Old 05-25-2015, 05:47 PM   #15
2015 19' Flying Cloud
2011 23' FB International
Dayton , Ohio
I don't think the newer sensors are any better. We just bought a 19' (2015) and the black tank stays at 0 for a long time, then the next level it shows is 47, then 75.
Artvez is offline   Reply With Quote
Old 05-25-2015, 05:52 PM   #16
Dayton , Ohio
There is a guy on Youtube who tested the ice cube theory in a clear black tank he made and it didn't do anything to clean the tank. I think he goes by Fit RV if you want to look it up.
Old 05-25-2015, 05:52 PM   #17
HowieE's Avatar
Princeton , New Jersey
Images: 12
The best sensor for the black tank is eyeball it through the toilet.
it is hard to envision that you could ever fill the black tank in a week from those you can haul in your van.
When we are camping without sewer we often use the black tank by pouring dish water in the toilet to keep the gray from filling. Have gone 10 days this way
2004 Excursion 4x4
Old 05-25-2015, 06:01 PM   #18
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Three adults and five grandkids can in a four day trip.
Old 05-25-2015, 06:42 PM   #19
bellastream's Avatar
1969 31' Sovereign
Auburn , Washington
Originally Posted by Sneakinup View Post
"Black tank always looks half full"
Does that make you an optimist or pessimist? (sorry... couldn't resist)
I'm a black tank half empty kinda guy my self
bellastream is offline   Reply With Quote
Old 05-26-2015, 10:54 AM   #20
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
What brand of tank monitor do you have. The Micro Pulse sensors are notorious for false readings. I think one of the reasons for the Micro Pulse is they probably have never been properly calibrated even at Jackson Center. There was a recent article in Airstream Magazine which goes through the entire procedure to properly calibrate all three tanks. It is quite involved but makes perfect sense. You need to drain and fill each tank and use a connection on the back of the panel during the drain and fill process to "educate" the sensors. The amount of time and water required makes me sure it was never done at the time of installation. I'm building a new shop building with a full hook up pad next to it. When that's done, I'll do the entire procedure and post the results here.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 05-26-2015, 11:36 AM   #21
dalemonroe's Avatar
2008 16' Safari
Portland , Oregon
Our black tank gauge acts up as described above. AS has a hookup for cleaning but it doesn't do the job. I made a cleaning attachment that I put down the toilet which works well. The gauges work fine after little cleaning. The toilet dumps directly into the black tank so that is your access point.
I used a two foot piece of CPVC pipe with a hose attachment on one end. The other end has a 90 elbow and a short piece of pipe. the end was heated and squeesed to make a fan shaped spray. I put it down the toilet and turn it around a few times.
dalemonroe is offline   Reply With Quote
Old 06-01-2015, 11:27 AM   #22
dbrett's Avatar
1988 25' Excella
Poland , Ohio
Might want to check this video:
Fella built a plexiglass tank to test the idea of using ice cubes to clean it.
Dave in NE Ohio
88 Excella
WBCCI # 1315
Mahoning Valley Ohio Unit
dbrett is offline   Reply With Quote
Old 06-01-2015, 07:18 PM   #23
73shark's Avatar
Conclusion: you need to flush #2 w/ some water. Otherwise it's just going to stick wherever it lands.
I like the idea someone posted using a 90* fitting and sticking it in the tank and spraying.
Half polished. Half arsed.... gomotomoto Our Community 9 11-22-2014 04:41 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Half or full timing budget? Jim Pona Full-Timing 13 12-11-2010 10:38 PM
Sink drain creates toilet bubbles, greywater always reads full dre00 Plumbing - Systems & Fixtures 22 02-02-2009 12:13 PM
black rubber sealant looks like bacon dikku@mac.com Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 08-24-2004 06:26 PM
