Old 09-09-2016, 10:27 PM   #1
2014 Interstate Ext. Coach
BUTLER , Pennsylvania
Black water tank
I HAVE A 2014 INTERSTATE. I CANNOT EMPTY MY BLACK WATER TANK. I CAN HEAR THE VALVE OPEN THE LIGHT COMES ON, HOWEVER WHEN I TRY TO PUMP NOTHING COMES OUT. I RARELY PUT SOLIDS IN EXCEPT FOR TOILET PAPER. MY GRAY WATER SIDE WORKS FINE. CAN ANYONE HELP ME WITH MY DILEMMA
BOBCONEYBEER is offline   Reply With Quote
Old 09-09-2016, 10:36 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
First, drive. out to the loneliest spot you can find and dig a big hole. Then start taking stuff apart....
Old 09-09-2016, 11:02 PM   #3
2011 Interstate Coach
Muskogee , Oklahoma
So, you can confirm there is still liquid in the tank before you open the valve? If so, you should be able to hear it gurgle in the 3" line after you open the valve. If you can't hear that then the valve is not opening. It is in warranty, let the dealer fix it. If you want to try you can manually open the valve.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 09-10-2016, 07:23 AM   #4
Can you manually open the valve
Old 09-10-2016, 10:42 AM   #5
Muskogee , Oklahoma
Here's a thread that talks about this issue:
http://www.airforums.com/forums/f240...108588-3.html#
You should be able to find the pdf file for the valves you have on that thread, and it will tell you how to manually open them. If the light is not on at the panel where the switch is located, then likely it is not open. I'd check the power first to be sure it actually is not responding.
Old 09-10-2016, 10:44 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A question in aid of troubleshooting, just how full is the black tank? I ask because if the black tank isn't very full, then that could be part of your problem. The tanks are very susceptible to being out-of-level, and can be hard to empty if the van is tilted the wrong way.
Look under the van, and see which side of the black tank has the discharge valve. Then elevate the van on the opposite side. On my 2012, a couple of leveling blocks under the passenger side to elevate it does wonders for tank drainage.
That's assuming that the indicator light isn't lying to you and the valve actually is open.
Side note, you must have the gray valve closed completely in order to open the black valve. There's an interlock to prevent both being open at once. So also verify that the gray valve is closed.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-10-2016, 10:50 AM   #7
Muskogee , Oklahoma
Here's a link to the manual if you have the same type:
https://www.barkermfg.com/uploads/5/...auto-drain.pdf
Protag, there's no interlink on mine. Both valves can be opened, and actually, I do that almost every time I dump. I first empty the black tank, and run the flush hose to flush it out while I do so. When it finally empties, I leave it open, and continue to flush it while dumping the grey tank. After the grey tank is empty, I close the black tank valve, and let it fill with some water for a bit, then turn off the water, and close the grey valve.
Never had any issues doing it this way. The black tank gets cleaned, it has some water in it to start doing its job next time we need it, and both tanks are ready to go.
Old 09-10-2016, 11:00 AM   #8
Thanks for the link. My memory may be faulty (it often is) but I'm virtually certain that on my 2012, the last time I tried to open the gray valve with the black valve still open, it didn't work. I had to close the black valve first.
WBCCI #1105
TAC LA-4
Old 09-10-2016, 12:02 PM   #9
2018 30' Classic
Rock Hall , Maryland
Could someone direct me to the tread on routing the backup camera into the Kenwood. I so dislike the Pyle display.
GloryBound is offline   Reply With Quote
Old 09-10-2016, 06:23 PM   #10
2018 30' Classic
Sorry for the post I'll redo it as a new thread
Replacing black water tank with grey water tank cheetah1 Sinks, Showers & Toilets 25 10-02-2014 05:26 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Help!!! Fresh water tank/ black tank meredith Fresh Water Systems 6 09-01-2011 11:51 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
