Old 02-07-2016, 05:45 AM   #15
r carl's Avatar
Lin , Ne
The problem is most likely the angle that the blade is contacting the windshield. The wiper blade should contact the windshield at a 90 degree angle. If the windshield wiper arm has twisted slightly over time the windshield wipers will chatter. A little work adjusting the wiper arm should help. In the past I have used an adjustable wrench on the flat part of the wiper arm and twisted the arm slightly to get the wiper to contact the windshield correctly.
Old 02-09-2016, 07:22 AM   #16
I suspect you are correct. Applying the Rejex to our windshield seems to have made the problem worse instead of better, which I never thought possible. Having exhausted the potential of both surface applications and blade brands, we now have to turn to twisting. Fortunately there are pointers for that on Sprinter Forum.
Wiper Blades for '87 345 ? breeze General Motorhome Topics 7 04-22-2017 08:52 AM
Who carries new wiper blades for 35 cutter? mfancher Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 3 03-26-2012 02:32 PM
wiper blades 2000 Land Yacht daveshrader Land Yacht/Legacy Motorhomes 3 07-01-2011 06:18 PM
Fixing the Windshield Wiper Blades Keyair Classic Motorhomes 4 06-03-2011 12:02 AM
Wheels and wiper blades Curtis-79MH Airstream Motorhome Forums 2 09-22-2003 09:37 PM
