Old 05-20-2019, 06:24 PM   #1
2013 Interstate Coach
Idaho Falls , Idaho
Black tank vent
Due to tracking down a leak I found that the black water vent pipe did not extend far enough from the roof line to fit into the 360 degree vent as it was supposed to. In fact it was about three inches short. It appears it had been leaking for awhile since the area around the hole cut in the roof was rusty.
Has anybody else found this? Another example of the workmanship not matching the name brand.
Passin Thru is offline   Reply With Quote
Old 05-20-2019, 08:35 PM   #2
2011 Interstate Coach
Evansville , Indiana
The vents on our 2011 were sun damaged so I recently replaced them with the new style 360 siphon vents. While I didnít find much water damage in that area, the metal was rusted. The original vent pipes were cut at different heights (>2Ē) so I donít think the factory folks spent much time worrying about whether it was done correctly.
BurntAsphalt is offline   Reply With Quote
Old 05-20-2019, 09:10 PM   #3
Boxster1971's Avatar
Fulton , Maryland
Yes - found the same problem on my 2013 Interstate when I replaced one of the 360-Shipon vent caps with a lower white model to clear the solar panels I was adding. I'm attaching photos of what I found and how I fixed it. I added a short extension to the vent pipe that was about a inch short of the metal roof.
ID:	341276   Click image for larger version
ID:	341278   Click image for larger version
- - Mike
Old 05-21-2019, 06:09 AM   #4
Idaho Falls , Idaho
Boxster - I havenít fixed mine yet (waiting for a dry day) so your pictures and method of fixing will help. In your pictures it appears that there was a flange between the old vent and the roof line that you did not have to remove. Is that correct? I was wondering what the vent actually rested on due to the thickness there.
Old 05-21-2019, 09:06 AM   #5
Fulton , Maryland
Yes - there is a thick "donut" ring made by Airstream from clear acrylic plastic to make a flat mounting surface next to the roof rib.
- - Mike
Old 05-21-2019, 02:12 PM   #6
orlik's Avatar
2017 Interstate Grand Tour Ext
Gulf Breeze , Florida
Plenty of info on vent leak I had reported in the below thread.
http://www.airforums.com/forums/f240...ie-190327.html
orlik is offline   Reply With Quote
Rust? What rust?? Black tank? What black tank??!? gadgetgeek Repairing/Replacing Floor &/or Frame 2 08-08-2018 10:20 AM
Black tank only for gray and black water??? mmollema Waste Systems, Tanks & Totes 9 02-01-2017 04:36 PM
Black tank vent snapped off at tank! russ240 Sprinter and B-van Forum 14 08-12-2015 06:38 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Is it possible for the vent on the black tank to be broken? andi-n-jag Waste Systems, Tanks & Totes 2 07-13-2008 06:52 AM
