Old 07-07-2014, 09:36 AM   #29
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Originally Posted by gmillerok1 View Post
That is exactly how I winterized my unit. Plus, I ran the pump until pink liquid came out the hose. Still, the macerator leaked after I de-winterized in the spring. From now on I will disconnect the hose and drain the liquid from the hose.
Did you determine what the failure mode was with the macerator? In my case one of the short studs that held things together broke off in the housing. I am guessing that this happened due to water freezing inside the housing.
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 07-07-2014, 10:23 AM   #30
2011 Interstate Coach
Muskogee , Oklahoma
It was leaking between the seal and the electrical housing. A kit could have repaired it, but the cost wasn't that much less than just replacing the entire pump and it was a lot easier that disassembling it which requires a special tool I did not have. Airstream told me it would be replace under warranty if I could prove it wasn't a leak caused by freezing-which of course I could not. Their quick answer made me think it hadn't been the first time the question had been made to customer support leading me to believe this is a common issue to fail.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Leaking Black Water Tank LWPittman Waste Systems, Tanks & Totes 2 01-21-2012 06:38 PM
Leaking Black Water Tank ssolid Waste Systems, Tanks & Totes 6 04-10-2009 07:26 PM
Black Tank Macerator Recommendations? Lumatic Waste Systems, Tanks & Totes 14 08-04-2008 11:36 PM
Black Water Tank Shut-off Leaking tntom Waste Systems, Tanks & Totes 2 07-03-2008 06:38 PM
Macerator pump uncleneal Waste Systems, Tanks & Totes 4 03-12-2004 09:40 AM
