Old 11-03-2014, 07:33 AM   #1
Best way to remove label goo from visor?
Our 2007 AI had the standard "don't put a rear-facing infant carrier in a seat with an airbag" label glued to the rear of the sun visors, rather than screen-printed directly on them as is done with many newer vehicles. One label has come off, the other is about to fall off, but both are leaving their adhesive behind.
Has anyone tried to remove this kind of mess, and if so, did you find a product that would dissolve the adhesive without further damaging the visor material? (the labels themselves have already caused differential stretching).
Thanks!
Alison and Lawrence
League City TX
THE INTERSTATE BLOG
Old 11-03-2014, 07:51 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I have always used, and continue to use liquid lighter fluid (naphtha) to dissolve glues and adhesive. It almost always does the trick without any damage to the surface.
Brian
SuEllyn & Brian McCabe
Old 11-03-2014, 08:10 AM   #3
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
There are a number of products that will remove adhesive. Naphtha, as mentioned by moosetags, acetone, mineral sprits, denatured alcohol and Goo Gone ( http://googone.com ).
Just be sure to test whatever you use on a small area first as some of these will damage certain plastics. Don't ask how I know that. :-(
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 11-03-2014, 08:12 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I've found that WD40 will sometimes remove adhesive.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-03-2014, 08:23 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
acetone
Be very careful about the use of acetone. It adversely affects many plastics and is highly flammable. Naptha (lighter fluid) is a bit less agressive, but is still very flammable. Mineral spirits does not attack or dry very fast. If you sparingly wet a small piece of cloth with the solvent and then rub briskly, you can usually get the best results while controlling the solvent and less effects on the plastic you are cleaning.
Old 11-03-2014, 08:49 AM   #6
Edistobob's Avatar
2013 25' Flying Cloud
Edisto Island , South Carolina
I'll second the recommendation for "Goo Gone". I've never had it harm any surface I've used it on, and it works pretty well especially if you let it remain on the "goo" for a bit. But out of an abundance of caution, test a small area first to be sure the surface is not affected.
Edistobob is offline   Reply With Quote
Old 11-03-2014, 12:43 PM   #7
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
If none of the above work, try Goof Off.
Old 11-03-2014, 12:48 PM   #8
Libertyville , Illinois
I love Goo Gone!
Short563 is offline   Reply With Quote
Old 11-03-2014, 02:25 PM   #9
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I agree with Protag - WD-40 works for me. Just get the area wet with WD-40 and let it soak a few minutes. Then it should wipe right off.
2012 Dodge Durango Hemi/AWD
Old 11-03-2014, 02:57 PM   #10
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Sometimes plain old vegetable oil works wonders.
It's especially good on anything metal that has a non-stick surface. (What the hell do they use that sticks to the non-stick stuff anyway?)
Paula
Old 11-03-2014, 03:27 PM   #11
1967 17' Caravel
Centennial (Denver) , Colorado
nothing better than 3M adhesive remover available at auto supply stores or body shop suppliers, stuff is great for anything sticky!!!!!
jskalet is offline   Reply With Quote
Old 11-03-2014, 03:35 PM   #12
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Goo-Gone should work and add a nice citrus fragrance.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Help the Goo be Gone Thumper General Repair Forum 3 04-23-2013 06:29 PM
Removing under sticker goo ExcellaFella Cleaning, Stripping & Polishing 4 11-16-2011 02:18 PM
what's your favorite airstream WARNING label? 2airishuman Off Topic Forum 39 03-27-2008 07:23 PM
Magnet for 1994 front visor philippes Classic Motorhomes 3 07-29-2007 07:04 AM
cleaning sticker goo from interior clearcoat Xray Our Community 3 07-29-2004 11:00 AM
