Old 08-22-2019, 12:29 PM   #1
Washboy's Avatar
2012 Interstate Coach
Spicewood , Texas
Battery Isolator- Replacement Help
My 2012 AI is not charging the house battery from the engine alternator. I cannot find any blown fuses or loose connections. I purchased a Blue Sea
ML-ACR 7620 to replace the Sure Power 1315-200 battery Isolator. I have searched the forums and cannot find where anyone has had the sure power. I also do not have a dash button. If anyone could help me with wiring, I would really appreciate it. I replaced the trip lite inverter with a magnum last year with no problems thanks to information on this forum.
Washboy is offline   Reply With Quote
Old 08-22-2019, 12:48 PM   #2
Rig Rat's Avatar
2015 Interstate Ext. Coach
Columbus , Ohio
I believe that Wachuko has put a blue sea BIM wiring diagram on his thread “our journey begins!
Adventure before Dementia!
Rig Rat is offline   Reply With Quote
Old 08-22-2019, 12:50 PM   #3
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Fairly easy install. Are you doing the switch in the dash or close to the location of where you are installing the ACR?
Let me get you links from when I did mine... those might help
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 08-22-2019, 12:55 PM   #4
2013 Interstate Coach
Raymond , Iowa
Not sure where all you have looked for fuses, but:
At the side of the chassis battery, under the driver floorboard, is a positive buss with several fuses and cables. One of the fuses/cables goes to the BIM. If that fuse is blown the alternator would not charge the chassis battery, nor would the chassis battery be charged by the Magnum. I assume that this same fuse is used in your Sure Power BIM as in the Precision Circuit BIM in my 2013. You need this fuse to be good even if you change to the Blue Sky BIM.
Titus is offline   Reply With Quote
Old 08-22-2019, 01:06 PM   #5
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
When you install the Blue Sea, you lose the dash button function anyway. In my installation, I installed the remote for the Blue Sea above the driver's seat where it can be easily reached to couple the batteries.
Best electrical mod I have done on two AIs now, my former 2014.5 and my current 2018.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 08-22-2019, 01:20 PM   #6
Raymond , Iowa
As I read Wachuko's instructions the dash switch still works. Using terminal 2 he connects the red wire of the ACR to the gray/black wire of the dash switch. Of am I misinterpreting something?
Old 08-22-2019, 01:31 PM   #7
wachuko's Avatar
Orlando , Florida
Here you go:
http://www.airforums.com/forums/f240...ml#post2083406
Originally Posted by wachuko View Post
Since we can't go back and edit our post , consolidating all the post on the ACR install... and correcting a mistake on a post I made where I said that the Isolation Brown was not connected when it was actually the Orange (Isolation #3) that was the one left unused.
I wanted to have the switch in the front... I reuse the cable that goes to the exiting switch. Red (Terminal 2) wire from ACR connected to Gray/Black wire that goes to switch. And then I had to run 2 additional wires from the back to the front, to complete the install of the switch as per the install diagram (Terminal 7 for the yellow wire, and Terminal 8 from House battery).
Let me try to consolidate the updates from my thread in one post...
Response from Blue Sea (which is what Pahaska and FlyFishinRVr said )
My Blue Sea ACR was installed in the following way (remember to install the 2amp inline fuses!! ):
Terminal 1 - I ran a cable from chassis battery negative/ground post to here...
Terminal 2 - I reuse the cable that goes to the exiting switch. Red wire from ACR connected to Gray/Black wire that goes to switch.
Terminal 7 - Yellow one that goes to the switch in the front... ran additional wire for this.
Terminal 8 - Ran an additional wire from switch to house battery. Also with a 2amp inline fuse. I connected this to the terminal A in the ACR since the house battery connects there as well.
Jump Terminal 8 and Terminal 3
Used the Isolation #2 (Green) for the Gen-Stat wire - remember to place a 2 amp inline fuse.
Isolation #3 (Orange wire) - left without any connection.
I might be repeating my self. But for clarity. Here is matching to old Battery Isolator:
Dash Switch - Goes to Terminal 2 on ACR switch - I reuse the cable that goes to the exiting switch. Red wire from ACR connected to Gray/Black wire that goes to switch.
Ground - to ground block in that area
Gen-Set- Connect to the Isolation #2 (Green wire) - remember to place a 2 amp inline fuse.
Coach Bat - Terminal A on ACR
Chassis Bat - Terminal B on ACR
Ignition - Connected to Isolation #1 (Brown wire)
So connection ends up being as if you had two engines (one is the Sprinter engine and one is the Generator):
I was going to order a new trim to get rid of the trim with the hole where the stock switch was... Rather than ordering a new lower dash trim , I took out the switch, remove the label it had and installed that on the inside (to not lose it)... installed switch back and trim back in place. And now it looks factory and there are not labels to confuse that with anything else... it is just there disconnected.
I hope it is clear now for those doing the Blue Sea ACR install... This is one of those "Must do" modifications.
Safe travels!
Wachuko
WBCCI #26769
Old 08-22-2019, 01:34 PM   #8
wachuko's Avatar
Orlando , Florida
Factory switch is no longer needed. If you need to manually combined them, you do so using the switch that comes with the Blue Sea
Safe travels!
Wachuko
WBCCI #26769
Old 08-22-2019, 01:36 PM   #9
wachuko's Avatar
Orlando , Florida
Thumbs up
THIS ^^ might be the problem he is having...
Safe travels!
Wachuko
WBCCI #26769
Old 08-22-2019, 01:45 PM   #10
Contributing Member
Pahaska's Avatar
Depending on the setting of the remote switch, hooking the dash switch into the red wire could short +12 to ground. Since my remote is within reach of the driver, I chose to abandon the dash button. I can reach up over my left shoulder and couple the batteries.
John W. Irwin
WBCCI #9632
Old 08-22-2019, 01:51 PM   #11
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
At the side of the chassis battery, under the driver floorboard, is a positive buss with several fuses and cables. One of the fuses/cables goes to the BIM. If that fuse is blown the alternator would not charge the chassis battery, nor would the chassis battery be charged by the Magnum. .
TITUS - I am confused here - But how does that blown fuse (if it is indeed blown) affect the charging of the house battery? OP is having problems charging house battery from alternator but did not state there is any problem charging the chassis battery; ergo - if no issues charging chassis batt, then I assume the fuse is NOT blown
Alex AVI is online now   Reply With Quote
Old 08-22-2019, 01:58 PM   #12
Washboy's Avatar
Spicewood , Texas
Iím going to check that fuse again. I think itís big like 80 amp or something like that. But I would still like to upgrade the BIM. Again my AI does not have a switch or button at the Dash. I would love to post photos, and I have before, but my iPhone is not allowing me the choice to upload photos. I may have a setting wrong.
Old 08-22-2019, 02:01 PM   #13
wachuko's Avatar
Orlando , Florida
Thumbs up
I sent you my email id... send those over and I will post them for you.
Safe travels!
Wachuko
WBCCI #26769
Old 08-22-2019, 02:04 PM   #14
Contributing Member
Pahaska's Avatar
You have several choices:
  1. You can mount the ACR remote within reach of the driver, as I did
  2. You can have a second person operate the remote to couple the batteries in the remote chance you ever have to do so. I never have had a necessity.
  3. You don't lose anything since you don't have a dash switch now.
John W. Irwin
WBCCI #9632
Battery Isolator Replacement JJ1965 Classic Motorhomes 13 06-15-2019 09:05 AM
Battery Separator switch (Battery Isolator) problems Prairie Sprinter and B-van Forum 5 01-22-2018 05:42 AM
battery isolator kooblekidz Airstream Motorhome Forums 5 08-28-2003 06:04 AM
Battery Isolator thenewkid64 General Motorhome Topics 20 01-12-2003 09:00 PM
Battery Isolator shelocta Airstream Motorhome Forums 1 10-29-2002 10:32 PM
