-2017, 07:34 AM   #97
toskeysam's Avatar
Townsend , Tennessee
Here's the arrangement Lew was able to put on top of my 2013 AI Lounge Ext. The WeBoost antenna is beside the AC and a new TV antenna moved forward to beside the vent. Click image for larger version
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 05-23-2017, 10:08 AM   #98
How did he get the WeBoost into the van? Did he make a new hole or use an existing one?
Four Corners Grand Circle Tour ghatfield On The Road... 4 07-19-2015 09:00 PM
New Interstate Grand Tour UKDUDE Sprinter and B-van Forum 47 01-16-2015 10:26 PM
Interstate Grand Tour Porchelf General Motorhome Topics 13 06-11-2014 10:48 AM
Utah Grand Circle Tour-Route Advice 4RXLA On The Road... 18 01-30-2011 12:20 AM
Grand Tour Over59 On The Road... 3 02-21-2004 02:33 PM
