04-20-2016, 05:25 AM
#21
Normal
I often charge thru the engine while boondocking, then plugging a charger into the dash for the iPad, phone, etc.
15 minutes or so of the engine running tops everything off.
I wouldn't be too intent on not having to charge during a several day boondocking, instead accepting the limitations of your batteries and just running your engine or generator for awhile at least every other day.
A small thing, in the great scheme.
Just my opinion.
Maggie
04-20-2016, 06:13 AM
#22
League City
FWIW, and for the benefit of other owners including T1N owners, engine charging has not proven to be effective in many cases (it's discussed in more detail in other threads). For reasons that are not clear, our alternator often raises the battery by only 5% per hour. There's no way we can keep up with a boondocking drain by running our engine.
Has anyone ever added solar and then later stated that they regretted spending the time and money? Ever, in the history of the Class B universe? I kick myself because my husband and I didn't do our 300 watt DIY project a year earlier than we did (but we had other projects going on). By investing about an additional 5% of the original purchase price of our (8-year-old used) Interstate, we got 400% more enjoyment out of its vastly increased versatility. And we went high-end on our products because my husband enjoys the novelty of developing cutting-edge applications where possible - solar could be added far more cheaply than our project. Everyone has their viewpoints, but to me, this is a no-brainer.
04-20-2016, 07:01 AM
#23
Normal
One of the benefits, for me, of having an older Interstate is that I don't have a gauge that gives me percentages of charge on my batteries.
Color me ignorant, but I am glad to not have that.
Between driving between sites, and running the generator or engine when not driving, we have not had a problem keeping up with the limited draw on the battery during low-use boondocking.
Nor does battery wear seem to be excessive.
Just more than one way to skin a cat....depends on what you're doing and how you do it.
Maggie
04-20-2016, 07:35 AM
#24
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Nope. If it was a no-brainer, Airstream would do it themselves.
It doesn't take a rocket scientist, or even an engineer, to figure out that off-grid camping requires solar panel wattage at least equal to house battery amp-hours to have a reasonable expectation of keeping the batteries charged through solar alone, if you start with the assumptions that: (1) you can only use half the amp-hour rating daily (50% discharge) and (2) will only get about 6 hours of "good" sunlight on an average day on flat solar panels laid horizontally. The rest is simple math.
04-20-2016, 08:45 AM
#25
League City
I don't think I agree for the simple reason that Airstream likely has a dual line of thinking on this issue, but their lines of thinking do not reflect decision trees invoked by boondocking (some of this repeats previous thread content):
(1) They are making a semi-reasonable assumption that a lot of buyers are going to travel from hook-up to hook-up and therefore would have little use for the type of solar that could allow them to remain off-grid for more than a period of hours.
(2) They are probably also gambling on the fact that the balance of buyers, the would-be boondockers, are not going to know the difference at the point of sale. They will see a small solar panel standard installation and assume they're good to go. By previous forum accounts, sometimes those installations do meet the needs of the traveler. But often not (because of parasitic draws or usage patterns or weather patterns or whatever other factors). By the time it dawns on those owners what are the natural limitations of what they bought, it's too late for buyer's remorse and they'll probably just bite the bullet and upgrade it themselves, no skin off Airstream's nose.
My point was, for would-be boondockers, even occasional boondockers, I think it's a no-brainer, especially for owners like my husband and I whose rigs were born without any solar to start with. A bit more cash enables a vast number of additional travel scenarios.
04-20-2016, 08:52 AM
#26
From All Over
And yet a generator comes as standard equipment. I'd gladly trade the generator for an equal weight of additional house batteries and solar panels.
04-20-2016, 08:56 AM
#27
2015 Interstate Ext. Coach
Chicago
from my own experience, the sub-standard base package of inferior panels, wiring, controller, and installation ... made the solar a negative rather than a positive. I had to upgrade all 3 of those. It would have been better if they had started with nothing. Not sure why (other than making their assembly line simpler) they don't give us some solar upgrade options when we're ordering a van. That alone might cause me to go to Advanced or someone else next time.
04-20-2016, 09:11 AM
#28
2011 Interstate Coach
Overland Park
, Kansas
Have you had your alternator checked? That sounds like a very slow charge rate, especially if you still have one house battery.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
04-20-2016, 09:47 AM
#29
Houston
Just to return to my original inquiry for advice. I think I can live with the OEM solar set up if the Lithium plug and play is a real option. It would provide substantially more AH for half the weight and faster charging time. It appears the Magnum with the batteries internal BMS will work fine and they are designed to work well below freezing. Am I missing something? Other than the cost.
04-20-2016, 11:27 AM
#30
League City
This thread is wandering more than a confused armadillo caught in this week's flood, but my short response is "it might not be that easy". Well, we have different vintages of Interstate so it gets dicey to even speculate. My husband LB_3 is working on the specs for our lithium as we speak, so that we can fully take advantage of the solar that we put in. Not only is it NOT plug and play, he's telling me that he has to physically re-wire part of the vehicle, and that's not solely because of our battery location, I don't think (it has to move from under the passenger seat where it never should have been to start with, to under the closet). Anyway, I will get him to clarify this when he has a free moment.
04-20-2016, 11:39 AM
#31
League City
The issue with Lead acid batteries is that they have a high internal resistance so once they get above 85% full the charging rate drops considerably. One of the biggest advantages of Lithium batteries is that they have a low internal resistance which permits them to charge at their full amperage until full. One of my biggest frustrations with solar is getting direct sun and knowing we have 10+ amps available and the battery only taking on 2.5 amps.
04-20-2016, 12:14 PM
#32
Houston
The two brands I'm looking at are Smartbattery and Starkpower. Both claim to be drop in replacements for lead acid and the internal BMS protects the battery from the evils of lead acid/solar charging systems.
04-20-2016, 04:09 PM
#33
League City
No lithium battery on the market is a true drop in replacement for lead acid batteries due to the different charging voltages and protocols. They have to be considered part of a larger system. Luckily, many inverter/chargers are flexible enough to be programmed to support Lithium batteries.
The reason a drop in won't work for us is that I want to install an inverter in our AI (30% off from Uncle Sam if it's part of a solar system) and there just isn't any practical way to run heavy enough wire to the passenger seat pedestal to hook up an inverter. That means removing the current converter, relocating the battery, and installing the inverter, and rewiring the AC power circuits.
04-20-2016, 04:29 PM
#34
2024 Interstate 19
Fulton
, Maryland
I did a lot of research before I upgraded my batteries last fall. Lithium was my desired choice until I discovered that ALL lithium batteries must be above freezing to charge. They will happily discharge below freezing but can't be recharged without damage unless they are above freezing. That was a show stopper for me as I use my Interstate all year in Maryland and have been know to make winter trips to Minnesota. Smartbattery and Starkpower never mention this limitation on their web sites, but if you contact them with a direct question on charging beow freezing they will admit the limitation. See this article from Battery University for details;
http://batteryuniversity.com/learn/a...w_temperatures
- - Mike
04-20-2016, 04:38 PM
#35
From All Over
You could install battery heaters just like your tank heaters. Added complication, perhaps, but it would extend your camping season with lithium batteries.
04-21-2016, 05:44 AM
#36
League City
Heaters in general tend to draw boat-loads of power (unless they are gas) and so I'd like to see the calcs on that one.
It raises the question of whether it would be possible to have a back-up Lifeline system on a separate loop. Hibernate the lithium when it gets too cold. Quite a resource-heavy idea but if the Lifeline is there to start with and could somehow be left in place, I wonder if it could be made to work.
Back when I was in my pre-solar redneck stage of attempted boondocking, I tried to argue to my husband that we simply buy a separate Lifeline, bench charge it, and stow it in isolation under the bloody couch so that I could physically swap it out with the house battery when the house battery got too low (all I have to do in my case is lift the cushion off the passenger cab seat to access the active Lifeline). Presto - my boondocking time doubled with no extra engineering required and almost zero extra work. Sounds promising to me!
Being a mechanical engineer, my husband blanched at the inelegance of this proposal. I said, "I don't care if it's a sophisticated solution or not - all I care is whether or not it works."
Anyway, it's that general mode of thinking that makes me question whether two different battery systems could be feasible, with a possible switch-over depending on prevailing conditions.
04-21-2016, 06:34 AM
#37
From All Over
I haven't run the calculations.
You can't really use tank heaters when boondocking. They're battery-killers. Since battery heaters are so similar to tank heaters, winter boondocking with battery heaters would be out of the question. But since you still need your batteries to run your 12v systems even when plugged into shore power, running battery heaters from shore power would allow you to recharge your lithium batteries even in winter.
04-21-2016, 06:54 AM
#38
Houston
So how does Tesla get around this problem? They most certainly have cars driving around in the Nordics and I'm not aware of them shutting off regenerative braking.
04-21-2016, 08:34 AM
#39
2024 Interstate 19
Fulton
, Maryland
Tesla and all other electric vehicles have a battery heating and cooling system. Remember the lithium batteries can be discharged below freezing so it is certainly drivable below freezing, with reduced range. But the batteries must be warmed up to be recharged. An EV is only recharged when plugged into a high voltage source. That source first warms the batteries before charging starts.
For my Interstate with 400 watts of solar on the roof plugging into AC shore power is a rare event when parked in my driveway. Solar keeps all my batteries fully charged every day. As I refined my battery upgrade plan the desired location for my new batteries was under the van. The complexity of trying to design and install a battery heater system was more than I wanted to take on. I chose to install four Lifeline GPL-4CT, 6V AGM batteries providing 440 AH capacity. Getting the batteries under the van, like Airstream does now on new Interstates, gave me space inside to install a 2000 watt Magnum inverter/charger without giving up any interior storage space.
My upgrades of more solar, bigger batteries and a bigger inverter has given me new freedom to go and stay where ever I want without worrying about having enough battery power to use the electrical systems for my normal needs. Now I only need to run the generator when using the air conditioner without shore power.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
04-21-2016, 08:35 AM
#40
Houston
Never mind. I found the answer. The car does disable regenerative braking and they have to hear the batteries. Both which deteriorate performance. I guess I've convinced myself to stay with AGM.
