Old 05-18-2016, 01:38 PM   #1
mdf
2016 Interstate Lounge Ext
Belvedere , California
Battery Upgrade
Hi All,
Wanted to share a recent battery upgrade I was able to complete (with professional help) based on great advice from the forum. I have a 2016 Interstate Lounge 4x4, with the stock batteries under the coach on the drivers side. My goal was to simply add battery and solar capacity to expand dry camping flexibility. Eventually, I would like to add a more robust solar system (read: Lewster, when he has time!), but we didn't have time to take that on before a 5000 mile summer trip starting next month. So to get me through the trip I :
1) added a second 100W go-power flex panel on the roof, utilizing the existing wiring, controller, etc. I realize this system isn't ideal, but it will have to do for now, and was relatively simple as they make an add on kit which greatly simplified wiring and installation.
2) Converted the (2) stock 12v batteries to (4) Lifeline 6v 4CT AGM batteries.
I looked into trying to modify the under coach battery boxes, but that didn't work so well. So instead, we found that the Lifeline 4CT's fit perfectly in the metal under floor storage box under the floor of the storage area. See the attached pic.
Shout out to Vinnies Airstream repair in Santa Rosa, CA. Vinnie installed these batteries for me. Highly recommended for any of your service needs while in the NorCal area! Second shout out to Lewster for all the great advice -- can't wait to do the rest of the project when schedules permit.
mdf is offline   Reply With Quote
Old 05-18-2016, 03:01 PM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
No picture attached to your post. Id like to see how your squeezed four batteries into that storage box.
Old 05-18-2016, 03:41 PM   #3
mdf
Sorry, my internet must be too slow to upload the hi res pic. Will post when I can save in a smaller footprint. We had to take the plastic hatch off to get them in, then reinstall once they were seated.
Old 05-18-2016, 04:06 PM   #4
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Yes - I was wondering about that too! 4 batteries?
Old 05-18-2016, 04:35 PM   #5
2015 16' Sport
Santa Rosa , California
MDF,
I saw your Interstate at Vinnie's. I had my trailer in for some service work. The batteries looked great and are a perfect fit. I want to second your opinion of Vinnie's work! He did a great job for me.
rnelson is offline   Reply With Quote
Old 05-18-2016, 05:33 PM   #6
mdf
Here is the photo
(4) Lifeline 4CT 6 volts
Old 05-18-2016, 05:37 PM   #7
mdf
One more thing about Vinny. He was previously the service manager at Mercedes Benz of Santa Rosa, so he is more than familiar with the Sprinter. Conveniently, his shop is literally across the street from MB Santa Rosa. Easy to get anything fixed or serviced!
Old 05-18-2016, 08:35 PM   #8
toskeysam's Avatar
Townsend , Tennessee
Very nice picture......hmmmmmm.....
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 05-18-2016, 09:31 PM   #9
toskeysam's Avatar
Looks like a great idea. My only concern comes from memories of my Ford Pinto....granted these are not gas tanks....but....
FMCA # 436814
Old 05-18-2016, 10:06 PM   #10
lewster's Avatar
Naples, FL , Hood River, OR
Interesting placement and nice work but remember that 4 Lifeline 4CT golf cart batteries weigh in at about 270 lbs. Thats a bit of weight to place that far to the rear of the long wheel base Sprinter.
Old 05-18-2016, 10:36 PM   #11
mdf
Thanks everyone - to be clear - this was a stop gap solution to get me through this summer. The 4cts are heavy, although I think not an issue. I did remove the stock 24s, which were also pretty far back (and off center) and almost equal in weight to two of the 4cts. Lewster, we will go lithium when the big project gets done!
Old 05-18-2016, 11:27 PM   #12
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Might make the rear ride less bouncy.
Old 05-19-2016, 04:05 AM   #13
Teamaron's Avatar
Boca Raton , Florida
+1 on this
If not batteries maybe put some cinder/concrete blocks in temporarily
Teamaron is offline   Reply With Quote
Old 05-19-2016, 05:40 AM   #14
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Well within the Sprinter's/Interstate's load-bearing capacity.
It would be a good idea to weigh the loaded van (including rear-seat passengers) by axle to see how close it is to the Gross Rear Axle Weight rating— which can determine if the added weight of the batteries takes away any tongue weight capacity for trailer towing or use of a hitch-mounted cargo carrier. As long as GRAW is still at least 500 pounds more than the actual rear axle weight, there should be no reduction in towing capacity with regard to tongue weight.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
12V converter/battery/monitor upgrade dznf0g Batteries, Univolts, Converters & Inverters 35 01-31-2016 07:49 PM
Battery Upgrade Roadrunner Batteries, Univolts, Converters & Inverters 9 08-08-2010 07:44 PM
Performance report: Battery upgrade one year ago hshovic Electrical - Systems, Generators, Batteries & Solar 4 07-10-2009 09:04 AM
Battery and Univolt upgrade report - 1981 280 MoHo outofcontrol Batteries, Univolts, Converters & Inverters 5 03-22-2009 06:29 AM
Bambi upgrade to group 31 battery? rfield54 Electrical - Systems, Generators, Batteries & Solar 0 05-17-2005 09:33 AM
