Old 06-12-2015, 10:33 AM   #1
2012 Interstate Coach
Carlsbad , California
BBQ Options?
Hello Interstate Owners,
We have a 2011 Interstate and are looking to pickup a compact BBQ that connects via the exterior LP gas outlet. I understand this is a "low flow" outlet and I am wondering you have found to work the best?
02interstate is offline   Reply With Quote
Old 06-12-2015, 11:52 AM   #2
2011 Interstate Coach
Muskogee , Oklahoma
Good question. I tried hooking the external gas valve up to a small portable Charbroil gas grill and I couldn't keep it lit. It was like it was not getting a constant or consistent flow. I was going to take it to a propane shop to have them check it out. The overflow valve hose was clogged up with some debris they cleaned out when I first got my unit but I never used the grill before or tested that hose.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Old 06-12-2015, 11:56 AM   #3
Gainesville , Florida
Bbq is the food. It is prepared on a grille.. Jim
Old 06-12-2015, 12:09 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The History of Barbecue and Grilling | Tori Avey
MICHAEL
Old 06-12-2015, 12:57 PM   #5
DoublTrouble's Avatar
2015 27' FB International
While do not have an Avion, I can share a "tidbit". The low pressure connection needs to be matched with the correct regulator on the grill. My personal experience with using an 8lb tank and original regulator vs the low pressure hose and matching regulator from my grill manufacturer is that the heat or btu output is significantly less. This may be unique to my grill. Other members may tell you which grill they use with that connection that perform better.
In my case the grill I have is way too hot even on its lowest setting, therefore, the lower pressure setup is working well for me.....right now anyway!
There was a recent thread on this subject, you may find useful. You'd need to dig for it..
DoublTrouble is offline   Reply With Quote
Old 06-12-2015, 12:58 PM   #6
Chief thanks for the link...
Old 06-12-2015, 01:14 PM   #7
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Camco Olympian 5500
I added a low pressure outlet to my Safari and use it with a Camco Olympian 5500 grill. I found it on a good sale, otherwise they are pretty expensive. It is designed to work directly off a low pressure feed and does not need an additional regulator.
There are several versions with the same name/number. Mine came with a combination stand/hanger frame. It sits on a small table or will hang from an accessory rail ($6) screwed or riveted to the side of the RV.
I had to adjust mine down because it was too hot, even on low. Screwdriver adjustment under the knob.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 06-12-2015, 01:21 PM   #8
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Side stepping the language nit pickers... you'll discover the number of choices for a low pressure, portable grill is limited. However, the high pressure units with a regulator are easily modified. You simply have to remove the grill's regulator and connect a hose (it is usually a 1/8" threaded coupler on the grill end, there are other sizes tho) with a quick connect that matches your outlet on the other end. Hoses come in variable lengths: upwards to 15' in length. Two regulators equal trouble, the grill's flame size valve is sufficient to control the burner just like your stove top.
You can also insert a T between the grill's regulator and grill so dual use is enabled for those times your grill is used without the Interstate and off a small tank.
Here is the kind of thing you'll need:
http://www.amazon.com/Camco-57280-Qu...=pd_sbs_auto_3
If messing with the conversion concerns you, here is an alternative:
http://www.amazon.com/Camco-57305-Ol...ords=rv+grills
SeeMore is offline   Reply With Quote
Old 06-12-2015, 02:24 PM   #9
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
My Olympian 5500 works well.
2012 Dodge Durango Hemi/AWD
Old 06-12-2015, 03:49 PM   #10
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
+1 for the Olympian 5500. It is one of the few grills available that will work with the LP gas quick disconnect on the Interstate. That connector is for regulated low pressure LP. Many portable grills have there own regulators and must be connected to high pressure LP.
Here are a few photos of mine using the Camco grill mounting rail.
Enjoy,
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
ID:	240525   Click image for larger version
Old 06-12-2015, 05:09 PM   #11
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
The outside LP-out quick connect on an AS is regulated at 1/2 lbs. It takes 10 lbs to operate a grill regulator therefore you have to purchase an RV type unregulated grill or purchase what you want and remove the regulator. I modified a Cuisinart by removing the regulator and inserting a Camco male low-pressure quick connect in the grill's flame adjustment valve where the regulator was removed from and purchased a Camco 10' male/female low-pressure hose to connect it to the AS. Works great and not difficult to do.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 06-12-2015, 07:16 PM   #12
Boxster1971:
First, what is the origin of your handle?
Second, I can't tell from your picture but is your mounting rail that is attached to the Interstate silver or white? Mine is white and I'm trying to figure out how to get it stripped and anodized so it will be silver.
Al
S/OS #004
Old 06-12-2015, 07:53 PM   #13
Fulton , Maryland
Originally Posted by Al and Missy View Post
Boxster1971:
Al
My handle was a whim from when I once owned a 1971 Porsche 914/6.
The mounting rail started white, but I painted silver to closer match my van. Its been there for two years now and still looks great. I think anodizing it is not necessary.
- - Mike
Old 06-13-2015, 04:35 AM   #14
Rockwell , North Carolina
- - Mike
Bet you wish you still had it? See attached PDF file.
I had a 1970 914-6 back in the '80's. Fun car to drive.
jerhofer is offline   Reply With Quote
AC replacement-options, options... Belegedhel Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-13-2011 08:54 AM
Stainless BBQ for Airstream Killo1 Commercial Listings 29 05-28-2009 09:45 AM
Coolest BBQ ever? RichardT Off Topic Forum 6 06-20-2006 01:03 PM
BBQ with Rich Pahaska Our Community 7 02-23-2006 09:13 PM
Outdoor BBQ Melvin P. Thorpe Our Community 33 04-21-2003 07:37 AM
