Old 09-01-2019, 05:54 AM   #1
2019 ​Interstate Nineteen
Verona , WI
Battery location on 2020 AI 19
Can anyone confirm the house battery location on an 2020 AI 19? Thank you.
KIA59K is offline   Reply With Quote
Old 09-01-2019, 08:04 AM   #2
old/new member
preedtx's Avatar
I think i see 2 on mine, one on each side underneath near the front cabled together. If placed for weight balance i will credit AS for good engineering.
But we need a more opinions.
preedtx is offline   Reply With Quote
Old 09-01-2019, 09:00 AM   #3
Gainesville , Florida
Those may be the coach batterys if under the hood. Is that wher you meant or inside the coach.
Old 09-01-2019, 09:07 AM   #4
2012 Avenue Coach
Corpus Christi , Texas
I think you mean chassis batteries in your example above.
rowiebowie is offline   Reply With Quote
Old 09-01-2019, 09:40 AM   #5
old/new member
preedtx's Avatar
The Mercedes chassis battery is under the floor in front of the drivers seat. There are no batteries under the hood of my 2020 19.
Old 09-01-2019, 10:27 AM   #6
Verona , WI
Thank you. I looked under both driver's and passenger's seat and it looks like there is a battery under each one and they are connected. Not sure if this is correct and, if so, if both of these are for the Airstream. It looks like you can access the battery terminals under the passenger seat by lifting the velcroed flap that faces the door.
Old 09-01-2019, 11:39 AM   #7
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
PREEDTX - I'd say you have it right. But the owners manual is a bit confusing at it seems to indicate there is only "a" (one) coach battery. See first attached clip from owners manual. But the wiring diagram and parts list clearly indicate there are two coach batteries, one on each side near the entry steps. See other attached clips from wiring diagram in owners manual and parts book.
ID:	351035   Click image for larger version
ID:	351037   Click image for larger version
- - Mike
Old 09-01-2019, 12:28 PM   #8
old/new member
preedtx's Avatar
Thanks, i guess my degree in Electrical Engineering finally paid off.
BTW, The AS 19 web page specs does say 2 coach batteries.
Old 09-11-2019, 11:44 PM   #9
Spokane , Washington
Two AGM Lifeline batteries. Under the chassis. One on each side of the coach, on their sides. Terminals facing the center of the vehicle.
1919 is offline   Reply With Quote
2020 Globetrotter 23FB Twin - Dometic RMD 8555 wont run on battery dianacr 2018 - Current Globetrotter 29 08-04-2019 08:06 AM
Battery box and battery location(s) ehodg66 Batteries, Univolts, Converters & Inverters 4 04-22-2014 07:39 PM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
jordan 2020 brake controller 57overlander Brakes & Brake Controllers 5 11-25-2004 07:10 PM
