Old 10-22-2015, 12:27 PM   #1
2009 22' Interstate
Boylston , Massachusetts
Battery Upgrade Question
Vehicle: 2009 AI
House batteries were dead when I bought the van so I'm upgrading to Lifeline 6CT batteries. For those that have installed these batteries in the AI battery box--how did you do about securing the batteries in the box? The batteries are much larger than what was in the box originally so there is not a lot of room for them to move around but it seems like they should be secured somehow. I haven't tried the existing battery straps but somehow I doubt they would work.
sneebot is offline   Reply With Quote
Old 10-23-2015, 04:22 AM   #2
ben322's Avatar
2009 Interstate
Bethesda , Maryland
I cut a couple of blocks of plastic for a snug fit.
2009 Airstream Interstate
ben322 is offline   Reply With Quote
Old 10-23-2015, 04:46 AM   #3
r carl's Avatar
Lin , Ne
Wood blocks cut to size works too.
Old 10-23-2015, 02:21 PM   #4
Anyone have an idea how Optima batteries compare to what comes from airstream. I've had my 2013 AI for a couple of weeks and just opened the compartment to find Optima blue top batteries.
ofdcb is offline   Reply With Quote
Old 10-23-2015, 10:36 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Optima hypes their "spiral-cell" design as being superior to standard configurations, but the numbers actually tell a different story. Optima blue-tops have about 15% fewer amp-hours than a comparable-sized standard AGM house battery. If you need to replace them, I strongly urge you to consider Lifeline batteries.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-23-2015, 10:59 PM   #6
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I tried Optima in my boat and for whatever reason they just did not work out. I also would go with the Lifelines.
TinCan
graysailor is offline   Reply With Quote
Old 10-24-2015, 09:52 AM   #7
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
I installed my 6 v batteries in 2008. More juice! Still going strong after 85,000 miles and 7 years.
See my post way back then on installation.
http://www.airforums.com/forums/f449...tml#post514373
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Battery Upgrade Question Boxster1971 Sprinter and B-van Forum 8 08-23-2015 11:38 AM
Battery Upgrade Roadrunner Batteries, Univolts, Converters & Inverters 9 08-08-2010 07:44 PM
Performance report: Battery upgrade one year ago hshovic Electrical - Systems, Generators, Batteries & Solar 4 07-10-2009 09:04 AM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 06:29 AM
Bambi upgrade to group 31 battery? rfield54 Electrical - Systems, Generators, Batteries & Solar 0 05-17-2005 09:33 AM
