Old 10-08-2013, 07:41 PM   #1
2009 22' Interstate
Chetek , Wisconsin
Black Gray valves trouble shoot
09 Airstream Black valve refuses to open and red light stays on. Switch itself is OK reversed switches same problem. Works sometimes seems like a loose wire. Where will I find the motors that open the valves? There does not seem to be a manual way to open them.?
Wisconsinden is offline   Reply With Quote
Old 10-08-2013, 09:13 PM   #2
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
The dump valves have a manual override; it is a flat head screwdriver slot on the end of the valve motor shaft. See page G-16 of the Interstate manual. If you don't have the manual, you can download a pdf copy from the Airstream website.
Good luck,
Wayne
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 10-09-2013, 05:26 AM   #3
2009 22' Interstate
Chetek , Wisconsin
Main outlet pumps ok
I have used that valve no luck. The valve at the tank black mainly does not open with switch. I do not know where the main black valve is located, can guess but am not able to see...
Old 10-09-2013, 05:34 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Since the black tank is above floor level right under the toilet, my guess is the black valve is passenger side, right where the 3" hose goes up through the floor.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-09-2013, 11:38 AM   #5
2009 22' Interstate
Chetek , Wisconsin
Thumbs up Airstream Fix
The black valve has a open close on the side with arrows to show direction 1/8 allan does the trick. turning this a few times it freed up and am now using the valves normal. NO Cost thanks to Airstream counseling
Thanks Airstream
