Old 01-28-2015, 05:43 PM   #1
Mjgman's Avatar
2013 Interstate Coach
Bradenton , Florida
Battery separator
Took my coach in for service. Both batteries were losing charge, after posting on the forums it was suggested that my battery separator was malfunctioning..
It turned out that a wire from the battery boost had a screw in it and was causing it to short out.. So I had a constant drain on power even when the coach battery was turned off..
All fixed now, and I'm having them give me a quote to increase the solar power... Pick it up this week. I miss having it near by even though I won't be using it anytime soon.. 😀
Mjgman is offline   Reply With Quote
Old 01-28-2015, 06:06 PM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
My BIM went bad w/o any extra screws shorting stuff out.
If I make it to Bradenton over Spring break, will have to look you up.
Old 01-28-2015, 06:47 PM   #3
Mjgman's Avatar
Bradenton , Florida
That would be great.. Spring time is hit or miss down here.. Some years we have had wonderful weather other years it's hot and muggy..
Old 01-28-2015, 07:40 PM   #4
73shark's Avatar
Close to 75th W and Manatee W?
Question about wiring new battery charger on the battery side of the latching relay. BTUs4You General Repair Forum 3 07-27-2012 12:36 PM
Water separator / fuel filter for gas motor home Taxman Land Yacht/Legacy Motorhomes 14 03-21-2011 08:55 PM
To battery or not to battery 29348 Batteries, Univolts, Converters & Inverters 4 07-16-2006 02:02 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
