Old 07-04-2016, 06:22 PM   #15
2015 Interstate Ext. Coach
Lake Mary , Florida
The project is on the road side. Make sure to use jack stands for protection in mind.
Mr. B is offline   Reply With Quote
Old 07-04-2016, 06:26 PM   #16
Lake Mary , Florida
Make couple times spraying and flushing of black tank using a special inlet for that, so the fluid would not be so nasty.
Old 07-04-2016, 06:30 PM   #17
Lake Mary , Florida
Remove the pump with four bolt nuts as it was explained by Gmillerok, loosen the clamps and remove 3 inch pipe and blue hose. Cut two electrical wires - actually I don't understand why they didn't make a proper connection so you have to cut and connect them again.
Old 07-04-2016, 06:32 PM   #18
Lake Mary , Florida
Disassembled the motor hoping I will be able to fix it because it is good working pump, just leaking somewhere.
Old 07-04-2016, 06:35 PM   #19
Lake Mary , Florida
Nope )
One of the bolts appeared broken, thus did not hold a leak. The broken threaded part of bolt is inside the body thread.
So, I decided to buy a new suggested pump.
Old 07-04-2016, 06:37 PM   #20
Lake Mary , Florida
Suggested pump on Amazon has number 18550000A,
However my original pump has number 18550300C.
Are they interchangeable?
Thank you and Happy Fourth!
Old 07-04-2016, 07:55 PM   #21
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
It's the same pump: one is a Flojet part number, the other is a Xylem part number. The 2 companies must have merged or something like that.
Old 07-04-2016, 09:23 PM   #22
Lake Mary , Florida
Both pumps are Flojet.
I bought one on Amazon today, will arrive on Thursday, will see if they are the same.
Old 07-04-2016, 10:29 PM   #23
2011 Interstate Coach
Muskogee , Oklahoma
Yes. The link I gave you was from my Amazon order and is identical to the one I installed and currently have on mine. The second pump had the identical broken bolt issue. I talked to flowjet and the guy told me excessive back pressure can cause the bolt to snap do be sure to always open the valve on the end of the hose before turning it on.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 07-04-2016, 10:53 PM   #24
Lake Mary , Florida
Very good to know, thanks!
Old 07-05-2016, 05:27 AM   #25
Lily&Me's Avatar
Normal , Illinois
Nice job laying this all out, Mr. B.
Maggie
Old 07-05-2016, 06:22 AM   #26
Lake Mary , Florida
Thank you I was trying to do it well
Old 07-05-2016, 01:41 PM   #27
Lake Mary , Florida
When I loosen and put aside hoses clamps, I removed hoses from the pump, and it was not easy - exactly as you told before, and I used a flat screwdriver to detach them from the body of the pump. It looks there was a silicone between inner surface of the hoses and the pump. Do I need to put silicone again before I dress hoses back to the new pump?
Old 07-05-2016, 03:10 PM   #28
73shark's Avatar
Overland Park , Kansas
You may have to in order to slip them on.
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 11:36 AM
LEAKS LEAKS more LEAKS in ATL parzam21 General Repair Forum 17 12-27-2015 02:46 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
